TOTAL CHAOS Long Travel *Discussion Thread*
Discussion in 'TOTAL CHAOS' started by TOTAL CHAOS, Oct 2, 2018.
  1. Dec 13, 2018 at 6:33 AM
    TrapComa
    TrapComa Well-Known Member
    Mason
    Cedar Park, TX
    07 Indigo Ink LT PreRunner
    Wannabe prerunner, wannabe overlander
    Offroad Warehouse is who I buy all of my stuff from. They’re salesman named Mike is a great guy. I got my LT kit, cam tab gussets and UCAs, on top of a handful of other non TC things
  2. Apr 29, 2019 at 3:57 PM
    TOTAL CHAOS
    TOTAL CHAOS [OP] WWW.CHAOSFAB.COM Vendor
    Corona, CA
    "Back in 2012 I took a gamble on a company buying a long travel kit for my 2005 Tacoma that I knew very little about. 2019 is here an that same Long travel kit is still kicking! It's not quite as pretty but I can assure you it's just as functional. Nearly 100,000 miles and close to 60 Wheeling trips later I can say I have never been more satisfied with the durability, dependability, support, and passion of an offroad manufacturer. Thx to TC for all they do. Keep bringing the Chaos!"⁣
    @NickKinzie - Cincinnati Ohio⁣
    [​IMG][​IMG]
    MurkedYota likes this.
  3. May 19, 2019 at 1:29 AM
    taco_tallua
    taco_tallua MEGA-Known Member
    Anaheim, CA
    2016 MEGA Toyota Tacoma
    I'm here for the memes
    Are the travel numbers for your kits on your website for 4wd? If so, considering I am 2wd I don’t have the limiting factor of a axle so technically I would be able to get more travel out of your +2 or +3.5 kit?
  4. May 19, 2019 at 1:47 AM
    Bot_Chu
    Bot_Chu Du Ma
    Nate (Bot)
    Corona, Ca
    2007 ACLB Prerunner
    Enkei RPT-1, ADS 2.5 F/R, 4" Spindles, Toyo RT 315/75/16
    Bruh buy one already
  5. May 21, 2019 at 5:07 PM
    TOTAL CHAOS
    Corona, CA
    The travel numbers listed will be the same for both 2WD and 4WD systems. It's possible you can squeeze a little more out of a 2WD system but you have to keep an eye out for the upper misalignment spacer clearance. We recommend 1/4" clearance between the upper misalignment spacer and uniball cup for both 2WD and 4WD models
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
  6. Jun 25, 2019 at 2:37 PM
    TOTAL CHAOS
    Corona, CA
    65428233_3038909506149577_23048821090654_d4b93078ee50ecd3eb0d318687db4e48c89982d6.jpg
    The difference is in the details
    At TC we are committed to customer service.
    Designed for performance. Built to last.
    We put extra effort into every process when we build our parts for you. ⁣
    Learn more at www.chaosfab.com
    ⁣#MadeintheUSA :oldglory:
    65061415_3038909602816234_23463321641292_5bd443c6cc572002f90a5de869170f41dbe11191.jpg
    65652505_3038909769482884_75862480268096_d04dc47088e8ed59ed6a713b33f440bda7b43437.jpg
    65217399_3038909792816215_90054013470711_4a478f9a6bfa91340b95aed558faf68e1f014745.jpg
  7. Aug 5, 2019 at 11:44 AM
    TOTAL CHAOS
    Corona, CA
  8. Aug 6, 2019 at 1:51 PM
    Kauai Quicksand
    Kauai Quicksand Active Member
    2016 Quicksand
    Total Chaos +2 LT King 2.5 shocks King 2.0 Bump stops Old Man Emu leafs ARB lockers front and rear 4:88 Nitro Gears BAMF aluminum economy grille FN fx Pro wheels 285x70x17 Toyo open country m/t Winjet Automotive tail lights Morimoto XB LED headlights Morimoto XB LED fogs MesoCustoms ultimate turn signals MesoCustoms dome/map lights
  9. Aug 28, 2019 at 11:37 AM
    TOTAL CHAOS
    Corona, CA
    Supercharged Urban Lexus rocking a +3.5" TOTAL CHAOS Long Travel System
    What do you think?
    : (IG)snoopy_gx470
    69281766_3210637355643457_53299849303550_34c6767ae4d3a09696ea7890cae94d4547a55e60.jpg
    69368375_3210637508976775_53216329841959_e516a059b19f6d003de38fa6e99013e1bd8393d7.jpg
    69939753_3210637408976785_87505996548669_2d5ce4abf1c366e0d6509effe1ee1c110c452d33.jpg
    69027820_3210637552310104_76659746328469_8b6117809d4b5a058e5365d007c9b978d72d4850.jpg
  10. Aug 28, 2019 at 11:49 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    All I want for Christmas is a TC kit. The end.
