Total Chaos UCA how-to Install
Discussion in 'Suspension' started by SILVER06TRD, Sep 14, 2008.
  1. Nov 8, 2009 at 5:29 PM
    #181
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Not sating your is a bad route. Its a good one. I was just pointing out, as you kinda make it sound like all sorts of stuff is in the way, and you have to wildly bend the steel, that you in fact dont. FWIW, I can get the bolt out faster than cutting it with a saw..
  2. Nov 8, 2009 at 7:36 PM
    #182
    woods247
    woods247 Well-Known Member
    back yonder
    09 TRD Sport Double Cab 4x4
    SAWs front, Fox resi rear, Total Chaos UCAs, 17" BBS RD-Truck FJ Rims with 255 BFG KM2s, TRD exhaust/intake, OME Springs, All-Pro flip kit, Timbren rear bumpstops, custom spare carrier, All-Pro skids, Beefed Sliders, All-Pro front bumper, Warn M8000 w/Synth MasterPull line, Procomp 30" LED lightbar, Bestop Soft topper, Safari Snorkel, CBI Bushmaster (custom), Baja Racks Utility rack, All Pro custom bed rack, Leer 100XQ
    With practice I'm sure many folks can get these out quickly by bending the metal, but this being the third time (and Youngblood's first) for me installing UCAs on a Tacoma, I can say it was FAR faster to cut the heads and slide new bolts in from the bottom. I begged him to bend the pinch but he stood his ground and IMO made the right choice. It's not always about speed to me anyway. If I assist anyone else with lifting their truck, I'll recommend they cut and install new bolts if they have a sawzall. I can bring one if they don't. :) It was so much cleaner and quicker. Props of course Chris4x4, your posts helped tremendously with my mods.
  3. Dec 9, 2009 at 10:23 PM
    #183
    SILVER06TRD
    SILVER06TRD [OP] Well-Known Member
    AZ
    06 TRD
    de-badged, color matched grill, trd intake, trd short shifter, 3" skyjacker coilovers, rear aal, doug thorley long tube and y-pipe, urd catback, high flow cats, uni-chip, hellwig rear sway bar.
    I've been asked a couple times for the alignment numbers after this install. For those of you that asked I know it's been a while...I thought I had lost them, but just recently came across the paperwork again. So, I thought I would post them up....hope it helps out.
    The work was done at the local Goodyear tire shop.
  4. Dec 22, 2009 at 10:56 AM
    #184
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    I'm hopeing Santa brings me some tc uca's! I put on a 3in. Lift and now have had two alignments and still have wandering issues and some nasty bump steer! My question is does anyone have problems with there tires rubbing the uca? I only have about a half an inch between my tires and the stock uca's? Also thanks for the thread and all the imput! I'll be installing mine soon and can't wait, for I've been driving it this way for two years! And have forgotten what it is supposed to drive like?
  5. Dec 22, 2009 at 11:11 AM
    #185
    youngblood
    youngblood Well-Known Member
    Chattanooga TN
    07 SR5 4x4 DC longggg bed
    None (yet)
    The UCAs definitely improve the accuracy of the steering response.
    I'm running TC UCAs and stock TRD wheels with 285/65 16 tires. It is close in there maybe 1/2" but they don't rub.
    Going with bigger rubber is going to require a wheel with greater offset. I'm planning to go the same route as woods247 with some 17" BBS with a 4.75" backspace.
    Enjoy your new UCAs!
  6. Feb 10, 2010 at 5:24 PM
    #186
    05tacoSPORT
    05tacoSPORT Well-Known Member
    Tennessee
    TRD SPORT
    Geared and Locked
    Who has the best $$$$$price$$$$$ on these????????????????????????????????
  7. Feb 23, 2010 at 7:48 AM
    #187
    Twirlin
    Twirlin Nature just gets the blow-by
    WI
    '10 TRD Sport Mag Grey
    anyone in the southern wisconsin area that wants to help me install some TC UCA's?
  8. Feb 25, 2010 at 6:05 PM
    #188
    whitebread
    whitebread Well-Known Member
    Raleigh, NC
    2019 OR 4x4 6MT
    I was trying to remove my OE UCA tonight and could not get it off the spindle. The upper part with the long bolt was no problem. With the spindle part I tried prying, hammering, and using a clamp. All were quite unsuccessful. Is there any trick to it that I am missing?
  9. Feb 25, 2010 at 7:10 PM
    #189
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I just Hit the shit out of it. It should pop right out. If your trying to save the bolt, use a puller.
  10. Feb 25, 2010 at 11:14 PM
    #190
    SilverStreak05
    SilverStreak05 Well-Known Member
    NorCal
    2005 4x4 TRD Off-Road
    DR coilovers, DR rear reservoir shocks, Deaver custom 11 pack leaf springs
    A little trick if you want to keep and re-use the upper ball joint is to flip the nut over once you get it off and screw it back on upside down. Then you can hammer on the nut to pop the ball joint out and you wont damage the threads.
  11. Feb 26, 2010 at 4:07 AM
    #191
    whitebread
    Raleigh, NC
    2019 OR 4x4 6MT
    Thanks for the input. I will just pick up a pusher...seems a little less destructive than smacking the hell out of it with a hammer. ;)
  12. Feb 26, 2010 at 8:54 AM
    #192
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    It's funny how this varies by truck. Mine were a bitch to get out also, I couldn't hammer them out. I ended up using a big crow bar to pop them off...but when I helped Rene (tacoskim) install his UCA's, his popped right out with 1 hit from the hammer.
  13. Mar 24, 2010 at 10:46 AM
    #193
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    i'm saving for the total chaos. while my truck handles nicely lifted..i feel something changed and it is less responsive than stock. it just feel "looser". camber set at spec was impossible for my poor alignment guy.
    i'm going back in!!
    thanks chris. you and the wife ever come to the bay area..beer is on me.
  14. Mar 24, 2010 at 7:01 PM
    #194
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    :woot:
  15. Apr 4, 2010 at 5:42 PM
    #195
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    So after you cut off the old bolt do you reinstall the new one the opposite direction? ie. front to back instead of back to front? Nut side where the 'bend' would have been, reverse of original direction etc. Thanks.
  16. Apr 4, 2010 at 6:05 PM
    #196
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yes.
  17. Apr 4, 2010 at 7:14 PM
    #197
    youngblood
    Chattanooga TN
    None (yet)
    Yes indeed.
  18. Apr 4, 2010 at 8:03 PM
    #198
    nvdeserted
    Reno, NV
    Cool. It was actually obvious once I went out and looked at it. I'd rather not bend the pinch-weld just to get a bolt out. Thanks.
  19. Apr 26, 2010 at 6:25 PM
    #199
    Redgrom
    Redgrom http://www.tacomaworld.com/forum/2nd-gen-builds/29
    Brent
    san clemente
    4x4 taco and 96 ford bronco
    ATO front skid (need more but icon's might fail if I hang anything else from my truck) All-Pro front bumper thanks to a good deal here and a pesky encounter with a rock or 20, total chaos uppers.
  20. May 10, 2010 at 3:08 PM
    #200
    mike686
    mike686 Well-Known Member
    Michael
    Waldorf
    10 Tacoma TRD Off Road
    See Build Thread
    So what im getting out of this is if we were to do a six inch or higher lift and we dont want to have wandering issues then invest in getting a pair of uca's? sorry im new to all this stuff and i researched i think on total chaos website and i thought now i might be crazy but i thought it said for all tacomas up to 2008 ... will they fit my 2010? :confused:
