Total Chaos bed stiffeners with Amp research bed extender
Discussion in '2nd Gen. Tacomas (2005-2015)' started by nazlax10, Apr 4, 2017.
  1. Apr 4, 2017 at 1:32 PM
    nazlax10
    nazlax10 [OP] Check out my build thread for any products used!
    David
    Woodstock, GA
    '21 Toyota Rav4 LE... At least it's a Toyota
    https://www.tacomaworld.com/threads/nazlax10s-build.408318/
    Hey all! So I've only seen this done once before, but it was only a picture with no real description. I wanted a bed extender but also needed bed stiffeners. Here's how I did it.
    *Your results may vary and I am in no way responsible for any damages if you choose to follow my write up.
    Here's all the products I used:
    Total Chaos bed stifferners
    6- 1 inch spacers
    2- 3/4 inch spacers
    4- 1/2 inch spacers
    6- #10-24 x 3-in Oval-Head Stainless Steel Standard (SAE) Machine Screws
    6- #10 Stainless Steel Standard (SAE) Nylon Insert Lock Nuts
    First you need to cut two inches off of each end of each bed extender tube. Sorry I didn't think of doing a write up until after I already cut them. Here's the after math though.
    Then mount your bed stiffeners per total chaos' instructions.
    After that get the template that came with the bed extenders and cut 3/4'' off the bottom of it. This will allow it to clear the bed stiffener.
    Then tape your template onto the bed stiffener. It'll go towards the rear of the truck, in the corner of the bed stiffener up right.
    Drill all 6 holes. Install the bed extender brackets with the spacers behind them. 4 of the screws should go through the bed stiffiners, these will need 1 1/2" spacers. The screws that go through the door pillar only will need 1 3/4" spacers.
    Then adjust the bed extender width per instructions and install it in the brackets.
    FB_IMG_1491321307804.jpg FB_IMG_1491321312981.jpg FB_IMG_1491321319136.jpg FB_IMG_1491321323908.jpg
  2. Dec 13, 2017 at 3:28 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Great writeup!
    Daves300 likes this.
  3. Jan 21, 2018 at 8:29 AM
    Twizted
    Twizted 1GR FE
    Rob
    America
    '15 DCLB TRD Locked 4WD & '17 Tundra DC SR5 TRD Offroad
    stock af, but hover if you think you disagree... RV living: Vagabond Drifter (6' bed) Custom bed cabinet buildout 175w Renogy solar panel 40a Rich Solar MPPT solar controller 1000w Wagan Pure Line inverter Lavaner Pro 2kw diesel heat exchanger Suspension/wheels: Toytec Aluma 2.5 front shocks with resis 13x700 coils (soon 14x700) Toytec Aluma 2.5 rear shocks SPC UCAs Deaver Stage 3 rear leaf springs Wheeler's 3 degree axle shims Wheeler's U-bolt flip Wheeler's Super Bumpstops 18"x9" XD Monster (x5) 275/75/18 Cooper ST MAXX (x5) EBC Stage 3 pads/rotors Electronics: Kenwood DNX773S iDatalink - Maestro RR Stubby Antenna No-name Switchback LEDs Hella Sharptone horns (no relay) Relocated backup camera w/DIY bracket Armor/recovery: BruteForceFab Rear HC w/swingout BAMF Sliders (DOM, 10 degree w/kick out, rattle-canned) BAMF IFS Skid (BAMF powder-coated) BAMF Mid Skid (BAMF powder-coated) BAMF TC Skid (BAMF powder-coated) BAMF LCA Skids (BAMF powder-coated) BAMF Rear Diff Skid (early model, powder-coated) BAMF CMC Plates US Offroad Winch Bumper Smittybilt X20 10k synthetic rope winch Total Chaos Bed Stiffeners ARB compressor w/air-up kit DIY cowl snorkel ARB rear air-locker Interior: Husky Floor Liners (F&R) Rear 40% seat-delete Hinged fridge platform in place of rear seat Exterior: CaliRaised Low-profile Ditch Light Brackets CaliRaised Side-projecting LED pods CaliRaised Faux TRD Pro Grille Morimoto amber LED fog lights One-of-a-kind 1GRFE plate (second iteration) Removed: OEM Bed Mat CaliRaised bed molle panels
    Any afterthoughts after almost a year using this solution?
    I've got the bed extender already, and am considering stiffeners. Don't have the install template for the extender though.
    Cl9kev and remgu2000 like this.
  4. Jan 21, 2018 at 8:39 AM
    ODNAREM
    Ron
    Huntington Beach,CA.
    2012 TRD Sport Prerunner
    @BLKTRUCK For Potential Future Reference.
    BLKTRUCK likes this.
  5. Jan 21, 2018 at 8:48 AM
    nazlax10
    David
    Woodstock, GA
    Absolutely love it! My bed is still perfectly straight with a ~300lb topper on it, and I use my bed extender at least 3 or 4 times a month. The only thing I would change is I would do a better paint job on the metal sleeves. Some of the paint is starting to chip. I know, that's small stuff that doesn't matter, but I'll probably try to find some black Stainless Steel ones online to replace them with. Other than that this thing is holding up great! As far as the template if you're pretty good at measuring you could try making your own with just some paper or maybe try to find one online. What brand and model bed extender do you have? Also you'll essentially re-use the holes that are currently there for the bed extender. The only thing you'll need to do is transfer any holes to the bed stiffeners that the stiffiners will cover up. The only thing to be mindful of is the design of bed stiffiners. Make sure that if you use your current holes the bed extender will clear the stiffiners.
