Total Chaos UCA how-to Install
Discussion in 'Suspension' started by SILVER06TRD, Sep 14, 2008.
  1. Mar 2, 2013 at 11:38 PM
    #361
    1904
    1904 Active Member
    Installed mine today! Great write up
  2. Mar 2, 2013 at 11:42 PM
    #362
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    Me too. This sticky was very helpful.
    But before I started, I had already decided to cut off the bolt heads instead of bending the sheet metal. Local dealership had them instock and I pad $12 each. It took less than a minute to cut off the head with a sawzall and slide them out through the back.
  3. Mar 2, 2013 at 11:47 PM
    #363
    Millertime187
    Millertime187 I'll be your huckleberry!
    David
    Clay City, KY
    1995 Taco
    Just a few little things. It's my DD
    I love mine!!!
  4. Mar 3, 2013 at 6:31 PM
    #364
    bullaculla
    Da big big island!
    Got both sides done now.
    Quick tip on the drivers side.
    There are a few lines(red arrow) in the way of removing/installing the pivot bolt. Remove the two nuts (green arrows) with a 10mm wrench. I got some paracord and made a choker to tie the fuel lines off to the header. There was enough room to slide the bolt back in this way.
    hope this helps somebody :cool:
    pnwovrland likes this.
  5. Mar 27, 2013 at 9:30 AM
    #365
    TRDMike66
    TRDMike66 Well-Known Member
    so. cal.
    2007 TRD SR5 Package
    Bilstiens 5100's all the way around, wet okale seat covers, red led interior lights,Level 8 Guardians wrapped with Hankook Dynapro's 260/70/17 and 35mm caps/black gorilla lugs,sock monkey TRD So Cal Bedside Decals BANKS-Monster Cat-Back Exhaust, Light Racing Upper Control Arms, One of a kind satoshi grille thin lip by Homer Taco.
    quick question i have billies at the highest setting should i install uca's? or are the stock ones fine?
  6. Mar 27, 2013 at 10:11 AM
    #366
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Is your alignment good without them? Do you have the amount of travel you want with your equipment? If it is fine then the next question is how deep are your pockets?
  7. Apr 8, 2013 at 3:51 PM
    #367
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    Ha, easier, but barely. I used a piece of 11-12" 3/8" redirod with a sleeve of tygon tubing over it (just because I had it) to align the the washers & UCA to the truck mounting, sliding the redirod in from the top.That held everything aligned so the cursed long bolt would hopefully be lined up properly when it got pushed in.
    Then cursed, wiggled fuel lines, (driver's side), lined up, tapped the UCA bolt in from the bottom, along with the occasional turning, pushing, and more cursing.
    needless to say this post was a big help, installing Camburg BJ UCA, outside in the rain, last night. Passenger side is tonight's adventure. Should be easier, hope the rain stays away long enough. 24" - 1/2" drive breaker bar is my friend, works well in bending the fender lip.:rain:
  8. Apr 8, 2013 at 10:34 PM
    #368
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    No rain tonight, passenger side in, almost half the time, now that I know what i'm doing. Had a bit of rust in this bolt; looks like it got some moisture trapped in there; cleaned up the bolt, brushed some anti-sieze on it, and got it back in. The clip for the Antilock brake sensor did not line up well on the passenger side; secured with zap strap for now. Added some ABS 1.5" (i think) pipe caps and siliconed them in to cover the Camburg arm BJ. drilled and tapped in a small wood screw in the top to pull off the cover in the future to get at the grease nipple.
  9. Apr 9, 2013 at 6:15 AM
    #369
    Sandman614
    Tim
    '06 SR5 Off Road
    You already bend the metal of the way to slide the bolt out, No reason to fuss with the lines to get the bolt in the opposite direction. I found the driver side a lot easier to get the bolt in and out.
  10. Apr 9, 2013 at 6:17 AM
    #370
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    On some trucks, the body is over slightly to one side, than others. This can make the difference.
    techbill likes this.
