Total Chaos UCA how-to Install
Discussion in 'Suspension' started by SILVER06TRD, Sep 14, 2008.
  1. Sep 14, 2008 at 7:12 PM
    SILVER06TRD
    SILVER06TRD [OP] Well-Known Member
    AZ
    06 TRD
    de-badged, color matched grill, trd intake, trd short shifter, 3" skyjacker coilovers, rear aal, doug thorley long tube and y-pipe, urd catback, high flow cats, uni-chip, hellwig rear sway bar.
    Got the total chaos uca's intalled this weekend. With help from Chris it took about 2hrs with only a few minor bumps. They make a night and day difference compared to stock and allow for proper alignment and ride quality. These were installed on my 06 TRD with skyjacker coilovers and AAL's.
    go over the instructions and ensure you have all your parts.
    note: for some reason my zerks were difficult to get started and hard to tighten. they were actually 3/8. take your time and don't strip em, i did and had to get some generic metric one's at auto zone..the went in by easily by hand.
    supplied 3/8 zerk
    auto zone one's on the left compared.
    start by removing the wheels and placing the truck up on some stands.
    remove this bracket (10mm) and un-bend the clips that hold the line.
    remove some of the rubber shroud to give yourself some room to see and work. it's easy to just pop it over the plastic clips.
    remove the ball joint bolt (19mm)
    loosen the top nut (22mm)
    you will have to bend the inner fender well just a bit to get the top bolt out. don't worry...it's not as bad as it sounds. use some channel locks and take you time. it helps to have someone look down from the top and guide where to bend. to work the bolt out Chris used a hammer and a 1/4" extension. as you tap it out you may need to continue to bend it some more. just bend as you go so you can see exactly where you're at.
    note: remember that when you put the bolt back in; you'll be putting it back in from the rear. so, it's ok if it wedges a bit against the fender when you tap it out.
    once you get it out, install it the reverse of the way to you took it out so that it's easier to get in.
    install the assembled arm, put the bolt in from the rear and tighten to 83ft lbs
    install the ball joint bolt, collars and washers..be sure to review the instructions so you have the correct order.
    we used used zip ties to attach the line back to the arm. double check to be sure it will have enough movement free play.
    it's basically the same thing on the diver side. here are some more pics of where to bend, how to feed the upper bolt and the finished product. :D
    note: see if you catch it?? one of our bumps :frusty:
    bend here
    re-install your upper bolt the opposite way.
    align and enjoy....if you want em i have my alignment numbers hit me up and i'll post em. all the credit goes to Chris 4x4 awesome bro! thanks again
    el_toro408 and jackn7 like this.
  2. Sep 14, 2008 at 7:16 PM
    jolayiv
    jolayiv Carolina Alliance
    Jim
    Hertford NC
    07 DC TRD 4x4 Off-Road
    Revenge-Fab Sliders, AVS Vent Guards, Rear TSB, Hose clamp MOD, Locker MOD, Flowmaster 40 Series Delta Flow, Midland Radio, Wilson 1000 antenna, Rear Diff breather MOD, Weathertech liners, Maglite mount, Bed Divider, LEER 100XR, Pop&Lock
    Great write up!
  3. Sep 14, 2008 at 7:20 PM
    SILVER06TRD
    AZ
    06 TRD
    SF devil....thanks
    hmasonb34 likes this.
  4. Sep 14, 2008 at 7:33 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Nice write up, Lenard!
    I had a great time! We had alot of laughs wich Im sure was the cause for the delays we encountered. :D
    One thing to note: WHen re installing the bolt on the driverside, be carefull when working around the fuel lines near the cab. The bolt will be up against them, just be carfull not to bend or damage the lines.
  5. Sep 14, 2008 at 7:37 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    great write up man!!! sounds like you and chris had a kickass saturday!!!:D
  6. Sep 14, 2008 at 7:43 PM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Great job fellas. Looks great.
  7. Sep 14, 2008 at 7:47 PM
    SILVER06TRD
    AZ
    06 TRD
    thanks bro....:wink:
  8. Sep 15, 2008 at 6:06 PM
    Ridgerunner
    Ridgerunner Well-Known Member
    Frank
    Rocklin, Ca.
    2001 prerunner doublecab limited
    2001 with; cat-back side-swept twin exhaust, elbow mod, Westin bullbar with Hella 450 driving lights, Snugtop XTR camper shell, TRD off-road 2x4-black beauty.
    RIGHTON Chris!!!!! Truly a gentleman here AND we are lucky to have him and his expertise in this group!!!!:) By the way-what are the benefits of these new UCA's over stock-and should I put em on my '01?
  9. Sep 15, 2008 at 6:08 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    hey uncle frank......the uca's allow for correct alignment angles when you lift a truck. you probably dont need it for a stock setup, but it may make a difference in the ride.
  10. Sep 15, 2008 at 6:12 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    AH OK T-thanks:) I like it just the way it is anyways-I guess ol unk is gittin older:D :yawn:
  11. Sep 15, 2008 at 6:13 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    nah......not older.......wiser:D!!! in the case....im gettin older too......i need sleep soon!!!:D
  12. Sep 15, 2008 at 6:25 PM
    Ridgerunner
    Frank
    Rocklin, Ca.
    HAA thanks neph:cool:
  13. Sep 15, 2008 at 6:32 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    To add: when used with longer shocks and springs, you get more travel. :)
  14. Sep 15, 2008 at 6:33 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yep.....thanks for covering the bases brotha!!! i knew i was missing something!!:)
  15. Nov 23, 2008 at 7:15 PM
    ksj
    ksj Well-Known Member
    Pacific NW
    2018 Cavalry Blue TRD Pro
    265/70-17 KO2
    Installed it upside down once, eh?
    I biggest bump I had was when I tapped the bolt in and it knocked the second sleeve and the last 1/2 bushing out (bolt installed from the top). Had to take it all out again to reinstall the bushing and sleeve...
    blue_goose likes this.
  16. Nov 23, 2008 at 7:33 PM
    roxspin72
    roxspin72 Enjoying my addiction
    NC
    Speedway Blue, TRD, 4X4,
    Oh Yeah!!!
    I will have to save this one in my fav. What about them C/O... Never knew skyjacker made those. How much, and how do they perform???
  17. Nov 23, 2008 at 7:34 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I belive that was the one Silver06TRD did. We were haveing a good time jokeing around and all, and werent paying enough attention. I quickly realized the problem though, before it was installed. :D
  18. Nov 23, 2008 at 7:51 PM
    Ridingontrd
    Ridingontrd Well-Known Member
    Richard
    Laughlin,N.V
    trd sport 4x4 w/towpkg
    aFe prodry,Dynomax ultra flo ss,Scangauge2,Demello front bumper,BudBuilt skids,sliders(local)AllPro rear bumper,Wet O's cobalt blu,w/halfpiping,TRD logo in gold,R/L hood struts,5150's@10"aal 3 pack,T/C uca,Light racing c/o,1"diff.drop,de-badged,
    Thank You... For putting up these pics.You have just saved me from a new uni-ball.:bananadance::D Reps for that!!
  19. Nov 24, 2008 at 4:51 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Not sure if Silver06TRD is going to reply right away, BUT, I have ridden in his truck, and I must say they are the best rideing CO's I have been in. :)
  20. Apr 15, 2009 at 10:11 PM
    TEX357
    TEX357 TX
    05 TACOMA
    285\70-17 BFGoodrich KM2's 17x8 Pro Comp 7089
    Awesome write up but what exactly do the UCAS do?
