Total Chaos 2" LT Kit
Discussion in 'Long Travel Suspension' started by HIYota, Jul 9, 2011.
  1. Jul 9, 2011 at 4:41 AM
    HIYota
    HIYota [OP] Well-Known Member
    Angel
    Las Vegas, NV originally Kauai, HI
    09 Silver 6 spd TRD Sport DCSB 4x4
    Check my build thread...too much to list.
    Is anyone on TW running the Total Chaos 2" LT Kit? I've been looking into the AllPro LT kit because it isn't as wide. Thing is the AP LT kit to me seems like it's' a one and done thing. No upgrading the setup if I choose to do so...Just wanting to know how much if possible the TC 2" LT Kit can be upgraded?
    Here is the link...http://www.chaosfab.com/86002.php
  2. Jul 9, 2011 at 8:44 AM
    nelson18matt
    nelson18matt Well-Known Member
    Goodyear, Arizona
    2004 Long Travel Tacoma
    *SOLD*
    what do you want to upgrade...?
    the TC kit is different from the AP kit in that it's a boxed design, allows the use of a secondary (bypass) shocks, and the upper arms can be heimed instead of bushings
    other than that, they are pretty much the same... both have uni ball upper and lower, yeild the same travel and retain 4WD drive
  3. Apr 8, 2012 at 1:16 PM
    stephen11ty7
    stephen11ty7 Well-Known Member
    Stephen
    Villa Park
    07 white taco
    Total Chaos 2" LT, Icon coilovers
    I've been contemplating this kit for a while now! Anyone on here have it?
  4. Apr 8, 2012 at 3:35 PM
    Piratefish
    Piratefish Well-Known Member
    Sebastopol
    2011 Tacoma Off Road
    Sadly None
    Its what Im going with but I dont have it yet. Working on the rear first, got my defined kit the other day.
  5. Apr 8, 2012 at 3:50 PM
    stephen11ty7
    Stephen
    Villa Park
    07 white taco
    how do you like that?
  6. Apr 8, 2012 at 3:55 PM
    Piratefish
    Sebastopol
    Sadly None
    If your asking me Its not installed yet. The defined kit that is.
    From what I can tell the TC kit is great. I dont need the extra width so the 2" over is for me. THe only bummer is that you still need fenders, axels and everything else.
  7. Apr 8, 2012 at 11:00 PM
    thekernel114
    thekernel114 Well-Known Member
    Chilliwack, B.C.
    07 tacoma 4x4
    allpro long travel, shackle flip with ome dakars, cruisin offroad bumpers and sliders, 4.88 gears with arb's front and rear, budbuilt skids.
  8. Apr 8, 2012 at 11:25 PM
    stephen11ty7
    Stephen
    Villa Park
    07 white taco
    Funny, I read the exact same thing on another build, they weren't getting the advertised numbers out of the kit, and in turn went with Camburg!
  9. Apr 8, 2012 at 11:26 PM
    stephen11ty7
    Stephen
    Villa Park
    07 white taco
    Yes I was asking if you had the defined rear installed yet. Which kit did you get?
  10. Apr 8, 2012 at 11:51 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    I thought it was just for the FJ's and 5 lugs?
  11. Apr 9, 2012 at 3:21 AM
    HIYota
    Angel
    Neg, TC has put it on a Tacoma. The site says that you just need ext axle shafts to keep 4WD.
  12. Apr 9, 2012 at 4:22 AM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    What use will you have for it? Will you need a secondary bypass is the main question?
  13. Apr 9, 2012 at 5:02 AM
    HIYota
    Angel
    I honestly don't know if I'd have the need at this point. This post is pretty old and I've had some modifications to the truck since. I've also learned a lot from this forum. At this point my truck is MT and I plan on keeping it that way untill I pay the wife's 4runner off. Who know's where I'll live when I can afford something like this so I got time to do more research. I'd like the keep the truck slimmer so the 2" would be better for what I want. If not I'll just build a beast MT.
  14. Apr 9, 2012 at 8:29 AM
    stephen11ty7
    Stephen
    Villa Park
    07 white taco
    You never "need" a secondary shock, the kit just has the luxury of running a secondary shock. Also this kit yields more travel than a replacement LCA from TC, but not quite as much as their 3.5" kit. The 2" kit IMO is for someone who DD'S their truck, and wants off road performance, but wouldn't mind 4" wider track width vs. 7" total.
  15. Apr 9, 2012 at 11:27 PM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    "Need" is relative lol! If I had that kit, I'd def take advantage of the seconday bypass!
    Ext travel MT with some air bumps up front and a SUA in the rear would do the job too! I'll prob end up with a 2" over as well....but it won't be for awhile!
  16. Apr 11, 2012 at 2:17 AM
    Marnes2986
    Marnes2986 Well-Known Member
    Mark
    Anaheim-Corona, Ca
    not trying to get too involved lol....but if you have to get fenders anyways, why not just go with the regular 3.5 kit.
    always those situations where you say, "shoudve gone bigger/better"
  17. Apr 11, 2012 at 2:29 AM
    HIYota
    Angel
    My thought on that issue is I'm in the military and I have no clue where I am gonna be stationed. I like exploring the outdoors as much as I'd like to go fast in the dez. Making the width only 4" wider is a benefit for either senario compared to 7.5" wider. I am looking for an all around build. Not to mention having 4WD is gonna limit my travel to the roughly the same numbers anyway.
  18. Apr 11, 2012 at 4:13 PM
    stephen11ty7
    Stephen
    Villa Park
    07 white taco
    Camburg's 3.5" kit has an advertised 14" with 4x4 and chaos at 13.5" while the 2" kit shows 11.5, just depends since those numbers are not universal, some trucks pull less and some more.
  19. Apr 16, 2012 at 4:07 PM
    Trifenix
    Trifenix Well-Known Member
    so cal
    99 LT 5 lug Taco
    3.5 might as well. Mid travel and 2 isnt far apart enough imo.
