TOTAL CHAOS - Stock Length Lower Control Arm (LCA) - Should I upgrade?
Discussion in 'Suspension' started by TOTAL CHAOS, Jul 9, 2018.
  1. Jul 9, 2018 at 10:13 AM
    TOTAL CHAOS
    TOTAL CHAOS [OP] WWW.CHAOSFAB.COM Vendor
    Corona, CA
    At TOTAL CHAOS we offer stock length replacement Lower Control Arms for a variety of vehicles. These are available in Standard and Race Series with single and dual shock offerings.
    Standard - Stock Length Lower Control Arm
    • 3/16" main body stock length fully boxed lower control arms are CNC laser cut and include internal gussets.
    • Boxed arms feature replaceable urethane pivot bushings. Pivots include zerk fitting to maintain the equipment while bolted on the vehicle.
    • 1/4" thick steel skid plate is integrated into the control arm for rock crawling protection.
    • Features a billet machined uniball adapter. Lower ball joints are upgraded to a 1" stainless steel uniball for maximum wheel travel and added component strength.
    • Dual shock capable or Jounce Shock compatible.
    • Weld-on bump stop spacers are included.
    • *These arms will not fit on Hilux Revo or vehicles equipped with KDSS
    • *Not compatible with shocks with bushing lower rod ends.
    Race Series - Stock Length Lower Control Arm (Single Shock)
    • Racer inspired and constructed from 100% laser cut 4130 chromoly.
    • The lightest weight bolt on lower arms @ 16.5 pounds.
    • Maximizes vehicle ground clearance with integrated lower uniball cup.
    • Single shock tab mounts do not require wheel spacers to be installed.
    • 1" 100% stainless steel uniball replaces factory lower ball joints.
    • Replaceable polyurethane pivot bushings include zerk fittings for easy maintenance.
    • The lightest weight bolt on lower arm @ 16.5 pounds.
    • Dual 2.5 shock capability provides maximum dampening control.
    • *1.25" wheel spacers are required.
    Toyota Tacoma
    (2016-2018)
    Standard - Race Series (Single Shock) - Race Series
    (2005-2015)
    Toyota 4Runner
    (2010-2018)
    *** KDSS Compatible ***
    Race Series (Single Shock) KDSS - Race Series KDSS
    (2003-2009)
    Toyota FJ Cruiser
    (2010-2017)
    (2007-2009)
    Lexus GX460
    (2010-2017)
    Lexus GX470
    (2003-2009)
    Toyota Tundra
    (2007-2018)
    Race Series
    Toyota LandCruiser 200 Series
    (2008-2017)
    Race Series
    Not sure if you should upgrade?
    Please take a look at the following posts for more information on TOTAL CHAOS Lower Control Arms. Comment below if you have any questions.
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
  2. Jul 9, 2018 at 10:16 AM
    TOTAL CHAOS
    Corona, CA
  3. Jul 12, 2018 at 9:50 AM
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    @TOTAL CHAOS - So I have Icon Secondary shocks with their hoops and lower control arm skid plates already. Would these be a direct bolt on for me?
    Icon has a steering stop spacer that gets welded on to the stock LCA to basically limit the range of the steering to prevent the brake line from contacting the shock. Do you know if this would be an issue?
    Taco_dak likes this.
  4. Jul 12, 2018 at 2:27 PM
    TOTAL CHAOS
    Corona, CA
    You may have to purchase the TOTAL CHAOS Shock Hoops. The geometry and spacing is different between our setup and theirs. The bypass might not line up with the mount on our arm when running their hoop. Our hoops were designed specifically for this setup.
    The Icon steering stop that gets welded to the factory arm will NOT be an issue since you're removing the factory arms. TOTAL CHAOS arms do require trimming the steering stops off the ball joint cradle. Here are the installation instructions showing this modification:
    Installation Instructions
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
  5. Jul 12, 2018 at 2:56 PM
    Metallikatz3
    SLC, UT
    2017 DCLB OR
    Always in process
    Thanks for the detailed answer!!
  6. Jul 15, 2018 at 10:02 AM
    Sandia Labs
    Sandia Labs Well-Known Member
    Colorado via Brawley, CA
    Clazzio all around, ARE topper, Total Chaos bed stiffeners, Tacoma bed mat, Weather tech floor mats, Cab mount chop
    Can a limit strap set-up be welded to the Total Chaos lower control arms?? If so, do you have pics of it being done?
    Thanks!
  7. Jul 15, 2018 at 10:04 AM
    Prayn4surf
    Prayn4surf 20 minutes late
    Socal
    2004 Tacoma xtra cab
    Any chance of a 1st gen stock length LCA?
    agunday21 and eccracer104 like this.
