Total Chaos UCA how-to Install
Discussion in 'Suspension' started by SILVER06TRD, Sep 14, 2008.
  1. Aug 30, 2010 at 7:38 PM
    #241
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    Anyone know off hand the size of the nut that goes on the uniball bolt? I'm at autozone hoping to get the wrench for it.
  2. Aug 30, 2010 at 7:55 PM
    #242
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
  3. Aug 30, 2010 at 7:57 PM
    #243
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    IIRC, its a 21mm....dam.....gimmie a sec, and I'll find out.
  4. Aug 30, 2010 at 8:04 PM
    #244
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Too dark to get a socket on it. IIRC, Its a 19mm. The bolt head is a 21.
  5. Aug 30, 2010 at 10:24 PM
    #245
    jdkeller
    Jonathan
    Inland Empire, Ca
    It was a 22! Bolt head is a 21.
    Thanks guys!
    I was lowering my coilovers. I decided to separate the uca and spindle. Made it a piece of cake!
  6. Aug 31, 2010 at 7:36 AM
    #246
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Thanks Johnathan! I couldnt remember
  7. Aug 31, 2010 at 8:34 AM
    #247
    jdkeller
    Jonathan
    Inland Empire, Ca
    No thank you! You are always more than helpful.
  8. Oct 1, 2010 at 2:44 PM
    #248
    jr114
    jr114 Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    Hey guys i just got my ball joint ucas fro camburg. I just wanted to confirm that you grease the sleeve that slides into the bushings and not the bushings themselves right? or do you grease both of them?
  9. Oct 1, 2010 at 5:00 PM
    #249
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Grease the heell out of both, bushings and sleeve.
  10. Oct 1, 2010 at 5:16 PM
    #250
    Tacomanator
    Clam Slammer
    Southern Cali
    x2. grease the shit out of em'
  11. Oct 2, 2010 at 7:25 AM
    #251
    jr114
    Jon
    SoCal
    Truck
    copy...much thanks again guys
  12. Oct 4, 2010 at 10:15 PM
    #252
    jr114
    Jon
    SoCal
    Truck
    guys with the camburg ball joint ucas...whats the extra nyloc nut and washer for??? looks like its 5/8 or something???
  13. Oct 5, 2010 at 5:17 PM
    #253
    jr114
    Jon
    SoCal
    Truck
    :facepalm:nm its actually bigger than 5/8 and from pictures it looks like that with the supplied washer replaces the factory one on the mounting bolt. duh
  14. Oct 22, 2010 at 8:52 PM
    #254
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    are you guys leaving the coilovers connected both top and bottom then putting in the UCA and bolting it to the spindle.
    The issue im having is that i can either get the coilover in and not be able to connect the UCA to the spindle, or I can connect the UCA to the spindle and not be able to connect the bottom of the coilover.
  15. Oct 22, 2010 at 9:03 PM
    #255
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ive done it both ways. You should have no issues installing it with the shock/spring installed.
  16. Oct 22, 2010 at 9:07 PM
    #256
    ktmrider
    Junk
    I just used a jack on the bottom of the LCA and compressed the coilover until i could tighten the uni-ball bolt down. thanks for the help too
    EDIT: Do you happen to know the torque for that bolt? I dont believe its listed on this thread.
  17. Oct 22, 2010 at 11:07 PM
    #257
    jdkeller
    Jonathan
    Inland Empire, Ca
    I thought it was like 83 but I don't remember.
  18. Oct 23, 2010 at 7:12 AM
    #258
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    TC told me between 90 and 100 ft-lbs. for the unibal.
  19. Oct 23, 2010 at 7:39 AM
    #259
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    100 per TC's instructions.
  20. Oct 23, 2010 at 9:33 AM
    #260
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
