TOTAL CHAOS +3.5" Race Series Long Travel
Discussion in 'Long Travel Suspension' started by TOTAL CHAOS, Aug 3, 2018.
  1. Aug 3, 2018 at 3:37 PM
    TOTAL CHAOS
    TOTAL CHAOS [OP] WWW.CHAOSFAB.COM Vendor
    Corona, CA
    https://youtu.be/3r6YdLJskv8
    LIFT: 3-4"
    TRAVEL: 13"
    TIRE: 33" or 285
    TRACK WIDTH INCREASE: 7"
    MORE INFO
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
    • 100% chromoly constructed Race System offers maximum ground clearance and weighs 10 pounds less than the standard TC +3.5" LT kit.
    • 3.5" extended 4130 chromoly tubular upper arms bolt to factory control arm mounting locations.
    • Upper and lower ball joints are replaced with 1" uniballs for maximum wheel travel and component strength. TOTAL CHAOS includes 1" I.D. uniballs that feature a heat treated stainless steel ball & heat treated stainless steel race for maximum corrosion resistance and component longevity. These uniball's also features a military grade PTFE woven fabric liner that helps prevent noise.
    • 4130 chromoly boxed and internally gusseted 3.5" extended lower control arms bolt to factory control arm mounting locations and are pre tabbed for dual shock capability.
    • Lower control arms feature an integrated uniball cup that provides 2.5" additional ground clearance when compared to the standard mild steel +3.5" LT kit.
    • Lower arms are 5 pounds lighter each side than the standard +3.5" LT kit.
    • 2.5" long travel specific coil over shocks bolt into the factory coil bucket location. Extended travel shocks are too short and will not work.
    • A secondary external bypass shock can be installed to increase dampening and tune-ability.
    • Spring rate options offer the ability to customize your ride for your specific application allowing you to custom tune the vehicle for specific terrain or desired performance.
    • Adjustable limit strap clevis' are included so that you can properly limit the suspensions droop wheel travel and make necessary adjustments during the life of the limit strap.
    • DOT approved stainless steel braided brake lines, TC custom 17-4 stainless hi-misalignment spacers and grade 8 mounting hardware is included.
    • TC 4340 custom extended axles reuse factory inner and outer CV's to retain 4wd.
      (axles are sold separately and not included with the kit)
    • 2 stage powder coat process includes a durable clear coat to provide a long lasting finish.
    • Hand crafted in the U.S.A.
    • Fiberglass fenders are required on Tacoma.
    • *If FOX Shox will be used, an "F" must be added to the LT kit part number, i.e. 86000-R-F
    ocherp, ChadsPride, Dalandser and 5 others like this.
  2. Aug 3, 2018 at 3:37 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
  3. Aug 3, 2018 at 4:48 PM
    Tango Bravo
    Tango Bravo Sailing the Seven Seas
    Thomas
    SoCal
    09 4x4, The Green Rubber Ducky
    Chaos 3.5" Race LT, RJ Fab Cantilever LT
    Any tacomaworld discount?
    :mudding:
  4. Aug 3, 2018 at 5:56 PM
    TOTAL CHAOS
    Corona, CA
    Sorry - No forum discounts or specials
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
    Tango Bravo[QUOTED] and PapaBear like this.
  5. Aug 4, 2018 at 7:44 PM
    TrapComa
    TrapComa Well-Known Member
    Mason
    Cedar Park, TX
    07 Indigo Ink LT PreRunner
    Wannabe prerunner, wannabe overlander
    I got the race kit to run lift spindles and I love it
  6. Aug 6, 2018 at 9:23 AM
    TOTAL CHAOS
    Corona, CA
    Nice truck! Have any more pics? Post them up if you don't mind :thumbsup:
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
    ChadsPride likes this.
  7. Aug 6, 2018 at 3:21 PM
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    Love the race kit...just need to install my bypasses now.
    2018SMURFPRO likes this.
