Total Chaos UCA how-to Install
Discussion in 'Suspension' started by SILVER06TRD, Sep 14, 2008.
  1. Jan 5, 2012 at 9:56 AM
    #321
    Swampmonkey
    Swampmonkey Well-Known Member
    Wes
    Fairhope, AL
    2011 Prerunner TRD DC
    UWS black low profile toolbox, TRD intake, TRD exhaust, TC uca's, Rear 2" toytec aal, OME Front and Rear shocks, OME 885s, NFABs
    I'm just making sure its the set ready to go out of the box for around$700.
  2. Jan 10, 2012 at 6:57 AM
    #322
    Swampmonkey
    Wes
    Fairhope, AL
    Can't find any superlube in my area. What other grease can I use on my TC uca's. Closest I can find is Mobil 1 synthetic. Or should I just order some superlube.
  3. Jan 10, 2012 at 6:59 AM
    #323
    Jez
    Jez Hittn' easy steet on mud tires
    Ohio
    06 Black DC TRD SR5
    K&N air intake, Fox 2.5 coilovers, Total Chaos UCA's, AllPro Expo rear leaf pack, Fox 2.0 rear shocks, Diff Drop, U-Bolt Flip kit, Drive Shaft shim kit, Weathertech's, Borla cat back, Ultra Gauge,Clarion Radio, 18% tinted windows all the way around, smoked tail lights and rear break light, painted front chrome grill black, stained yellow fog lights, black head light mod, Interior LED kit, LED reverse lights, black leather arm rest mod
    I used white lithium marine grease on mine and I don't have any squeaks.
  4. Jan 10, 2012 at 7:55 AM
    #324
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Your talking about the inners right? You DO NOT want grease on the uniballs
  5. Jan 10, 2012 at 8:18 AM
    #325
    Jez
    Ohio
    06 Black DC TRD SR5
    I took a dab of grease on my finger and put a very light coat on the inside of the uniballs before I put the sleeves in. Should I not have? Curious why not?
  6. Jan 10, 2012 at 8:19 AM
    #326
    Jez
    Ohio
    06 Black DC TRD SR5
    I was originally talking about the bushings and the fittings on the UCA
  7. Jan 14, 2012 at 12:56 PM
    #327
    RacerP
    RacerP Well-Known Member
    Chicago
    2003 4x4
    7th Injector kit, Trans Cooler, Donohoe c/o's, Billy's in the rear, FJ Cruiser Trail Team SE wheels.
    I have read thru pretty much this entire thread...
    What tool, besides the one available for sale from TC, has anyone used to replace the spindle slugs on a 1st Gen??
    The tool from TC seems so simple that perhaps you can use a socket?
    Any advice?
  8. Jan 15, 2012 at 9:00 AM
    #328
    Cr250jumper
    The moon
    50 shades of tan©
    I have Camburg LT but the slug in the spindle is the same concept. I rented a ball joint press and it wouldnt work so I ended up using a vice and a hammer.
    Set the vice so it is just wide enough to hold the spindle lips and let the ball joint fit through. I didnt care about ruining the ball joint and just hammered it out. Then flip the spindle over and do the reverse on the uniball adapter. You will be hitting the bottom of the adapter on the flat part so as long as you hit square it wont hurt anything. Have a 2nd person watch that the vice is not interfering and the slug is going in straight while you give it firm taps
  9. Jan 17, 2012 at 10:29 AM
    #329
    Swampmonkey
    Wes
    Fairhope, AL
    Alright. Doing things a little backwards but I have my reasons. Just installed my TC uca's first instead of lift. Went fairly smooth thanks to this thread. Without it I would have been lost. Took me about 4 hrs taking my time. Got it aligned cuz it will be a while until I save up for my lift. I'm amazed at how flimsy the stock uca's are. Seems to be steering good just a little stiffer.
  10. Jan 17, 2012 at 10:49 AM
    #330
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    Ive been running Mobil 1 in mine for over 30k and noticed little to no wear of the bushings when I took them apart for their last inspection.
    Why not? I use Wheelers Triflow lube and it keeps dirt out.
    The chrome uniballs TC supplies absolutely suck in any region that see's snow/salt. My balls lasted all of 9 months. Now I use Trilube on my new FK stainless steel balls and they have lasted much longer already.
    TC UCA's are very overrated IMO
  11. Jan 17, 2012 at 10:58 AM
    #331
    Cr250jumper
    The moon
    50 shades of tan©
    Because a uniball has an internal teflon liner. All the lube is doing is attracting dirt unless it is a dry lube. I was saying dont use the mobil 1 on the uniballs. I use Mobil one on my inner rubber bushings too
  12. Jan 17, 2012 at 11:28 AM
    #332
    XXXX
    sKiP
    05 Prius
    You need to check out the tri lube. It forms a protective barrier keeping dirt and grime out. For you guys who play in the dry sand I would assume dry lube is great. For us Northeast guys who play in the snow and mud on a regular basis dry lube is worthless.
  13. Jan 17, 2012 at 12:22 PM
    #333
    Cr250jumper
    The moon
    50 shades of tan©
    Ummm the wheeler tri flow lube says "superior dry lubricant". That is what I use but from Dupont. You keep re-saying the same thing I am saying. Once again my original point was do not use Mobile 1 on uniballs
  14. Jan 17, 2012 at 12:39 PM
    #334
    XXXX
    sKiP
    05 Prius
    Here is it installed on my uniballs
    It's anything but dry when installed and nothing like Dupont's dry teflon spray. It does harden to a waxy consistency that blocks the crap from getting into the liner from the top down totally unlike the Dupont spray
    I'm not full of BS or arguing with you. My issues with dry spray and chrome balls has been well documented by others in my region as well as myself http://www.tacomaworld.com/forum/su...el-uni-ball-tc-uca-05-tacoma.html#post2804791
  15. Jan 17, 2012 at 1:18 PM
    #335
    Cr250jumper
    The moon
    50 shades of tan©
    Oh my, I stand corrected. That is way different than mine, very interesting though
  16. Jan 31, 2012 at 11:47 AM
    #336
    RacerP
    Chicago
    2003 4x4
    Anyone know the dimensions of the UCA bolts on 1st and 2nd gens??
    I know the parts# but I gotta order some sleeves for my custom fabbed uca's and need to figure out what I.D. I need for the sleeves.
    Any difference between the 1st and 2nd gen?? As I already have some sleeves that are too short for mine that I am looking to sell.
  17. Jan 31, 2012 at 12:11 PM
    #337
    XXXX
    sKiP
    05 Prius
    Are you running 1" balls?
    I can get you bolt dimensions off my old worn down bolts from my 08', but IMO you need to call TC and get the facts from them.
  18. Jan 31, 2012 at 1:40 PM
    #338
    RacerP
    Chicago
    2003 4x4
    I am running 1" uniballs...
    But, I am talking the long bolt that goes thru the bushings.
  19. Jan 31, 2012 at 1:48 PM
    #339
    Cr250jumper
    The moon
    50 shades of tan©
    ^Send a PM to MJP2. I know he had to have a custom bolt made that was longer, his is a 2nd gen but I believe they are the same diameter bolt
  20. Jan 31, 2012 at 2:51 PM
    #340
    XXXX
    sKiP
    05 Prius
    ahh...the OE UCA mounting bolt. Yea I was talking about the UCA/spindle bolt.
    If it helps the ID of a 2nd gen UCA bushing sleeve is .5825" per my POS Harbor freight digital caliper
