Total Chaos UCA how-to Install
Discussion in 'Suspension' started by SILVER06TRD, Sep 14, 2008.
  1. May 10, 2010 at 5:39 PM
    #201
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    Yep, they'll fit. 2005 to 2010 same stuff. UCA anyway.
  2. May 11, 2010 at 6:11 AM
    #202
    Twirlin
    Twirlin Nature just gets the blow-by
    WI
    '10 TRD Sport Mag Grey
    yes, they will work with your truck. They are listed as 05+.
  3. May 13, 2010 at 9:04 PM
    #203
    huff.jeremy
    huff.jeremy Well-Known Member
    Illinois
    2010 MagGray SR5 Access Cab, 4x4, 2.7L, 5spd
    OME 884's, OME shocks, Wheelers 1.5" AAL, Light Racing UCA, Jason Fiberglass top, URD Short Shifter, Fog Lights
    I noticed the comment that the drivers side bolt will be against fuel lines when installing it in reverse... I just put my Light Racing UCAs on tonight, and on my 2010 it is apparently impossible to install the driver's side bolt in reverse for that reason. The bolt is sandwiched tightly between a brake line and a fuel line, neither of which I wanted to bend in order to make clearance for the bolt head.
    On a happier note, installing the bolt from the original direction was MUCH easier than getting it out.
  4. May 17, 2010 at 11:49 AM
    #204
    jmed99
    jmed99 Well-Known Member
    SC
    09 DC PreRunner TRD OR
    I will be attempting the TC UCA install soon.
    -Can someone please give me more info on the puller talked about int he thread? Do you have a link to this item so I can get a better idea?
    -Also, what length extension is needed here? 12 inch?
    I want to make sure I have all the proper tools before I start! :)
    Thanks!
  5. May 17, 2010 at 12:05 PM
    #205
    JasoTaco
    JasoTaco Well-Known Member
    Salt Lake City, Utah
    09 Tacoma TRD Off Road
    ToyTec Ultimate 3" Lift -TSB Rear springs - TRD Cold Air Intake - TRD Skid Plate - Total Chaos Upper Control Arms - 2 Hella Rallye 4000 lights (130W Bulbs) - Clear Bra - Under Coat - Bed extener - Toyota Bed Mat - Weathertech floor mats - Tailgate hose clamp & washer mod - PIAA Fog Lights - ScanGauge II - Beefed Sliders - Differential Breather Mod - Heated Seats - All-Pro Bumper - Warn M8000 Winch with wireless controls - Boztec Diff Skid - ATO skids
    Great post - Did you you bolt up this UCA before you realized it was upside down?
  6. May 17, 2010 at 6:38 PM
    #206
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    LMAO!! Yeah...We got to joking arround. I caught it before we bolted it up. :eek:
  7. May 17, 2010 at 8:59 PM
    #207
    JasoTaco
    I don't think I would have noticed if I hadn't installed some TC UCAs a couple of weeks ago. I read your thread prior to install, it was a huge help and confidence builder to do it myself. :)
    On a side not what kind headers are those I see in the back ground and how difficult was the install on them? I like the idea of putting on some headers but dread the install they look like a beotch to get to.
  8. Jun 12, 2010 at 10:32 AM
    #208
    raycie
    raycie Well-Known Member
    Oahu, HI
    2013 DCLB / 2016 4R Trail
    In need of $$$
    just curious as I this is next on my list.... I guess there ARE 2 options out there now.. the bend (material in engine compartment), and the cut (original bolt and buy a new one). What route do shops do? What route would toyota do? Will there now be a 3rd option?
  9. Jun 12, 2010 at 4:34 PM
    #209
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Toyota bends the sheet metal. So do shops. It has no affect on the structual integrity, or is it visable. It can be bent right back, as it only has to be bent enough to clear the bolt head.
  10. Jun 12, 2010 at 5:25 PM
    #210
    nvdeserted
    Reno, NV
    As said above, the manual supposedly says to bend the sheet metal. When I put mine on I did the new bolt method, it was super easy but the bolts are like $14 each... next time I'm just gonna bend the sheet metal.
  11. Jun 14, 2010 at 10:29 AM
    #211
    DTacoms
    DTacoms Well-Known Member
    Frisco, Texas
    05 4x4 DC LB BSP
    I did not even bother to bend the sheet metal back.
  12. Jun 16, 2010 at 6:02 PM
    #212
    STR8_BEAST
    STR8_BEAST Well-Known Member
    Collin
    HB, SoCal
    07 PRERUNNER TRD OR
    MAGNAFLOW EXHAUST, SOUND SYSTEM, KENWOOD DNX 7140, WINDOW TINT, REAR TSB, FRONT COIL SPACER, SATOSHI MOD, BHLM, WHITE CALIPERS, CB RADIO W/4FT FIRESTIK, MAGLITE MOD
    i tried disconnecting the stock uca from the stock spindle today, and after i took off the clip and bolt, it felt like it was fused on there. how did you guys disconnect it? I shook the lca and pulled at the uca and it wouldnt budge...
  13. Jun 16, 2010 at 6:04 PM
    #213
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Tap the lower ball joint with a hammer, tap the spindle near the ball joint.
  14. Jun 16, 2010 at 6:23 PM
    #214
    STR8_BEAST
    Collin
    HB, SoCal
    07 PRERUNNER TRD OR
    :frusty:
    ugh i spent 6 hours today taking apart my front suspension for the first time trying to throw some spacers on my coils (yes i know they suck but im just trying to fit bigger tires before i get a more permanent solution) and for the life of me i couldnt get them to fit. i pushed the lca down, but the farther it went down, the closer the uca got to the coil until it binded and wouldnt move, so i couldnt fit the lower shock mount into the lca. would you suggest disconnect the spindle from the uca to get it in or something else? im kinda lost right now...
  15. Jun 16, 2010 at 6:26 PM
    #215
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yes. Disco the UCA.
  16. Jun 16, 2010 at 6:30 PM
    #216
    STR8_BEAST
    Collin
    HB, SoCal
    07 PRERUNNER TRD OR
    alright, thanks chris :)
    any other pointers, or is just tapping the spindle by the uniball gonna do the trick?
  17. Jun 16, 2010 at 6:31 PM
    #217
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    That should do it.
  18. Jun 16, 2010 at 6:47 PM
    #218
    STR8_BEAST
    Collin
    HB, SoCal
    07 PRERUNNER TRD OR
    alright, i guess ill give it another go, thanks again chris
  19. Jun 18, 2010 at 12:44 PM
    #219
    STR8_BEAST
    Collin
    HB, SoCal
    07 PRERUNNER TRD OR
    ok, i'm trying to pry them apart, and hitting it with a hammer, but not too hard because i dont want to ruin the threads. is there a certain part i need to tap, like the side, front, bottom, or anything? it just doesnt want to budge
  20. Jun 18, 2010 at 1:17 PM
    #220
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    If your replacing the OEM UCA's, go ahead and beat the threaded part of the stock ball joints. Hitting them upward. You shouldnt hurt the threads, but if you do, your getting new bolts with the TC UCA's anyway.