  8. Jul 17, 2018 at 8:56 AM
    TOTAL CHAOS
    Corona, CA
    There are a few different ways of setting up limit straps, welding isn't a requirement. Here is one customer setup:
    19274840_10207310691164608_8248941180553_c707574bb50c9dec4ce03797bf11685b11f9d014.jpg
    mcharfauros and BassAckwards like this.
  9. Jul 17, 2018 at 9:00 AM
    TOTAL CHAOS
    Corona, CA
    Right now there is discussion in the R&D department. We'll post up as the discussion moves along
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
  10. Jul 19, 2018 at 2:30 PM
    Seabass
    Seabass Give it to me. I'll break it for you
    Adam
    AZ
    '06 Sport 4x4
    Just a bunch of old crap
    Got the dual shock LCAs for my 06. Are the 1.25" wheel spacers truly required if I have 16x8 wheels with 0 offset due to that second shock mount? I got the dual shock arms because they were the same cost as the singles and singles were out of stock at my shop. I hate wheel spacers, tbh. I'll likely never go dual shock, so could I just cut off the second shock mounts and avoid spacers?
  11. Jul 19, 2018 at 9:32 PM
    Sandia Labs
    Awesome!!! I love it! Do you have pictures of the setup on a Tacoma? I understand the FJ and Tacoma are similar, just want to see it on a Taco. Also, what is the length of the limit strap in this picture? For future pics can you please, please included the strap length. Thanks so much in advance!
  12. Jul 23, 2018 at 12:14 AM
    Seabass
    Adam
    AZ
    '06 Sport 4x4
    Bump @TOTAL CHAOS
  13. Jul 23, 2018 at 10:25 AM
    TOTAL CHAOS
    Corona, CA
    Sorry about the delay - we were at FJ Summit in Ouray, CO.
    We can't guarantee your setup will NOT require wheel spacers. The spacing will be close based on the info we have. If anything you might need a small wheel spacer like 3/4".
    Have they been installed? Is your shop an Authorized TC Dealer? It would be best to return/exchange them for a Single Shock LCA (Contact Us). I personally wouldn't cut the tabs off a new set of arms.
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
  14. Jul 23, 2018 at 10:33 AM
    TOTAL CHAOS
    Corona, CA
    Limit Straps are NOT required on this setup, so our photos are limited, but as we get more pics of our LCA's I'll post!
    I believe it was a 13" strap, but am not 100% certain. Unfortunately I don't have all of the specs on this customer install. He just sent us some photos :)
    Using an adjustable limit strap clevis will allow for easy adjustment of the strap. You don't have to be 100% precise with tab placement or strap length. It can all be fine tuned.
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
  15. Jul 23, 2018 at 10:53 AM
    Seabass
    Adam
    AZ
    '06 Sport 4x4
    I decided to go with getting some 1.25" Spidertrax spacers as a "just in case". They haven't been installed yet so I'll find out, once installed, if they are needed or not. I'm not going to take any chances with close clearances so I'll expect to need the spacers. I would exchange them for the single shock model but I may actually want to go dual shock at some point so I won't be cutting off the other tabs. Thanks for getting back to me.
  16. Jul 23, 2018 at 10:59 AM
    oni06
    oni06 Well-Known Member
    I just want to share the love.
    Back in Jan I bent my Spindle and LCA while wheeling.
    Contacted Jason (@glorifiedwelder) and he hooked me up with the following setup and I love it.
    New spindles with TC Gussets
    TC Cam Tab Gussets
    TC Upper Control Arms
    TC Lower Control Arms
  17. Jul 23, 2018 at 11:39 AM
    TOTAL CHAOS
    Corona, CA
    Beautiful! Glad you're out enjoying the TOTAL CHAOS parts :)
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
    oni06[QUOTED] likes this.
  18. Jul 25, 2018 at 9:53 AM
    Sandia Labs
    Awesome!! I'll be waiting on some additional pictures. Thank you so much for responding. It truly means a lot.
  19. Jul 29, 2018 at 9:12 AM
    RS874903
    RS874903 Well-Known Member
    Ohio
    4x4 Tacoma 4L V6 Pyrite Mica
    Hey @TOTAL CHAOS,
    I order some replacement bushings for my LCAs, but they didn’t come with the inner sleeves. Mine are a wee FUBARed. Looks as if they’ve been wearing on the inside of the LCA mounts. Do you all have the metal sleeves or do I need to source them somewhere else? If so can I get the specs on them? Thanks
  20. Jul 30, 2018 at 4:15 PM
    TOTAL CHAOS
    Corona, CA
    We carry all replacement parts for our gear. Give us a shout and we'll set you up!
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
    Sandia Labs and oni06 like this.