  8. Aug 6, 2018 at 3:28 PM
    TrapComa
    Mason
    Cedar Park, TX
    I actually took pictures today. I just got the Method 106 Beadlocks and BFG KM3s on a few days ago. I wish I could post videos on here of me hooning it. Next up is a rear suspension to match the front
    Stryker420 and ChadsPride like this.
  9. Aug 6, 2018 at 3:29 PM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    What you doing for the rear?
  10. Aug 6, 2018 at 3:30 PM
    ChadsPride
    Sponsored by TacomaWorld.com
    #goals
    Upload the video to youtube and post the link!
    Stryker420 likes this.
  11. Aug 6, 2018 at 3:59 PM
    TrapComa
    Mason
    Cedar Park, TX
    Probably Camburgs spring under, or getting a local shop to build a spring under. I’d like 4 link but my pay grade doesn’t like that idea
  12. Aug 6, 2018 at 4:13 PM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Crazy man didn’t think you would run burg...icons in the rear too?
  13. Aug 6, 2018 at 4:43 PM
    TrapComa
    Mason
    Cedar Park, TX
    Probably. Icons front shocks ride really good, and the 2.0 icons I have on the rear now are also really good. I’ll probably get rear shocks similar to @tubbsisland spring under setup. I wish Total Chaos would come out with a long travel rear kit.
  14. Aug 6, 2018 at 4:46 PM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    I would be surprised if they ever made one as many of them run a linked rear or the dmz kit. Since dmz has been around so long and has a good following I feel it may not be worth competing with that. Would you have to get custom triples made? It seems icon only makes double bypasses readily available.
  15. Aug 6, 2018 at 4:56 PM
    TOTAL CHAOS
    Corona, CA
    No LT, but we do have a Mid Travel setup for the rear end :)
    Mid Travel Rear - Spring Under Conversion (without springs)
    Mid Travel Rear - Spring Under Conversion (with springs)
    *Shown with a FOX 2.5 10" bypass + TOTAL CHAOS Rear Shock Hoop
    • Wheel travel specs: Wheel travel with stock mounting location shocks- 9.5"
    • Wheel travel with custom shock mounts- Capable of 12"
    MORE INFO
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
  16. Aug 6, 2018 at 4:57 PM
    TOTAL CHAOS
    Corona, CA
    THANKS FOR SHARING THESE!!!!
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
  17. Aug 6, 2018 at 6:56 PM
    TrapComa
    Mason
    Cedar Park, TX
    It looks like a good kit, but y’all need to build a rear kit that’s a proper match to the front end! And let me test it. I’ll do my best to break it. I’ve tried to break the front, haven’t been able to yet. The closest I’ve gotten is exploding the wheels and tires by hitting a 4’ deep ditch, but the suspension is fine
    *also, feel free to post those on your website or Instagram
  18. Aug 7, 2018 at 11:43 AM
    tubbsisland
    tubbsisland I took snowtanks beer
    Cliff
    Arizona
    My truck when it was sprung under was pretty much the exact same kit as what @TOTAL CHAOS offers below. Stock shackle mounts and fromt hangers with a custom Deaver spring, it may auctually be the same exact kit. It was made by Defined Engineering when I had it. TC has a great working relationship with DMZ too and Tim has a really solid kit so that would naturally be the logical next step beyond their mid travel and is probably the reason why they haven't made a LT spring under kit of their own. If it ain't broke don't fix it.
    Dalandser and Coot83 like this.
  19. Aug 15, 2018 at 8:14 AM
    TOTAL CHAOS
    Corona, CA
  20. Aug 16, 2018 at 6:03 AM
    Jeffrow20111
    Jeffrow20111 Well-Known Member
    Jeff
    Murrieta Ca livin, from Vista Ca thou
    2011 Tacoma Pre runner
    Maxtrac spindles, Total chaos upper arms, king 2.5's, flow master exhaust, K&N intake, throttle body spacer, custom front bumper, McNeil fenders, 33"BFG's, 17" Mickey Thompson classic lock wheels.
    Hey are those your 3.5” lift spindles on the tacoma in the video?? Or stock with gussets ?
