TOTAL CHAOS - Stock Length Lower Control Arm (LCA) - Should I upgrade?
Discussion in 'Suspension' started by TOTAL CHAOS, Jul 9, 2018.
  1. Oct 5, 2020 at 1:21 PM
    #161
    TOTAL CHAOS
    TOTAL CHAOS [OP] WWW.CHAOSFAB.COM Vendor
    Corona, CA
    While Dirt king makes a good LCA there are things what we believe set us apart from their LCA’s and one our mottos is “often imitated, never duplicated”. The TOTAL CHAOS 86555 is made 100% of 4130 material which is stronger than the mild steel that most companies use. When using mild steel its necessary to use a thicker material which makes the arm heavier, when using 4130 the arm is lighter without compromising strength. When it comes to the pivots, TC uses 2 ¼” material which allows for larger polyurethane bushings as well as larger diameter inner sleeves which make a stronger clamping force on the frame so the alignment stays put off-road. TC uses polyurethane bushings which allow for minimal flex off-road, but still offers a slight cushion when it comes to shock load to the frame. Poly will squeak if not maintained but Dirt King uses Delrin which is very strong, but will eventually have a very loud groan when the suspension is cycled, Delrin also transfers more load to the frame instead of absorbing it. At TC we believe if you aren’t making things better, its not worth modifying the factory parts. Dirt king uses a Moog ball joint which is no stronger than the stock ball joint, and cannot withstand the abuse that a 1” uniball can handle. For some reason, Dirt King uses spacers between the lower ball joint cradle and the steering knuckle. This changes the factory geometry and makes it necessary to use bolts that aren’t flanged or designed for that application. This is by no means meant to disrespect Dirt King since they do make a good product; We just wanted to inform you of the differences and why we thing we make a superior product.
    NYCO, Bertw192, Kronk21 and 5 others like this.
  2. Oct 5, 2020 at 1:22 PM
    #162
    TOTAL CHAOS
    Corona, CA
    Do you have a link to the All Pro kit?
  3. Oct 5, 2020 at 1:48 PM
    #163
    igiman
    igiman Well-Known Member
    Cali
    To much to list
    Im sorry PRO COMP 6” lift kit
  4. Oct 13, 2020 at 1:52 PM
    #164
    KrnTaco08
    KrnTaco08 Well-Known Member
    LA
    2017 Taco
    @TOTAL CHAOS anyone running bypass shocks with the stock length lower? Basically a true mid travel Tacoma. Thanks
  5. Oct 21, 2020 at 7:27 AM
    #165
    TOTAL CHAOS
    Corona, CA
    Yep! it's a good setup
    KrnTaco08[QUOTED] likes this.
  6. Dec 12, 2020 at 11:06 PM
    #166
    Chapman
    Chapman Well-Known Member
    Bay Area, CA
    2013 SW DCLB TRD Sport 4x4
    Which bypass shocks will work with the expedition stock length lowers? I think I'm going to stay mid travel.
    KrnTaco08 likes this.
  7. Dec 16, 2020 at 7:09 AM
    #167
    TOTAL CHAOS
    Corona, CA
    King Part # TC1119-25
    FOX Part # 982-02-952
  8. Dec 16, 2020 at 3:17 PM
    #168
    KrnTaco08
    LA
    2017 Taco
    you have them in stock?
  9. Dec 16, 2020 at 5:31 PM
    #169
    TOTAL CHAOS
    Corona, CA
    contact our sales team tomorrow, they will let you know.
    info@chaosfab.com
  10. Dec 16, 2020 at 7:41 PM
    #170
    KrnTaco08
    LA
    2017 Taco
    Ok will do. Thx
  11. Dec 25, 2020 at 1:09 PM
    #171
    Dalegribble02
    Dalegribble02 Well-Known Member
    Savona British Columbia
    2014 SR5 4x4 meg grey sold
    Dobinson mrrs Deaver leafs archive garage hammer hangers.
    Wanting the expidtion series. Is it worth it over oem lcas?
  12. May 3, 2021 at 5:07 PM
    #172
    Blkturbo!
    Blkturbo! Well-Known Member
    Sean
    Henderson, NV
    08 Tacoma; 05 Seadoo RXP; 94 Turbo Supra
    Icon Coilovers, Downsouth UCAs, rear Icon "2.5" shocks and Toytec single AAL. Still gotta do exhaust, dark headlights and re-gear the rear diff.
