Total blackout
Discussion in 'Lighting' started by axeeclipse, Aug 26, 2021.
  1. Aug 26, 2021 at 11:27 AM
    axeeclipse
    axeeclipse [OP] Member
    I have a 21 SR that I would like to get a switch to disable all light sources internally and externally for night hunting under NODs. I want to be able to drive around the ranch while wearing NODs so the dash lights ect inside need to be off completely.
    Anybody ever done this for hunts? Any clue on where to begin for this?
    Gunshot-6A likes this.
  2. Aug 26, 2021 at 1:32 PM
    caribe makaira
    Caribbean, Puerto Rico
    Brake lights would be an issue, since the power to illuminate them is also a signal to other systems. Dash Combo meter has its own fuse. Not touching the light stalk at the steering gets over most of the external an internal illumination. Head Unit might also be an issue.
  3. Sep 15, 2021 at 12:07 PM
    archangel689
    archangel689 Pvt Pyle
  4. Nov 9, 2021 at 12:02 AM
    axeeclipse
    bumping this again....
    I've been just pulling fuses but that's been a pain in the a$$ every hunt.
  5. Nov 9, 2021 at 7:21 AM
    caribe makaira
    How many fuses and which ones?
  6. Nov 9, 2021 at 7:25 AM
    tirediron
    tirediron Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    Given the complexity of your vehicle and how interconnected things are (shared power, light activation used by ECM to signal various things...) I would do it the old fashioned way. Make some cardboard/posterboard shields that you can put over the internal lights, and get blackout drapery lining and make covers for the external ones. I little bit of a PIA, but way less hassle in the long run, IMO.
  7. Nov 9, 2021 at 7:31 AM
    Gunshot-6A
    Gunshot-6A Prime Beef
    Conner
    Everett, WA
    '15 TRDOR / '17 Africa Twin
    Yes, it's way easier to mask things off than to try and killswitch anything unless you have a dedicated ranch truck for such purposes.
    Bingo. You can use the scroll wheel to make the dash lights go to zero. I also use a thick piece of cardstock with some painters tape along the edge to cover the nav screen. Exterior running lights on my 2015 can be switched off, but on the newer ones, may need to be blacked out manually using a combo of painters and gorilla tape.
    The method a few SOCOM buddies relayed to me was to cover the taillights in a layer of painters tape, then cover that layer in gorilla tape in all but a tiny little section so Vic2 can see the brakes and avoid smashing you from behind. The painters tape should keep it dim enough that your vis signature is pretty minimal. Tapeover only takes a few mins, and I just keep that cardstock for the interior in the seatpocket with some spare tape strips fixed to the sheet itself.
    Obligatory NODs tomfoolery:
