Total Chaos Bed Stiffeners! One of the best investment so far!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by runnin4tacos, Sep 30, 2018.
  1. Sep 30, 2018 at 3:04 PM
    runnin4tacos
    runnin4tacos [OP] Well-Known Member Vendor
    Tuan
    Denver, Colorado
    2017 Cement TRD Pro, 2024 TRD Off Road
    What is up, everybody!
    Since I got my Tacoma 2 months ago I have gotten a few things for the truck, but by far the Total Chaos bed stiffeners is the best thing I bought so far.
    I have taken the truck to 5 offroad trails already and I plan on doing a bed rack so the bed stiffeners were a must. I especially love that it has tabs where I can securely strap down my cooler or anything else.
    Anyone else rocking the TC bed stiffeners?
    Here is a video I did of the install if anyone would need it for their install.
    https://youtu.be/VeS5nBcx67U
  2. Sep 30, 2018 at 3:17 PM
    Timetraveler66
    Timetraveler66 Well-Known Member
  3. Sep 30, 2018 at 4:07 PM
    ShirtTucker
    ShirtTucker Taco Tip Line: 248-434-5508
    2017 V6 Sport AC MT
    Lots-o-stuff
    There have been a few posts about the different bed stiffeners that are available.
    Good video, thanks for posting it.
  4. Sep 30, 2018 at 4:43 PM
    idflyfisher
    idflyfisher Well-Known Member
    Dave
    Boise Idaho
    Dirt Eating TRDOR
    So I guess I need to do this as I just ordered a canopy. I have seen a few post about these, but was unsure of their purpose.
    Thanks for the video.
    Taco Fan and runnin4tacos[OP] like this.
  5. Sep 30, 2018 at 5:01 PM
    OregontoBajaCA
    OregontoBajaCA 2025 DC OR High Bread
    2025 OR DC iF Max
    Abject4x4, DAS Taco, wolf2600 and 2 others like this.
  6. Sep 30, 2018 at 5:16 PM
    NC_IslandRunner
    NC_IslandRunner Well-Known Member
    Rory
    2018 Inferno Taco TRD offroad
    I'm fairly new to Toyota, but are these really needed? Are our trucks really built this cheap? I've never heard of them on Chevy or Dodge, none of the Ford guys I know have ever used them, just seems every time I turn around there is something else needing done to correct bad design or fixes for Toyota's corner cutting. Sorry if I seem naive I'm just use to trucks that can go through hell, they may not resell for much but they are built right. I like my Tacoma so far but really hoping I didn't make a mistake buying it.
    NorCal3056, TacoIII, Tacman19 and 5 others like this.
  7. Sep 30, 2018 at 5:37 PM
    iTacomaSR
    iTacomaSR Member
    I think that just rice out the tacoma
    Bolts will rust in couple days
    You can bend that things with your hands
    See guys in video they don't know WTF they talking about
    The Tacoma bed hold up really good when accident
    GillyLink, wolf2600 and slowboater like this.
  8. Sep 30, 2018 at 5:59 PM
    StuckinOhio
    StuckinOhio Well-Known Member
    Mark
    Ohio
    12' v6 AC 4x4 SR5
    They are not required for strength unless you start adding alot of weight to the bed rails (think bedrack with a tent or HD cap).
    If you dont plan on stuffing your suspension frequently or flex the frame on articulation ramp you will be fine.
    Vendors have been making aftermarket parts for this chassis since 2005. There are thousands of products that people will convince you are NEEDED.
    The polymer bed design has bee around since 2005. I haven't seen many failures on this forum since i joined in 2012.
    My tailgate to fender gap is even and consistent from top to bottom and i do NOT have stiffeners
    The biggest perk of the bed stiffener is more tie down locations. IMO
  9. Sep 30, 2018 at 8:59 PM
    Kamille.bidan
    Kamille.bidan Well-Known Member
    2017 Blue TRD OR MT
    Tacomas have a huge aftermarket. There are a significant amount of owners (pretender-landers or overlanders with gear obsessions) that just buy anything that these 3rd party vendors make.
    TacoKoda, Minny Taco, G19LA and 31 others like this.
  10. Sep 30, 2018 at 9:09 PM
    John taco
    John taco Well-Known Member
    JT - Johnny
    King of Prussia PA
    I had to giggle to this! You are totally true about your statement. :spending:
    TDImark, GillyLink, VanGo3 and 11 others like this.
  11. Sep 30, 2018 at 9:10 PM
    TRDPro916
    TRDPro916 Well-Known Member
    TRD
    None
  12. Sep 30, 2018 at 9:20 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    Truth!
    John taco likes this.
  13. Sep 30, 2018 at 9:30 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    I had a 2nd gen with a composite bed, which I bobbed, making it even weaker. I didn’t have any sort of bed stiffening bracket like this and I used to haul 500lbs of stuff in the bed including weight on the bed rails, and I didn’t have a single issue with any sort of bed flex.
    Also with the bed stiffeners...they’re being mounted at the rear of the bed, which had a pretty beefy steel crossmember connected the bedsides. Sure it would make the bed a little stiffer, but I’m not sure how much benefit there is. Mounting a bed rack would likely add strength to the bed....not reduce strength.
  14. Sep 30, 2018 at 9:32 PM
    Stocklocker
    17TRDORDCSBAT
    I’m working hard tonight brainstorming. My idea is to make my fortune from TW members that will “need” these items. Here’s my ideas so far (Comments welcome):
    1: off road sun visors
    2: gas tank snorkel
    3: Bluetooth stiffener
    4: quadruple battery mount
    5: exhaust piping black-out vinyl
    Just what I’ve come up with so far.
  15. Sep 30, 2018 at 9:35 PM
    Spoonman
    Jamie
    Alberta
    HEY HEY HEY.
    How much for the exhaust vinyl?
  16. Sep 30, 2018 at 9:36 PM
    Stocklocker
    17TRDORDCSBAT
    Price to be determined. Having some trouble getting the prototype to stick to the manifold.
  17. Sep 30, 2018 at 9:37 PM
    Spoonman
    Jamie
    Alberta
    Do you need any test trucks? I volunteer only if I get 10% off.
    uploadadventure and SandyTaco4x4 like this.
  18. Sep 30, 2018 at 9:38 PM
    Amanelot
    Amanelot Member
    Texas
    2016 MGM TRD Sport DCSB
    There is no shortage of fords or chevys running functional headache racks that serve the same purpose. I'm guessing you just didnt realize what headache racks were for
    TacoBlancoOffRoad and CygnusX191 like this.
  19. Sep 30, 2018 at 9:38 PM
    mikekoot
    mikekoot Well-Known Member
    MIKE
    Castlegar BC
    14 ssm dclb sr5/18 tundra
    I've owned 2 2nd gens and a 3rd gen. One built for wheeling. Never felt like i needed this lol
  20. Oct 1, 2018 at 12:00 AM
    WheelInTheSky
    WheelInTheSky Ramblin' Man
    G
    Jackson Hole
    02 XtraCab 4x4 SR5-speed
