Total Chaos UCA how-to Install
Discussion in 'Suspension' started by SILVER06TRD, Sep 14, 2008.
  1. Apr 15, 2009 at 10:52 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    When lifting, you loose caster. Aftermakrket UCA's can add caster to the geometry so the vehicle can be aligned back to stock specs. They are also much stronger than the OEM UCA's, and the Uniballs are much stronger as well. Many UCA's are fully rebuildable and seviceable.
    MateoTorgy and lynyrd3 like this.
  2. Apr 16, 2009 at 6:36 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Im not really sure..:)
  3. Apr 16, 2009 at 7:20 AM
    hendooman
    hendooman The Stroker Ace
    Jeff
    KC
    2009 Tacoma OR (SOLD); 2015 TRD PRO 4Runner
    Toytec TRD PRO LIFT with 1.5 SAW in rear, 255 Coopers, Baja Rack, Southern Style Front Bumper, Warn Wireless Winch, DeMello Sliders.
    How much $$$...looking good. I put some 5100's on a couple weeks ago at 1.75. Took it to my dealer and got the rear TSb the next day. When I read my service receipt it said it was aligned to Toyata factory specs. The ride is great, no wandering...would the Total Chaos make that much difference?
    I really just want them so I have an excuse to take the front suspension apart again...so much fun. No problems whatsoever on installing the 5100's. THe spring compressor was easy, and did not seem dangerous at all....
  4. Apr 16, 2009 at 7:56 AM
    LonghornTaco
    LonghornTaco Can you pass the bailout please?
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
    Only going up 1.75", I think you're ok. I think if you go over 2" is where you start to have some issues...
    As always, Chris, correct me if I'm wrong.... :)
  5. Apr 16, 2009 at 8:10 AM
    hendooman
    Jeff
    KC
    Chris...how much$$$
  6. Apr 16, 2009 at 8:27 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I would have to see the print out, but, Your correct. Most issues arise after 2"+ lift. :)
    Generally, the TC UCA's can be found for just over $600.00.......around $620.00 to $650.00. Money well spent, IMHO.
    lynyrd3 likes this.
  7. Apr 16, 2009 at 8:29 AM
    LonghornTaco
    Minnesota
    Mine were $690 shipped from Wheelers...
  8. Apr 16, 2009 at 8:32 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ouch.....Now that they are a sponser, maybe they will cut us a break.
  9. Apr 16, 2009 at 8:39 AM
    LonghornTaco
    Minnesota
    This was 6 months ago... Maybe they've come down a bit??
  10. Apr 16, 2009 at 12:52 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Wheelers is awsome..........4wheel Parts sucks.
    jackn7 likes this.
  11. Apr 16, 2009 at 4:56 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Whew! Yeah...4wheel parts sucks.
    jackn7 likes this.
  12. Apr 16, 2009 at 7:22 PM
    Sandfire
    Sandfire Well-Known Member
    southwest midwest
    06 TRD Sport DC 4x4 silver
    OME 885 springs with OME N140s shocks, Total Chaos UCA's, TSB AAL, OME N182's, MT BAHA ATZ 4ribs.
    FYI, I bought my TC UCA's from Northridge toyota in Calif., they had free shipping and I paid $595. I dealt with Carrie, she was great to work with.:)
  13. Apr 25, 2009 at 10:36 PM
    Mrgoody86
    Mrgoody86 Well-Known Member
    Alex
    Lincoln, CA
    2009 Tacoma 4x4, DBL Cab, Sport Edition
    K&N CAI, Custom duel exhaust with jones muffler, Viper Alarm w/ remote start, Cobra radar detector hard wired and mounted above rear view mirror. Leather Arm rest mod, LED cabin light, Redline elite hood struts. Bilstien 5100's all around, front coilover set at 2.5", Toytec aal, and Total Chaos UCA's, Scangauge II, Front Diff Drop kit, Yellow Lamin-X fog light covers, 6K HID conversion Kit for Headlights
    Hey guys I just got my tc uca's, Have a question about removing the top bolt on the stock uca's. It says in the write up to bend the fender well, do I bend it towards the center of the cab or out towards the wheel area? What is the simplest way to acomplish this task any insight would be awsome. btw I am super excited about having these installed.
  14. Apr 25, 2009 at 11:36 PM
    LonghornTaco
    Minnesota
    You'll need to bend them out away from the truck. I used a pair of channel locks, but something with longer teeth would have been helpful. Just take your time and it'll come out.
  15. Apr 25, 2009 at 11:38 PM
    #35
    Mrgoody86
    Alex
    Lincoln, CA
    Thanks Longhorn I appreciate everything.
  16. Apr 26, 2009 at 6:50 AM
    #36
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Dont try and bend alot. Just a little bit. Enough for the bolt head to clear. Then, Tap the UCA bolt thru with a long 3/8" extension. Make sure the UCA washers dont "follow" the bolt, as they will cause it to bind up.
  17. Apr 26, 2009 at 7:59 AM
    #37
    Mrgoody86
    Alex
    Lincoln, CA
    Awesome info. thanks chris.
  18. Apr 26, 2009 at 8:06 AM
    #38
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    No problem.
  19. Apr 28, 2009 at 11:22 AM
    #39
    ccoorreeyy
    ccoorreeyy www.EvolvedFinance.com
    Corey
    Los Angeles (South Bay)
    08 Double Cab 4x4 SR5 Debadged
    BHLM, Revenge Fab Rock-Sliders, BFG TA KO's, N-Fab light bar with 4 Hella 500's, Rear Suspension TSB, TRD Exhaust, CB Radio, 100W Ultra bright headlights, JBL Sound
    Can anyone tell me what the purpose of UCA's are? I know that they help in handling... Or at least that's what I think. And, they're better of off-roading and stuff like that, but I don't know why.
    Thanks!
  20. Apr 28, 2009 at 12:02 PM
    #40
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    More range of motion with a Uniball. Stronger, rebuildable, and corects for lost caster.
