TOTAL CHAOS - 05+ Bed Stiffeners
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TOTAL CHAOS, Sep 25, 2018.
  1. Sep 25, 2018 at 11:06 AM
    TOTAL CHAOS
    TOTAL CHAOS [OP] WWW.CHAOSFAB.COM Vendor
    Corona, CA
    * Patent # D820,180 *
    Bed Stiffeners - What do they do? Do I need them?
    This is a very common question we get at TOTAL CHAOS. If you're running a camper shell, bed rack w/ RTT, or just putting your truck through serious off-road abuse then you should consider Bed Stiffeners.
    On 2005 and newer Tacoma's the composite bed is very weak. Over time they can fracture or crack causing issues with tailgate alignment and possibly lights. We reinforce the rear bed channels at the tailgate which is ideal for preventing bed flex and avoiding issues that come along with it.
    The TOTAL CHAOS Bed Stiffeners also feature additional tie-down points. Adding a set will give you 6 tie down points and 2 light or whip mounts. *no load ratings are implied
    Constructed of 3/16" steel these are built to last. We finish them in a durable black powder coat and include grade 8 hardware for the install. Are you running TOTAL CHAOS Bed Stiffeners or have questions about them? Post up :thumbsup:
    2005-2015 Tacoma - HERE - $170.83
    #48675
    2016-2018 Tacoma - HERE - $159.65
    #48676
    INSTALL INSTRUCTIONS
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
    [​IMG] [​IMG]
    Kolter45 likes this.
  2. Sep 25, 2018 at 12:07 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    I bought these and installed them. I have a leer canopy and the weight was causing the bed to crack on both sides down below the tail-lights. I would recommend them..
    asudevil likes this.
  3. Sep 25, 2018 at 12:19 PM
    ColoTacoPrerunner06
    ColoTacoPrerunner06 Truck of my dreams
    Speedway Blue 06 Prerunner built like I like it.
    5.5 lift front 4 rear on 33s with an endless amount more work to do
    What makes these bed stiffeners 60.00 better than the cali raised or others that I can get for 100.00?
  4. Sep 25, 2018 at 1:28 PM
    TOTAL CHAOS
    Corona, CA
    Thanks for posting up - it appears you accidentally received the 3rd Gen Bed Stiffeners. The top of the stiffener is slightly different between the second and third generation Tacoma. Here is a picture showing the difference:
    2005-2015 (#48675) is on the Left. 2016-2018 (#48676) is on the right.
    Our apologies about the mix up. Glad you were able to make them work!
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
    b_r_o[QUOTED] likes this.
  5. Sep 25, 2018 at 2:39 PM
    TOTAL CHAOS
    Corona, CA
    Customers that choose TOTAL CHAOS bed stiffeners are looking for superior quality, customer service, and a product that will easily last the lifetime of the vehicle. Constructed of laser cut 3/16” steel and powder coated in a durable semi gloss black finish these stiffeners were designed to be a solution to a personal problem the owner of TC was experiencing on his 2013 Tacoma that had a camper shell installed. Our Patented Bed Stiffeners extend higher than the competition which gives your bed rails additional support that we know it needs from our personal use and experience. The additional height is something that’s often overlooked and necessary with the Tacoma’s composite bed. These are 100% Made in the USA. If you have more questions don’t hesitate to email info@chaosfab.com
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
  6. Sep 25, 2018 at 2:49 PM
    ColoTacoPrerunner06
    That was an awesome answer. I have your upper arms on my truck and know you build quality stuff. When I decide to get these you will be high on the list. Any chance you could incorporate a bottle opener into these?
  7. Sep 25, 2018 at 2:49 PM
    TOTAL CHAOS
    Corona, CA
    @b_r_o
    Send us a PM if you can (tried sending you one, but your account is locked). We'd like to see the sales info on your order and figure out where the error occurred. Sorry again about the issue
    TOTAL CHAOS
    WWW.CHAOSFABCOM
  8. Sep 25, 2018 at 2:54 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Pm sent
  9. Sep 25, 2018 at 2:56 PM
    TOTAL CHAOS
    Corona, CA
    Thanks for the support :thumbsup:
    No plans on adding a designated bottle opener at this time, but the antenna/whip mount still works if you're familiar with opening bottles on the edge of a table :cheers:
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
    Dye22, 93yotasr5, Maggot61 and 2 others like this.
  10. Oct 24, 2018 at 8:15 AM
    TOTAL CHAOS
    Corona, CA
  11. Nov 19, 2018 at 1:22 PM
    TOTAL CHAOS
    Corona, CA
  12. Jan 26, 2019 at 10:34 AM
    steezymac
    steezymac Well-Known Member
    Front Range, CO
    2016 Black Tacoma TRD Off-Road
    Question to y’all Running the total chaos bed stiffers with a sleeping platform and drawer system...
    I bought some at the helm bed stiffeners thinking they would clear the circled support area, but the drawer is just barley going to hit it.
    It looks like the same area on the total chaos ones are shorter and I won’t have to alter my drawer system to get it to work.
    Better yet, maybe someone can give me a measurement of that whole bottom section so I can be exactly sure.
    Thanks!
  13. Jan 28, 2019 at 11:06 AM
    TOTAL CHAOS
    Corona, CA
    Edit:
    Let us know if these will work! Happy to provide more details.
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
  14. Jan 28, 2019 at 11:47 AM
    Bobcdn
    Bobcdn Well-Known Member
    WTB; 2nd gen well built Tacoma
  15. Nov 30, 2019 at 2:32 PM
    TOTAL CHAOS
    Corona, CA
    20% Off While Supplies Last!
    Enter Promo Code STIFFY
  16. Nov 30, 2019 at 6:49 PM
    Richie Rich
    Richie Rich Toyota Hoarder
    760 (San Diego)
    2010 X-Runner 2011 TRD Sport DC 4x4
    More than I can afford
    Damn, I should have waited.
    Just bought some a few weeks ago.
    Great product BTW. Like that it clears the OEM bed mat and the tie down points are handy. My bed was out of whack already (shell, rack) had to draw one side in a bit.
  17. Dec 3, 2019 at 7:51 AM
    TOTAL CHAOS
    Corona, CA
    Glad you like them! Any pics of your setup?
  18. Dec 3, 2019 at 8:13 AM
    Richie Rich
    760 (San Diego)
    Sure do. Took a couple while I was installing them. Also have your upper arms on this truck and a Gen 2 Caddy kit on my 86 4x4 project truck.
    Reminds me, I gotta order new bushings and uniballs for the uppers on this truck.
  19. Dec 3, 2019 at 10:09 AM
    Musubi3
    Musubi3 Well-Known Member
    Big Island
    2014 Tacoma DC 4x4 TRD Off Road, Supercharged
    I've been enjoying and using mines for some time now. I off road with my kayaks on the racks and thought this was a good safe measure. I use the additional tie downs a lot. I recently removed them to refinish the surface since I had some developing rust spots. I do a lot of salt water activities. These stiffeners are much more heavy duty than I thought.
  20. Dec 3, 2019 at 1:06 PM
    TOTAL CHAOS
    Corona, CA
    Rad!
    That is a nice setup
    Reach out when you need to get an order going
