Total chaos, Camburg, or Light Racing UCA'?
Discussion in 'Suspension' started by fishinsteeg234, Apr 7, 2010.
  1. Apr 7, 2010 at 7:42 PM
    fishinsteeg234
    fishinsteeg234 [OP] Well-Known Member
    Alex
    Atlanta, GA
    06 PreRunner Short Bed
    Pro Comp 3" suspension lift kit, Pro Comp 8128 alloy wheels with 285/75/16 BFG AT KO's, Gorilla Lugs, Camburg 1.5" uniball UCA's, AFE cold air intake, Black N-Fab bars, SS extended brake lines, HID bixenon's
    Which one of these brands of UCA's are best for fixing alignment issues and give the best ride for the price? any pics of before and after of the alignment fix? Thx.
  2. Apr 7, 2010 at 7:49 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    TC and LR correct for alignment. Though Camburg arms are said to, some people have installed them, and it made no change in the alignment. As for which is better? It depends on what kind of driving or off roading you do.
  3. Apr 7, 2010 at 7:51 PM
    jandrews
    '09 FourDubDee TRD OR
    Good f'ing question OP.
    I was favoring TC UCAs, found out they impact some extended travel shocks at full droop. It seems LR and Camburg don't. Was leaning towards the Camburg stuff...Chris, can you expound upon these reports of no alignment change in only some Camburg installs?
    Anyway, looking at non-ext travel Icon stuff now and TC UCAs still, as they don't seem to have a problem with the regular travel stuff.
    Doing a lift and tires right is goddam hard and takes too much research :\
    Governor and dziner like this.
  4. Apr 7, 2010 at 7:54 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Camburgs have the same issue with hitting the coil too. Any Uniball UCA will do this, as they have more droop. Seems some Camburg arms dont correct for Caster.
  5. Apr 7, 2010 at 8:09 PM
    fishinsteeg234
    Alex
    Atlanta, GA
    im leaning towards the total chaos, are you having any issues with your TC's chris? do they squeak often?
  6. Apr 7, 2010 at 8:11 PM
    AriZonaD54
    AriZonaD54 BANNED in 49 states...
    Andrew
    Valley of the Sun
    Loved my Camburgs but they squeeked like a bitch and no matter how I treated them or dressed them, I couldn't get rid of the squeek. So I sold them and picked up TC. Been happy for many months now.
    Both are strong like OX, but it was something stupid like the squeek that drove me nuts.
  7. Apr 7, 2010 at 8:11 PM
    jandrews
    People have reported the issue does not occur with Camburg, LR, etc UCAs and Icon Ext Travel. I haven't looked into other brands. Apparently the difference in the actual shape of the UCA is to blame. So no, it doesn't appear to be all brands...just certain combos. In any event, it sucks, but that's what doing your homework is for.
  8. Apr 7, 2010 at 8:13 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Mine have been silent since day one. I have had them under water, had concrete dry on the uniball (No shit), and still not a peep. I have sprayed some dry teflon lube on them once a year. Maybe grease them every 6 months.....or when I remember. :eek:
    m603holden and Byb127 like this.
  9. Apr 7, 2010 at 8:14 PM
    fishinsteeg234
    Alex
    Atlanta, GA
    good to know thx
  10. Apr 7, 2010 at 8:46 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    I think some of the old Camburg UCA's did not correct caster... now they all do, new design. Just had my front aligned with new Camburg (ball joint UCA) and it's night and day how much better the handling is, but then again probably any aftermarket UCA will fix this nowadays.
  11. May 20, 2010 at 4:01 PM
    shockme
    shockme Well-Known Member
    Todd
    Arizona
    2010 4x4
    Looking to change out your upper control arms without hitting the bank account too hard? Camburg now offers a performance upper arm that utilizes the OEM type Toyota ball-joint. You re-use your factory ball joint or we have new premium aftermarket joints available. It gives many of the same benefits their uniball upper arms offer at a much lower cost. By building an upper arm to re-angle the ball-joint, you’re able to gain more wheel travel and keep the joint in its normal operating range. These arms also correct the suspension geometry by increasing much needed caster which improves handling and allows for a wider range of alignment adjustment. The tubular construction also gives you more tire & shock clearance compared to the stock stamped arm.
    Ball-Joint Arm Specs:
    - Tubular chromoly upper a-arms
    - Re-angled ball-joint to increase wheel travel over stock
    - Increase in positive caster geometry for better handling
    - Energy Suspension polyurethane bushings with thick inner sleeves
    - Uses factory ball-joints and hardware
    - Includes all necessary hardware
    - Stainless steel ABS line clamps
    - Powder coated gray finish
    Notes:
    These arms are designed to be used with stock unmodified spindles or Camburg performance lift spindles in conjunction with an approved 2"-3" lift bolt-in coilover. They were not designed to be used in conjunction with other suspension kits or spacer type kits.
    Maximum wheel backspacing = 4.50"
  12. May 20, 2010 at 5:59 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    ive got perfect alignment with my camburg uniball ucas, no squeeks at all i lube them all the time and take good care of em for the most part
    Somebody Else and Sicyota04 like this.
  13. May 20, 2010 at 11:00 PM
    dezert taco
    dezert taco Well-Known Member
    central valley
    J arm longtravel full fiberglass
    it has a J-arm longtravel front end fiberglass fenders hood and bedsides engine cage been rolled need to replace roof
    TC all the way wish i would have stayed with the TC kit i had but i J armed my truck. TC for sure!!!!
  14. Sep 20, 2016 at 6:18 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    Bump just cause.
  15. Sep 20, 2016 at 6:36 PM
    bigl110
    bigl110 Well-Known Member
    Laurence
    Virginia
    2018 dcsb sr Barcelona red 4x4
  16. Sep 21, 2016 at 10:42 AM
    JT@Bajakits
    JT@Bajakits Well-Known Member Vendor
    JT
    Race Trucks and Off Road Suspension
    Ours!! :D
    Justinlhc likes this.
  17. Sep 25, 2016 at 6:45 PM
    WendyTaco
    WendyTaco Well-Known Member
    Kyler
    2017 TRD Off-Road
    Those control arms are sexy :drool: but being in Florida where most of my off-roading is mud, I've decided when I upgrade I'll be going with Camburgs ball joint UCA's.
  18. Sep 25, 2016 at 6:59 PM
    SoCOTaco
    SoCOTaco Well-Known Moron
    Mitchell
    Lakewood, CO
    2012 Tacoma TRD Off Road 4X4
    GFC, Fox 2.0's w/ Dakars, SCS BR6's, Fridge w/ Beer
    I'm really looking to get the Light Racing ones (for cost effectiveness), but all the talk I hear is about is TC. Are they really that much better? My style is more high speed smooth stuff and sand/slickrock over rock crawling. Will the Light Racing ones be "good enough"? (Dangerous words, I know.)
  19. Sep 26, 2016 at 9:07 AM
    JT@Bajakits
    JT
    TC has been around for a while. They make a great product but it is a little outdated.
    We designed our boxed UCA the same way we designed our Trophy Truck suspension!
    They are stronger and look a lot better than a bent tube UCA.
    In the end, it really comes down to how much you are looking to spend.
  20. Sep 28, 2016 at 9:07 AM
    TRD493
    TRD493 Well-Known Member
    Dave
    Texas (DFW)
    17 TRD Sport DCLB 4x4 / 01 4x4 V6 Extra Cab TRD SR5
    Don't see UCA's for 2016 Tacoma on your site.....How much?
