Total chaos UCA bent bolts
Discussion in '2nd Gen. Tacomas (2005-2015)' started by klikboom, May 1, 2016.
  1. May 1, 2016 at 5:33 PM
    klikboom
    klikboom [OP] Well-Known Member
    SNOHOCO
    Taco
    I was doing a front end overhaul and found both bolts that attach the UCa to the knuckle bent. Also I swapped out knuckles as part of the refresh and the lower spacer from total chaos was totally seized in the knuckle. So.... I'll be calling total chaos Monday to try to get some new spacers / bolts. Are any of the other UCA designs better for this sort of load. Ie 1.25" uniballs or the shorter fasteners found in the icon and pro comp arms?
  2. May 1, 2016 at 7:08 PM
    PSU Taco85
    PSU Taco85 Señor Member
    optional
    '10 TRD OR mostly stock
    Plasti dipped hootus
    sounds like it's time for some limit straps
  3. May 1, 2016 at 7:41 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    in what way were they bent in relation to the spindle?
    like PSU stated it could be a matter of needing limit straps as you are trying to extend pass the limit of articulation the uniball allows for.
