Total Chaos Spindle Help
Discussion in 'Suspension' started by devil01, May 17, 2009.
  1. May 17, 2009 at 8:49 PM
    devil01
    devil01 [OP] Active Member
    SOCAL
    08 TRD Sport DC
    5 pc blk billet grille, Pioneer Premier Avic F90bt, Icon UCA's, Icon Rem. Res Coilovers, Icon Rem. Res rear shocks, TC Spindles, Deaver J-66's, Light Racing Front and Rear Jounce Shocks
    So, ive had a bunch of brand new suspension stuff sitting in my living room for the past 2 months. Haven't had much time to install anything so no pics yet :mad:. I got remote reservoir coilovers, remote res rear shocks, and UCA's from Icon. got a set of deaver J66's, front and rear jounce shocks from light racing, and finally the 3" lift spindles from total chaos. I was wondering if anybody installed the spindles themselves, and how the install went. How did you swap the bearings over? how hard was the work? any help let me know!
  2. May 17, 2009 at 8:51 PM
    Rippin101
    Rippin101 Well-Known Member
    Jax Beach, FL
    2014 TRD Sport 4x4
    -Nitto G2 265/70/17 -Level 8 MK6 Wheels -Katzkin Leather Black on Black -BHLM -Weathertech -Extang Solid Fold -Bedlight LEDs -TRD Skid
    I haven't done it myself but I know that 06Bluez installed some Allied spindles on his Prerunner recently, maybe he'll chime in :D
    He said it definitely wasn't easy and that it took quite a few hours! ;)
  3. May 17, 2009 at 8:54 PM
    devil01
    SOCAL
    08 TRD Sport DC
    cool, maybe he has pics.
  4. May 17, 2009 at 8:57 PM
    Rippin101
    Jax Beach, FL
    2014 TRD Sport 4x4
    Ya I dont think he has any of the install but he does have after pictures and it looks so good! :cool:
  5. May 17, 2009 at 8:59 PM
    devil01
    SOCAL
    08 TRD Sport DC
    yeah, just checked, it looks good. cant wait to get my setup done.
  6. May 17, 2009 at 9:01 PM
    devil01
    SOCAL
    08 TRD Sport DC
    i know downsouth has them, but he never responded to the PM's i sent a while ago. It kinda made up my mind to buy em from ORW instead of downsouth motorsports.
  7. May 17, 2009 at 11:15 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    where are they at on the website? I cant find them...
  8. May 17, 2009 at 11:18 PM
    jdkeller
    Jonathan
    Inland Empire, Ca
    Nevermind i found them.
  9. Jul 19, 2009 at 7:34 PM
    devil01
    SOCAL
    08 TRD Sport DC
    Well, finally got everything installed on my truck, tookit off jacks, and son of a bitch! my stock 17" wheels were rubbing my brand new TC spindles. WTF!?! The instructions have a warning that 1/4" spacers are required for 16" stock rims, not 17" rims. Anyone know what wheels and what backspacing I need to clear the spindles?
  10. Jul 19, 2009 at 7:35 PM
    devil01
    SOCAL
    08 TRD Sport DC
    Oh Yeah, ill have pics up when I fix the rubbing issue.
  11. Jul 19, 2009 at 7:42 PM
    devil01
    SOCAL
    08 TRD Sport DC
    anyone????? already looked thru the backspacing forums, didnt find what I was looking for. Looked to see who else was running the TC spindles, no luck.
  12. Jul 19, 2009 at 7:45 PM
    Kenny650
    Kenny650 Well-Known Member
    I am about to run Camburg Spindles. I have 5 inches of backspacing on my current wheel setup but I bought the Spidertrax wheel spacers so I can clear the spindle. BTW...how hard was the install for the spindles?
  13. Jul 19, 2009 at 7:46 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You may have to get wheels with a different BS. Maybe some woth a 5" BS or less.
  14. Jul 19, 2009 at 7:48 PM
    Kenny650
    Any wheels under 4.75 inches of backspacing can clear the spindles but I would recommend just getting the spacers...
  15. Jul 19, 2009 at 7:54 PM
    devil01
    SOCAL
    08 TRD Sport DC
    Kenny, the spindles werent too bad to install, it goes a lot smoother and faster if you have a couple of people to help. you dont even need to press/pull anything. I suggest leaving the spindles on while taking off the 4 bolts that hold the hub bearing to the spindle. Use a screwdriver and hammer to pop it out. then attach the new spindle to the lower control arm, and then you use the four bolts to tighten the hub back down, and it will seat itself. you may need to grind the calipers to get the attatch points to line up.
  16. Jul 19, 2009 at 7:56 PM
    devil01
    SOCAL
    08 TRD Sport DC
    Im kind of skeptical about the spacers, because I plan on beating up the truck a little in the desert, and dont want the added sress to the hubs. I will look 2morrow for wheels with less than 4.75" BS, If I cant find any within my budget, I guess I will go with the spacers.
  17. Jul 19, 2009 at 7:57 PM
    Kenny650
    Did you add new extended brake lines?
  18. Jul 19, 2009 at 8:01 PM
    devil01
    SOCAL
    08 TRD Sport DC
    yup, brand new steel braided lines, they came with the spindles. The only hard part about those is when you disconnect the upper hard line from the rubber line, there is a flare, so all of the threads will be backed out, and you will have to pry (hard as hell) to get the flare out of the old rubber brake line. then you're home free. on the TC spindles, most of the brackets get tossed, so it makes it easier to get everything done.
  19. Jul 19, 2009 at 8:13 PM
    bermise
    bermise Well-Known Member
    Houston
    08 TRD off road
    Total chaos spindles, Total chaos heim joint uca's, Icon E/T coilovers, Icon reservoir shocks, custom Deaver 10 leaf pack, 285/70/17 Cooper STT
    My last two sets of wheels have been 17X9, -12mm offset and 4.5 inch backspace and I have had no rubbing issues and did not need spacers.
  20. Jul 19, 2009 at 8:15 PM
    devil01
    SOCAL
    08 TRD Sport DC
    Well, thanks guys, I appreciate the input. I found bermise, he has the TC spindles, and has 4.5" BS and runs a 12 mm offset on a 17" rim. I guess the stock rims on a Sport has 5" of BS, so no wonder why Im grinding the wheels against the spindles. Kenny, let me know if you need any more advice with the install. hope it goes smoothly, Its gonna b sick as hell.
