Total Chaos UCA how-to Install
Discussion in 'Suspension' started by SILVER06TRD, Sep 14, 2008.
  1. Aug 3, 2011 at 3:50 PM
    #281
    tacokid09
    tacokid09 it's about the off-road miles
    Brian
    San Luis Obispo, CA
    2010 Tundra
    so i dont have to but new UCA bolts correct? also this will be the most mechanical work i have done by myself.. it shouldnt be that by the looks of this. i have to do this install along with COs.. im pretty sure i could do it in one day
  2. Aug 17, 2011 at 7:18 PM
    #282
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    Fwiw, I found that using a punch tool was very helpful in removing that super long bolt.
  3. Sep 10, 2011 at 12:15 PM
    #283
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue 5.3l v8 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 37/12.5/17 mickey thompson baja atz Allpro hybrid bumper grill craft grill wicked flow muffler inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
    so what is the 22mm socket used for i havent seen anything on my truck thats 22mm?
  4. Sep 10, 2011 at 11:48 PM
    #284
    SILVER06TRD
    SILVER06TRD [OP] Well-Known Member
    AZ
    06 TRD
    de-badged, color matched grill, trd intake, trd short shifter, 3" skyjacker coilovers, rear aal, doug thorley long tube and y-pipe, urd catback, high flow cats, uni-chip, hellwig rear sway bar.
    The A-arm ball joint top nut:[​IMG]
  5. Sep 12, 2011 at 6:26 PM
    #285
    CGtaco
    CGtaco Well-Known Member
    Phillip
    07 Tacoma TRD 4x4
    Fog light Mod Total Chaos UCA's Front Icons Rear Icon / res
    :rain::rain::rain:I live in Kodiak AK so I get lots of RAIN :rain:. Should i worry about the uni ball corroding. In the winter there WILL be salt on the ground. Right now im using a water repellent CPC joint lube. Should i pack the crap out of it with grease or keep using the film lube? ANY THOUGHTS???
  6. Sep 12, 2011 at 8:17 PM
    #286
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    If you already have them i would just switch over to a stainless steel uniball
  7. Sep 12, 2011 at 8:28 PM
    #287
    CGtaco
    Phillip
    07 Tacoma TRD 4x4
    I probably will when it comes to that. Any link to where i can buy?
  8. Sep 12, 2011 at 8:32 PM
    #288
    ktmrider
    Junk
  9. Oct 14, 2011 at 9:08 PM
    #289
    Raceline08
    Raceline08 Well-Known Member
    Brett
    Santa Rosa, ca
    Silver 08 DBC SB 4x4 TRD Offroad
    front Billies, 885x coils, taco lean spacer, TC UCA'S, Magnaflow 22" OME Dakars, Billy 110 rear's, B.A.M.F CMC, custom made E-locker guard
    Thanks Chris for the install and pics! New to the Tacomas! Did exactly what you did except i put the uca bolt back in the same way. TC is a great product and it is the difference between night and day! Now back to factory specs. thanks again.
    Brett
  10. Nov 6, 2011 at 9:09 AM
    #290
    Spagget13
    Spagget13 Well-Known Member
    Drew
    Lake Havasu City
    01 TRD off road ext cab
    Mcm Fabrication4x4 long travel kit, ADS coilovers, ADS bumps Deaver h70/e30 Leafs, 2.5x16 king double bypasses, straight pipe after cat, Glassworks Fiberglass front and rear.
    Can you use the stock shocks and coils for this kit? looking to get a little spendy for my birthday.
  11. Nov 6, 2011 at 10:12 AM
    #291
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You can, but the point of the TC UCA's, is to give a little more travel when using extended coil overs, and to add caster back when lifted.
  12. Nov 6, 2011 at 1:19 PM
    #292
    Spagget13
    Drew
    Lake Havasu City
    Well I have 3" spacers on my truck but i was thinking about getting bilstein 5100's
  13. Nov 6, 2011 at 1:28 PM
    #293
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    If youre lifted, then will will help the alignment.
  14. Nov 6, 2011 at 5:45 PM
    #294
    Spagget13
    Drew
    Lake Havasu City
    But then won't my cv's be at a severe angle?
  15. Nov 6, 2011 at 5:47 PM
    #295
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    No worse than they are now.
  16. Nov 6, 2011 at 6:01 PM
    #296
    Spagget13
    Drew
    Lake Havasu City
    Alrighty then. Thanks chris! You're the man!
  17. Nov 6, 2011 at 6:16 PM
    #297
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Glad to help ;)
  18. Nov 25, 2011 at 10:58 PM
    #298
    markmatters
    markmatters Viejon
    Mark
    Yuma, AZ
    2007 PreRunner
    subd. reference.
  19. Nov 30, 2011 at 11:26 AM
    #299
    DTaco55
    DTaco55 Active Member
    Derek
    L.A.
    2011 TRD Sport
    Great write up, looks awesome, very informative
  20. Dec 6, 2011 at 7:21 AM
    #300
    samhain
    samhain Well-Known Member
    Brandon
    Hilton Head, SC
    05 Tacoma SR5
    Can anyone reload the pics? They are all corrupt.
