Total Chaos UCA how-to Install
Discussion in 'Suspension' started by SILVER06TRD, Sep 14, 2008.
  1. Jun 18, 2010 at 1:29 PM
    #221
    STR8_BEAST
    STR8_BEAST Well-Known Member
    Collin
    HB, SoCal
    07 PRERUNNER TRD OR
    MAGNAFLOW EXHAUST, SOUND SYSTEM, KENWOOD DNX 7140, WINDOW TINT, REAR TSB, FRONT COIL SPACER, SATOSHI MOD, BHLM, WHITE CALIPERS, CB RADIO W/4FT FIRESTIK, MAGLITE MOD
    i would, but i'm not replacing them :eek:, i'm just disconnecting them so i can fit the shock w/ spacers, so i need the oem uca still, and if i destroy the threads, then i'll be up a creek....
  2. Jun 18, 2010 at 1:32 PM
    #222
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Ok. Then use a Ball joint puller, or a Pickle fork. Tap it in between the balljoint, and the top of the spindle, and it will pop right off.
  3. Jun 18, 2010 at 1:35 PM
    #223
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    A pickle fork may damage the boot if one is not careful.
  4. Jun 18, 2010 at 2:04 PM
    #224
    STR8_BEAST
    Collin
    HB, SoCal
    07 PRERUNNER TRD OR
    well im going to rent a ball joint puller right now, so we'll see how it goes
  5. Jun 18, 2010 at 4:42 PM
    #225
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    +1.
  6. Jun 18, 2010 at 5:08 PM
    #226
    STR8_BEAST
    Collin
    HB, SoCal
    07 PRERUNNER TRD OR
    the ball joint remover worked great! i just finished everything and am about to take it for a test drive. phew that was a lot more work than i thought it would take, but i'm just glad i was able to do it. thank you so much chris!!!!
  7. Jun 18, 2010 at 5:11 PM
    #227
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Glad you got it, Now post up some pics!! :D
  8. Jun 18, 2010 at 6:36 PM
    #228
    JDMcQ
    Congrats on getting it done.
  9. Jun 18, 2010 at 11:32 PM
    #229
    STR8_BEAST
    Collin
    HB, SoCal
    07 PRERUNNER TRD OR
    even with the ball joint remover, it took a lot of good whacks from a mallet to separate it, i put a pick of the overall stance in the live thread. ill try to get a couple more later
  10. Jun 21, 2010 at 9:24 AM
    #230
    betz.steven
    betz.steven Well-Known Member
    Southern NJ
    2011 TE 4Runner
    so the front bushing on my drivers side UCA mushroomed out from being over greased, took it apart today to reseat it but it is permanantly deformed. i already ordered a new one fro TC and its on the way. my issue was i was not able to get the through bolt back out past the fuel lines, any ideas to help make this easier for when i replace the bushing?
  11. Jun 21, 2010 at 10:37 AM
    #231
    betz.steven
    Southern NJ
    2011 TE 4Runner
  12. Jun 21, 2010 at 1:59 PM
    #232
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Not sure why the bolt wont come out....It went in that way, right?
  13. Jun 21, 2010 at 8:58 PM
    #233
    wvmountaintop
    wvmountaintop Well-Known Member
    Dennis
    Hampshire County, WV
    2010 Tacoma 4 Door LB Sport
    Weather Tech Floor Mats, Anytime Fog Light Mod, Belt Chime Mod, Extra D-Rings under Bed Bolt, ARE MX Topper, Bed Rug
  14. Jun 22, 2010 at 4:32 AM
    #234
    betz.steven
    Southern NJ
    2011 TE 4Runner
    yeah it just seemed like it would need alot more pressure on the lines to get the bolt back out than it did to get it in. but i guess i found the bushing to be deformed before the bolt came all the way out so i knew it had to be replaced anyway, so i figured i'd save that can of worms for when i actually replace the bushing this weekend, and just reassembled everything. was just trying to see if there was a specific trick to it or just the standard be carefull and it will come eventually with a little coaxing and frustration
  15. Jul 9, 2010 at 8:38 AM
    #235
    V-TRAIN
    V-TRAIN Well-Known Member
    N. CACKALACKY
    08 TRD SPORT LONG BED
    DEMELLO ROCK CRUSHER SLIDERS, PIAA LIGHTS, TSB 4 LEAF PACK, CBI OFFROAD REAR BUMPER LINEXED, CBI OFFROAD FRONT BUMPER LINEXED, REAR 5100's, 1.5" TSB AAL, ICON EXTENDED TRAVEL COILOVERS @ 3", TOTAL CHAOS UCA's, HELLA MICRO DRIVING LIGHTS, IPOD INTERFACE, THULE ROOF RACK, UWS SLIM LINE BLACK TOOL BOX, 17" BBS RD TRUCK WHEELS, GOODYEAR WRANGLER DURATRAC IN 285/70/17
    okay, i am hung up. i can't gey the drivers side uca bolt to budge. head keeps dancing around the fuel lines. have tried taping with 3/8 extension, took spanner wrench, put behind and beat it. have put another shorter bolt in opposite side to keep it from binding up. i have passanger side done, and icons in. i have been fooling with this damn bolt for 1.5 hours now, need help.
  16. Jul 9, 2010 at 8:39 AM
    #236
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Patience. It will go. You have to get it lined up perfectly. Wiggle the UCA, while pushing in the UCA bolt.
  17. Jul 9, 2010 at 8:45 AM
    #237
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    X2 and if you have another set of hands have them wiggle the fuel lines a little. I think if I remember there is a bolt you can take off the fuel lines to give you a tiny bit more play. Either a bolt or a clip.
  18. Jul 9, 2010 at 10:28 AM
    #238
    V-TRAIN
    N. CACKALACKY
    finally got it, i just pulled on the lines and got it to spin in there. i just have to go torque everything now. will do rear later today. i feel like it is down hill from here.
    i was holding my breath when i put he nut on that bolt, i was scared i might have stripped it. that would have been a nightmare, might have had to trade the truck for a mini-van.
    not
  19. Jul 9, 2010 at 10:33 AM
    #239
    jmed99
    jmed99 Well-Known Member
    SC
    09 DC PreRunner TRD OR
    It helped me to use a crow bar and apply a slight amount of pressure to the fuel lines moving them toward me. That allowed me to align the bolt so it wouldn't bind. It still took a little work but it went in. Just keep trying.
  20. Jul 9, 2010 at 10:35 AM
    #240
    jmed99
    SC
    There's no trick. Just pull the fuel lines a little (not enough to do damage) and it will come out. It's a pain in the ass but it will come. Allow yourself plenty of time and know ahead of time that you'll get pretty frustrated and you should be ok.