  11. Apr 9, 2013 at 4:20 PM
    #371
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    ^^^ Interesting, I did find I had to bend the sheet metal a bit more on the passenger side to get the bolt out.
  12. Jul 3, 2013 at 5:46 PM
    #372
    MagneticTaco
    MagneticTaco Well-Known Member
    Kiel
    Louisiana
    2013 DCSB Magnetic
    3" toytech lift, front spacers, AAL in the rear, 285/75r16 goodyear duratrac, blacked out emblems and taillights, pained grill
    sub for install
  13. Jul 13, 2013 at 2:52 PM
    #373
    Bengland25
    Bengland25 Never Forget! 343
    Bradley
    Southern California
    09 Tacoma TRD
    MB Chaos 6 17" wheels, BF Goodrich All-Terrain TA/KO LT265-70R17, Anytime Fog Lights, Anytime Backup Camera, Bed Lights, Tailgate Lock, Light bar with 3 Hella 700FF's, Realtree Camo arm-rests, Anytime DTRL (With Switch), Blue Seas Fuse Block and Circuit Breaker, Custom Bed Light-Bar, Cobra 29 LTD Chrome, 4' Firestik, Masterlock Hitch Key Safe, Bed Storage Compartment Locks, Custom Shovel Bracket Mount, Flag Pole Mount (RED SOLO CUP FLAG!), DIY Washable Cabin Filter, URD MAF Cal., Homelink Garage Door Opener, Volant CAI w/ Ram Scoop, AeroTurbine 3030XL, URD Short Throw Shifter, Custom Satoshi, Blitzpro 21S, 2 Blitzpro 6LZ's, Blitzpro 6D, BAMF Sliders
    Wanting to get this done today or tomorrow. What type of grease do I need for the bushings and did you guys put anything on the ball joint??
  14. Jul 13, 2013 at 3:59 PM
    #374
    Bengland25
    Bradley
    Southern California
    09 Tacoma TRD
    Also, I re-tapped the holes for the zerks, they thread nicely but TC says not to over tighten, you guys just finger tightening these or what? Don't want to collapse them by over tightening but also don't want to have issues with them being too loose..
  15. Jul 17, 2013 at 7:26 PM
    #375
    MagneticTaco
    Kiel
    Louisiana
    2013 DCSB Magnetic
    I installed mine last week and I also had more trouble with the passenger bolt coming out. Other than that went really smooth. The ball joint is self lubricating according to the instructions and does not need any grease. I used green grease for the bushings. Got it aligned the next day and made a huge difference compared to stock with my 3" lift. Not a bad install besides getting the bolts in and out. Really happy with the outcome
  16. Jul 18, 2013 at 3:10 PM
    #376
    Bengland25
    Bradley
    Southern California
    09 Tacoma TRD
    Yeah mine wasn't too bad at all either, got it all done this morning and love the ride!
    Anyone ever not need an alignment after installing these? Mine is just a straight as the day I drove it off the lot!! Was absolutely stoked and amazed at the same time
  17. Jul 19, 2013 at 11:44 AM
    #377
    MagneticTaco
    Kiel
    Louisiana
    2013 DCSB Magnetic
    My alignment wasn't too bad, prob the same as it was with the stocks which was ok after the lift. I had a 6 month unlimited alignment with tire kingdom so the new alignment was free. Figured why not
  18. Jul 23, 2013 at 7:15 PM
    #378
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    ^^ is this bracket new? TC UCA purchased last week.
  19. Jul 23, 2013 at 8:08 PM
    #379
    MagneticTaco
    Kiel
    Louisiana
    2013 DCSB Magnetic
    Is that the TC UCA's. In black?
  20. Jul 23, 2013 at 8:10 PM
    #380
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Yeah it's newer. I bought a set in 08 and it wasn't there, but my wife's have them.
