Total Chaos UCA how-to Install
Discussion in 'Suspension' started by SILVER06TRD, Sep 14, 2008.
  1. Dec 9, 2011 at 3:32 PM
    #301
    samhain
    samhain Well-Known Member
    Brandon
    Hilton Head, SC
    05 Tacoma SR5
    I just got finished with the LR upper control arm install. On the driver's side, remove the two 10mm bolts at the top of the fender well. Those hold the fuel lines in place. Once the nuts are removed, you will have enough play in the lines to move them aside and put the long bolt in backwards.
  2. Jan 2, 2012 at 7:13 AM
    #302
    Swampmonkey
    Swampmonkey Well-Known Member
    Wes
    Fairhope, AL
    2011 Prerunner TRD DC
    UWS black low profile toolbox, TRD intake, TRD exhaust, TC uca's, Rear 2" toytec aal, OME Front and Rear shocks, OME 885s, NFABs
    If I do 5100s with eibachs up front set at .85 and rear 2" aal will I need to go with the uca's at some point? Are the tc uca's better than the light racing ones from toytec? Thanks.
  3. Jan 2, 2012 at 7:30 AM
    #303
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    At .85" you shouldnt need any UCA's. THe LR UCA's and Total Chaos UCA's are different animals. THe TC's have a Uniball allowing for a little more travel, which is usefull with extended coil overs, while the LR's use a ball joint. For your aplicatin, the LR's would be just fine, if you wanted to get different UCA's.
  4. Jan 3, 2012 at 5:02 AM
    #304
    Swampmonkey
    Wes
    Fairhope, AL
    Thanks Chris. Wanting to keep factory rake. Only have three leaves in rear. If I do eibachs and 5100s at .85 what aal should I get in rear? Thanks again Tacoma God.
  5. Jan 3, 2012 at 7:27 AM
    #305
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I think you would want at least a 1.5" AAL
  6. Jan 3, 2012 at 7:40 AM
    #306
    jflan
    jflan Well-Known Member
    Vancouver, WA
    09 Access 4x4 2.7L manual SR5
    SnugTop SuperSport Sportsman keyless cap Weathertech mats - OEM skidplate - OEM hitch
    That would get you at least +2-1/2" in the front.
    Apparently you have the non-TSB spring (2+1) 2 leaves, 1 overload.
    I would go with the 2" AAL from ToyTec for non-TSB to keep the rake.
  7. Jan 4, 2012 at 4:00 AM
    #307
    samhain
    Brandon
    Hilton Head, SC
    05 Tacoma SR5
    U will need uca's with 5100 and .85 eibachs. That's what I am running.
  8. Jan 4, 2012 at 5:18 AM
    #308
    Swampmonkey
    Wes
    Fairhope, AL
    Any vibes or wandering with your settup?
  9. Jan 4, 2012 at 9:37 AM
    #309
    tacoman15
    tacoman15 Boobies
    Northeast Georgia
    2015 Tacoma TRD OR & 1985 SR5 4Runner
    not necessarily. i am running the same setup and i have stock UCA's and no problems.
  10. Jan 4, 2012 at 9:43 AM
    #310
    jflan
    Vancouver, WA
    Alignment report, please.
  11. Jan 4, 2012 at 9:46 AM
    #311
    tacoman15
    tacoman15 Boobies
    Northeast Georgia
    if i had my numbers i would be more than happy to share them. the last time i got an alignment was october and they didn't give me my numbers and i wasn't educated enough at the time to ask for them lol
  12. Jan 4, 2012 at 9:49 AM
    #312
    jflan
    Vancouver, WA
    Generally they can't get your caster in spec without aftermarket UCA's.
    If you're rig doesn't wander or bump-steer, then you beat the odds.
  13. Jan 4, 2012 at 9:52 AM
    #313
    tacoman15
    tacoman15 Boobies
    Northeast Georgia
    i must have beat the odds then. i don't wander lol or bump-steer
  14. Jan 4, 2012 at 9:54 AM
    #314
    jflan
    Vancouver, WA
    You won't lol when you're in the ditch.
    :p
  15. Jan 4, 2012 at 9:56 AM
    #315
    tacoman15
    tacoman15 Boobies
    Northeast Georgia
    the only time my truck will see a ditch is when i am pulling somebody out of one!
    jesus i hope i didn't just jinx myself
  16. Jan 4, 2012 at 9:59 AM
    #316
    jflan
    Vancouver, WA
    Fawk, I'm glad I don't have your Karma !
    :p
  17. Jan 4, 2012 at 10:01 AM
    #317
    tacoman15
    tacoman15 Boobies
    Northeast Georgia
    it's not necessarily my karma...it is usually just me opening my mouth too soon.
    oh wait, that is karma isn't it? :(
  18. Jan 5, 2012 at 5:53 AM
    #318
    Swampmonkey
    Wes
    Fairhope, AL
    Do the tc uca's come ready to install? Wheelers reads as if you gotta order ball joints bushings etc. Can someone clarify? Thanks.
  19. Jan 5, 2012 at 9:31 AM
    #319
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    It should come with all bushings and hardware needed. You are talking about the uniball set up though right? It doesnt use a ball joint on top anymore and it will come with the uniball already pressed in
  20. Jan 5, 2012 at 9:39 AM
    #320
    Jez
    Jez Hittn' easy steet on mud tires
    Ohio
    06 Black DC TRD SR5
    K&N air intake, Fox 2.5 coilovers, Total Chaos UCA's, AllPro Expo rear leaf pack, Fox 2.0 rear shocks, Diff Drop, U-Bolt Flip kit, Drive Shaft shim kit, Weathertech's, Borla cat back, Ultra Gauge,Clarion Radio, 18% tinted windows all the way around, smoked tail lights and rear break light, painted front chrome grill black, stained yellow fog lights, black head light mod, Interior LED kit, LED reverse lights, black leather arm rest mod
    Great write up! Subd
