Total Chaos Long Travel Kits - King or Fox shocks
Discussion in 'AccuTune Offroad' started by AccuTune Offroad, Mar 13, 2020.
  1. Mar 13, 2020 at 3:54 PM
    AccuTune Offroad
    AccuTune Offroad [OP] Well-Known Member Vendor
    El Cajon, CA
    **NOW AVAILABLE**
    Total Chaos Long Travel kits paired with custom tuned Fox or King shocks can be the ultimate upgrade for your 2005+ 2WD/4WD Toyota Tacomas. Kits available come as a +2" or +3.5" wide (on each side) and can be upgraded with a bypass shock for more performance.
    Click below for more details or comment below with questions!
    uploadadventure and whatstcp like this.
  2. May 3, 2020 at 11:18 AM
    Loco_Barbon
    Loco_Barbon Just deez nutz hangin’ out
    Hugh Mungus
    Where ever my 10mm isn’t
    i LiKe tRuCkS!!
    Penis valve stem caps.
    Does the +2 Expedition kit use the same coilovers and tune as your 4A King kit?? If so do you offer the kit less the parts in the 4A kit?
  3. May 4, 2020 at 9:01 AM
    AccuTune Offroad
    El Cajon, CA
    No, all of the Long Travel Kits use a longer coilover than what is used in the Mid Travel Kits. We tune each shock specifically for the suspension kit, weight of truck, driving style etc. They are all different. Not sure what you mean by "kit less the parts in the 4A kit"
  4. May 4, 2020 at 11:30 AM
    Loco_Barbon
    Hugh Mungus
    i LiKe tRuCkS!!
    I purchased and installed your King A4 kit a few months ago before you offered the long travel. I was hoping that the coilovers were the same so I could get the long travel kit without the coilovers, reservoir brackets, ect.
  5. May 4, 2020 at 12:02 PM
    AccuTune Offroad
    El Cajon, CA
    I see. No unfortunately for long travel setup, you need a shock with more travel and wider mounting points on the lower control arms. In addition to that, if your Tacoma is 4wd, you will need extended length axle shafts.
  6. May 4, 2020 at 12:06 PM
    Loco_Barbon
    Hugh Mungus
    i LiKe tRuCkS!!
    Understood, looks like the long travel might have to wait a few extra months. Thanks for the info.
    AccuTune Offroad[OP] likes this.
  7. Mar 30, 2022 at 4:47 PM
    roguegs
    roguegs Well-Known Member
    Angelo
    V8 T4R
    Went from 3rd Gen Taco to 3GT4R to 2nd Gen Taco and finally a V8 4GT4R.
    Stumbled across someone selling fox coilovers from their 3.5" TC Kit. Would I be able to run the same coilovers on a +2 LT kit? Not sure if there's internal valving differences, etc.
  8. Apr 13, 2022 at 3:22 PM
    AccuTune Offroad
    El Cajon, CA
    Wow sorry never saw the notification for this.
    +2" and +3.5" use the same coilover. Valving would likely be very similar. Are they tuned from us?
  9. Feb 24, 2025 at 12:00 AM
    Carloss1017
    Carloss1017 Well-Known Member
    Carlos
    SoCal
    95.5 Tacoma 4wd 2.7L
    Do you guys have king shocks for 1st gen Tacoma long travel kit
  10. Feb 24, 2025 at 10:01 AM
    AccuTune Offroad
    El Cajon, CA
    Looks like we have 1 set on order that has not been claimed yet. If you want to claim that set before they arrive we can certainly do that. Just give our sales team a call or send over an email referencing this part number: TC5151-03
    619-722-8555 or Sales@AccuTuneOffroad.com