    Twizted[QUOTED] likes this.
  6. Jan 21, 2018 at 9:29 AM
    Twizted
    Twizted 1GR FE
    Rob
    America
    Thanks for the reply.
    I have the AMP Research just like you, but it was there when I bought the truck. The person that installed mine either didn't have the bed mat in when installing, or didn't pay attention. The left side of my tailgate has to really be shoved in to latch all the way, because it presses into the extender, which is pressing down onto the mat. I'd like to move the extender toward the front of the truck just a bit to compensate, but that's obviously not possible without a hack, or plates like these stiffeners would give me.
    I have a KB Voodoo rack and RTT that add about 175lbs (dry), plus my recovery tracks, and soon-to-be Hi-Lift, so flex is a concern.
    ...still considering.
    How many holes for the extender mounts did you drill through the stiffeners? If all, then my slight relocation might be easier/better.
  7. Jan 21, 2018 at 9:42 AM
    nazlax10
    David
    Woodstock, GA
    I only had to drill one hole through the bed extender.
  8. Apr 4, 2018 at 5:36 PM
    remgu2000
    remgu2000 Keepin' on keepin' on.
    Ray
    Roswell, GA
    Used to have a 2017 Barcelona Red TRD Off-Road DCSB 4x4
    Have you done this mod? If so how did it go? Any tips? I also have the Amp Research bed extender and am considering bed stiffeners since I have a bed rack. I plan to get the install template for the extender off their site.
  9. Apr 4, 2018 at 8:08 PM
    Twizted
    Twizted 1GR FE
    Rob
    America
    I haven't ordered my stiffeners yet. I really need to; it'll probably be my next mod.
    remgu2000[QUOTED] likes this.
  10. Apr 20, 2018 at 8:08 PM
    PacoDevo
    PacoDevo Well-Known Member
    Pops
    Bazetta Twp. Ohio
    2016 SR5 DCLB white "Quinn the Eskimo"
    Could you show on a pic where you cut the 2" off on the bed extender?? I can't tell and am a bit confused.
    Thanks!
  11. Apr 21, 2018 at 4:30 AM
    Nettleberger
    Nettleberger Well-Known Member
    2017 Tacoma TRD Pro DCSB Super White
    Given he is shortening the width (moving the mounting point in from the rails by an inch toward the center of the truck) it was probably the slip joint.
    Norton likes this.
  12. Apr 21, 2018 at 7:35 PM
    PacoDevo
    Pops
    Bazetta Twp. Ohio
    I have an OEM extender.....no slip joint??? Still not sure how this is done.
    hotrod 15 likes this.
  13. Apr 21, 2018 at 7:40 PM
    Nettleberger
    OEM is made by AMP I think - if you were to remove the plastic pieces toward the metal bend and the straight center section - that may cover the slip joint.
    See this vid at 1:08
    https://youtu.be/XkQFrBhegOk
  14. Apr 21, 2018 at 8:19 PM
    PacoDevo
    Pops
    Bazetta Twp. Ohio
    Nettleberger - THANKS for the video.......will have to check out my extender tomorrow.
    Really appreciate it!!!
    Pops
    Cl9kev and Nettleberger like this.
  15. Jun 24, 2018 at 4:24 PM
    phuphyter
    phuphyter Well-Known Member
    I can confirm that the oem extender is made by AMP Research. The vertical supports have "AMP Research" molded into it. Also, you can adjust the width by slipping the larger side tubes over the middle connecting tubes quite a bit. I just did it right now.
    I haven't mounted the extender onto my bed yet.
    Cl9kev likes this.
  16. Jun 24, 2018 at 5:46 PM
    griffin407c
    griffin407c Well-Known Member
    Upstate NY
    '12 DCLB MGM 4x4 Sport w/Entune
    OME 885s on Bilstein 5100s set at 0 with 1/2" plate spacers. OME Dakars with Bilstein 5100 Extended Length Shocks. 16" Pro Comp 7032 wheels wrapped with 285/75-16 Duratracs
  17. Jun 24, 2018 at 8:30 PM
    Twizted
    Twizted 1GR FE
    Rob
    America
    I did this today. Only finished one side, as my mounting location requires four 3/4" and two 1/2" spacers. I will go exchange them at Lowe's tomorrow and finish.
  18. Dec 25, 2019 at 11:34 AM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    Forgot about this thread :thumbsup:
    PasswordIsTaco123 likes this.
  19. Dec 25, 2019 at 12:45 PM
    boogie3478
    14 TRD Off-Road V6
    All the mods
    Lol same. Now I'm trying to remember where I put my AMP Research side brackets...
    Twizted and PasswordIsTaco123 like this.
  20. May 30, 2020 at 9:46 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Thank you! I love my bed extender and am looking into adding bed stiffeners for a RTT. I didn't want to lose any functionality.
