Total Chaos UCA. Getting past 3.7 caster
Discussion in '3rd Gen. Tacomas (2016-2023)' started by alecwin, Mar 6, 2021.
  1. Mar 6, 2021 at 6:57 PM
    alecwin
    alecwin [OP] @taco.sawce
    Alec
    SoCal
    19 Pro
    Recently installed 35's not too long ago, still SLIGHTLY rubbing at full lock while in reverse on the pinch weld. Already have a CMR, and I've already cut and hammered as much as I possibly can. It's not too bad and doesn't affect driving, but will definitely drive me nuts over time.
    The one alignment shop I've gone to said the truck maxed out at 3.6/3.7 caster.
    I've come across some similar problems but no indefinite answer to that being the max.
    Curious to know if anyone has reached 4-4.5 caster with Total Chaos UCAs before I drop another 100-200 on another alignment shop.
  2. Mar 6, 2021 at 7:01 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    What I did was max my rear cams out, so I had max clearance, then used heimed upper control arms to adjust the caster/camber more
    I have total chaos uppers
    alecwin[OP] likes this.
  3. Mar 6, 2021 at 7:05 PM
    WormSquirts
    WormSquirts Armageddon
    Braeden
    BC
    High caster doesn't mean more clearance... Uca's that add caster reduce clearance at the fire wall.
    Fitting 35s depends more on wheel specs. I often have to do some tubbing in the fire wall to clear 35s without any rubbing through the entire suspension travel on customer vehicles.
    y=mx+b and alecwin[OP] like this.
  4. Mar 6, 2021 at 7:09 PM
    alecwin
    Alec
    SoCal
    19 Pro
    Ahh that actually makes a lot of sense. Was trying to stick with a wider stance but damn it's been a lot of work. Lol.
    Dig the Worms picture btw. Haven't seen that game since I was young.
    WormSquirts[QUOTED] likes this.
  5. Mar 6, 2021 at 10:36 PM
    WormSquirts
    Braeden
    BC
    I still play it with a few friends that I grew up with on steam haha
  6. Mar 9, 2021 at 9:30 PM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
  7. Mar 10, 2021 at 1:16 AM
    JEFFRPM
    JEFFRPM Well-Known Member
    Jeff
    2018 inferno Double cab long bed 4x4
    17 x 8.5 KMC wheels, yokohama 285-70-17 geolander, 3" lift, 800 watts of alpine, leer shell, front & rear cloud cameras,
    My camburg UCA's (the greaseable ball joint ones open spherical ball ones are a joke in mud & salt) allowed 4° positive caster & capable of 6° if I wanted
    All I can say is these trucks with a 2" or more lift in front ABSOLUTLY need at least 4° positive caster so you can drive them without it driving you
    Mine is DCLB TRD OFF ROAD has 2" in front 1" rear 285-70-17 tires on 17 x 9 zero offset wheels 4° pos caster 0° camber & zero toe in..........drives straight down the worst groved road like a Lexus
    It drives better than stock ALOT better
    71tattooguy likes this.
  8. Mar 10, 2021 at 6:20 AM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    Agreed DCLB here same specs on alignment with SPC’s. Truck drives great wouldn’t change a thing
  9. Mar 10, 2021 at 7:12 AM
    CanadaToy
    CanadaToy Well-Known Member
    Greg
    Toronto
    17 DCSB TRD OR Alpine
    TRD Pro grille & skid, OEM tonneau and roof racks
    Mine are set at 4.6 deg caster. pushed the wheel far enough forward, that it will lightly rub the front bumper at full lock when reversing. No rub on my CMC. Low lift though (2015 trd pro suspension).
    Adam Henry likes this.
  10. Mar 10, 2021 at 7:15 AM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    As someone else already posted JD FAB has the ultimate solution available : https://jdfabrication.com/collections/toyota/products/tacoma-2016-lower-arm-pivots-899-99