    Useless post/bump:
    :eek::eek: $$$$$$$:eek::eek:
    Well, I suppose my only realistic option for cost/quality balance is to simply buy new LCAs from Toyota o_O (daily driver + occasional light off-roading on desert washboard trails)
  13. Jul 3, 2021 at 5:06 PM
    #173
    20’TacoRoss
    20’TacoRoss Well-Known Member
    20’ Cement Tacoma TRD sport manual
    @TOTAL CHAOS
    Im planning out stage 2 for my taco. I am planning on going with relations race wheels RR5 monoblocks accompanied with your stock length lower and upper arms and single fox coilovers. Whats the biggest tire size i could go with and not rub while keeping great off road functionality before i have to cut the cab mounts?
  14. Jul 20, 2021 at 7:07 AM
    #174
    TOTAL CHAOS
    Corona, CA
    Any size bigger than stock is going to rub somewhere. a 265 should fit with some minor plastic clearing. you can run a 285 w/ our body chop kit.
  15. Jul 20, 2021 at 8:14 AM
    #175
    Blkturbo!
    Sean
    Henderson, NV
    I’m not sure how much different the dimensions are on the new Tacos as compared to my ‘08, but I have a 2.5in lift with 18x9 wheels on 4.5in backspace.
    With that, I’ve used 2 sets of 285/65/18 Nitto Trail Grapplers with very minimal cab mount rubbing at full turn.
    Now I’m using 285/60/18 Ridge Grapplers and with only a slight change in sidewall % on that model tire, I’ve got tons of room all around inner and outer shoulders of the tires.
  16. Feb 15, 2022 at 5:07 PM
    #176
    NCTaco4
    NCTaco4 Member
    Kevin
    Denver, CO
    2012 Tacoma PreRunner TRD Sport
    6 in Bilstien lift, Total Chaos UCAs, Alcan Leafs, Supercharged
    Hey @Seabass did you every find that these bound up? or did it end up clearing long term?
  17. Mar 9, 2022 at 9:58 AM
    #177
    Seabass
    Seabass Give it to me. I'll break it for you
    Adam
    AZ
    '06 Sport 4x4
    Just a bunch of old crap
    Still clearing just fine. No signs of binding or rubbing on anything. All shock paint is still untouched, and never had an issue on or offroad.
  18. Feb 15, 2023 at 9:17 PM
    #178
    machineman89
    machineman89 Well-Known Member
    Matthew
    San Leandro
    overlanding limo in progress :-P
    Weather tech floor mats, fog light any time mod, derped front embelem, Pelfretbilt 3 hoop plate bumper, 10k warn xeon winch-s some leds, pelfreybilt roof rack, scs stealth series rims, wrangler authority tires, BAMF 96" bolt on sliders, BAMF dif skid, some dirt....
    @TOTAL CHAOS what kind of life do the uni-balls on the lowers generally get? I'm replacing my stock lowers with these and they prolly have a 140k miles on my stock ball joints n arms.
  19. Feb 15, 2023 at 9:38 PM
    #179
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Definitely less than that! All these shiny stock length arms are a total waste of money! They just look nice, that’s all. Most don’t even have limit strap tabs. For a fraction of what they cost you can reinforce the stock ones where it matters and add sealed uniball frame pivots, which would actually be an improvement that none of these fab companies offer. Well, JDFab does, but they don’t offer stock length LCA…. On a stock length set up you’ll never be able to use the greater articulation potential of a uniball. It’s just a PITA with “benefits” you can’t use.
  20. Feb 16, 2023 at 12:27 PM
    #180
    TOTAL CHAOS
    Corona, CA
    Mileage is going to depend on a lot of variables but if you take care of them you should get 30,000-45,000 miles out of them. Yes they don't typically last as long as ball joints but they are also stronger than ball joints and much easier to maintain/replace.
    Obviously some others don't feel stock lowers are worth it but our Stock Expedition lowers add strength, easier to maintain than stock LCAs, allow a ton of shock options to be used, retain factory turning angles, and you get great customer service and support from Total Chaos.
    Bertw192 likes this.