  11. Aug 28, 2019 at 11:53 AM
    TOTAL CHAOS
    Corona, CA
    :santa:
    ChadsPride[QUOTED] likes this.
  12. Aug 28, 2019 at 11:55 AM
    ChadsPride
    :eek: :goingcrazy:
  13. Sep 19, 2019 at 11:38 AM
    TOTAL CHAOS
    Corona, CA
    Long Travel T4R Photobombed!
    69696074_3273473502693175_29364008202304_bd1bc349cabe7d86af8950793b9c8dea4517ae5a.jpg
    Post up some shots of your ride. Comment below If you have any questions on our suspension systems
    ChadsPride likes this.
  14. Sep 22, 2019 at 9:59 PM
    Texastaco2010
    Texastaco2010 Well-Known Member
    2010 TRD Tacoma
    Question guys is it necessary for me to have sway bar relocation brackets for my 2010 Tacoma? I have y’all +2 long travel kit with y’alls sway bar. Right now it’s at the stock location.
  15. Oct 4, 2019 at 5:40 AM
    #35
    Tretiak30
    Tretiak30 Well-Known Member
    Roman
    Cleveland, Ohio
    THE Ohioan.
    neo-garage.com
    It's here!!!
    TC has been working on an expedition version of their +2 LT kit, and it's finally here!!
    https://www.chaosfab.com/2016+-Taco...s-Long-Travel-Suspension-Kit-86222T-E-16.html
    I've got all the info at my disposal, so if you have any questions please feel free to reach out.
    • The 2” Expedition Series kit features a redesigned lower control arm serving as an evolution of the Race Series LCA’s with select features to improve component strength, function and vehicle handling.
    • A newly integrated steering stop tab retains the factory turning angle with no modification necessary to the OEM ball joint cradles.
    • Billet CNC machined uniball cup ends extend into the arm providing more turning clearance and increased strength.
    • Upper and lower ball joints are replaced with 1" uniballs for maximum wheel travel. TOTAL CHAOS 1" I.D. uniballs feature a heat treated stainless steel ball & race for superior corrosion resistance and component strength. A military grade PTFE woven fabric liner surrounds the uniball which helps prevent noise and debris buildup.
    • Extended 4130 chromoly upper and lower control arms increase track width 2” per side and bolt to factory control arm mounting locations yielding 11.5” of travel.
    • Upper and lower control arms utilize urethane bushings and steel inner sleeves which greatly reduce bushing deflection compared to stock rubber bushings.
    • Lower controls arms come pre-tabbed for a secondary external bypass shock which can be installed to increase dampening and tunability.
    • Different spring rate options offer the ability to customize your ride for your specific application allowing you to custom tune the vehicle for specific terrain or desired performance.
    • Adjustable limit strap clevises are included to properly limit suspension droop wheel travel and allow necessary adjustments during the life of the limit strap.
    • Kit includes DOT approved stainless steel braided brake lines, TC custom 17-4 stainless hi-misalignment spacers and all necessary Grade 8 mounting hardware.
    • TC 4340 custom extended axles reuse factory inner and outer CV's to retain 4wd (axles are sold separately and not included with the kit).
    Everything else is identical to the race kits, just beefed up to a whole new level and those few features added to make the kit that much better.
    These are now in stock and ready to ship, so if you'd like to order and get the best LT kit on the market right now, please reach out. I'll be happy to put together a nice package deal with shocks/bypasses and everything needed to make this kit fit.
    https://www.**********.com/collecti...tal-chaos-expedition-series-2-long-travel-kit
  16. Oct 5, 2019 at 11:57 AM
    #36
    soggyBottom
    soggyBottom Well-Known Member
    I'm trying to price out all the parts but I'm not 100% I have everything. What is the bare minimum for the LT conversion?
    - LT Kit (LCA, UCA, etc.)
    - extended axle shafts
    - coilovers
    did I miss anything?
  17. Oct 5, 2019 at 12:15 PM
    #37
    Tretiak30
    Roman
    Cleveland, Ohio
    THE Ohioan.
    neo-garage.com
    That, and spindle gussets, cam tab gussets would be a very good idea while everything's already apart.
    Shoot me a PM, I can hook you up with a killer deal on most kits out there! Especially Camburg or TC.
    TOTAL CHAOS[OP] and Coot83 like this.
  18. Jun 2, 2020 at 7:25 AM
    #38
    TOTAL CHAOS
    Corona, CA
  19. Jun 2, 2020 at 7:53 AM
    #39
    ChadsPride
  20. Sep 13, 2020 at 8:08 PM
    #40
    Jguardino
    Jguardino Well-Known Member
    jacob
    209
    01 Dbl cab, 22 TRD OR PREM
    Thinking strongly about buying for My 2001 taco. Any difference between the boxed or tubular kit, is one better structurally than the other?
