Total Chaos UCA how-to Install
Discussion in 'Suspension' started by SILVER06TRD, Sep 14, 2008.
  1. Jul 24, 2013 at 5:12 AM
    #381
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    They're not black, still the gunmetal looking grey
    That's what i thought, the kit still came with 2 zip ties and the drawing doesn't show it. I'm glad they put it there..
  2. Jul 24, 2013 at 5:21 AM
    #382
    Large
    Large Red
    There is an easy way to get the bolt back in the way it came out on the passenger side. I used a 4' pry bar and put it through the grill, the head of the bolt was perfectly in line with it, tap it in with a hammer. This was my 2nd time installing these and I wish I had known this little trick the first time.
  3. Aug 6, 2013 at 6:13 AM
    #383
    HazardousTaco
    HazardousTaco New Member
    96 tacoma 4wd
    3 1/2 inch toytec lift 33 inch procomp m/t magnaflow exhaust and other doo dads
    I was woundering if they made a uni ball joint upper control arm like these for the 1st gen taco's?
  4. Aug 6, 2013 at 6:32 AM
    #384
    kigmob
    kigmob Well-Known Member
    James
    New Orleans
    97 TRD S/C 4x4 V6 5spd
    ICON/TC TRD Supercharger URD 2.2 and 7th
    Yes. I see this is your first post. Try reading through some stickies and use the search function in the toolbar above to find any answers to questions you may have. More than likely your questions have already been asked and answered..
  5. Aug 6, 2013 at 9:37 AM
    #385
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    Its for securing the ABS sensor wire in the stock location.
  6. Aug 8, 2013 at 1:35 PM
    #386
    gretch6364
    gretch6364 Active Member
    Dumb question. How do the aftermarket UCA's provide more travel? Obviously, they would allow more travel due to their shape, etc., but you won't get more travel by just sticking them on your truck, right? You would need to adjust the bump stops and coilovers...right?
  7. Aug 24, 2013 at 5:26 PM
    #387
    drunktaco
    drunktaco Well-Known Member
    Sage
    Southwest Va
    Icon ext travel C/O's, Total Chaos UCA's, King R/R shocks, All-Pro leaf pack, lights, RCI skid, Brute Force sliders, ect.
    Anyone know what the torque specs are for the spindle to the upper control arm?
  8. Sep 3, 2013 at 6:34 PM
    #388
    HOOTERBIRD
    HOOTERBIRD Yeah You Right !
    NOLA
    2013 DCSB TRD Sport, 4X4
    Just got a set of the Icon tubular UCAS anybody know how they compare to the TCs? Also what grease should I use for the bushings and for the ball joint?
  9. Sep 4, 2013 at 11:23 AM
    #389
    SpaceBalls
    SpaceBalls Active Member
    Vancouver Canada
    08 Taco trd
    3" block lift 33" BFG's AT
    I thought you can remove the sway bar for more articulation with no problems!!
  10. Sep 4, 2013 at 12:04 PM
    #390
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    You can - mine has been off my truck the last 60,000 miles.
    He obviously is either trolling or had serious issues during his installation or he drove with the bar loose and it slammed into his CV boots. Either way not good.
  11. Sep 4, 2013 at 6:37 PM
    #391
    SpaceBalls
    Vancouver Canada
    08 Taco trd
    ya that makes more sense! forgot to hook up the bar and it hit the boots!!
  12. Nov 12, 2013 at 6:24 PM
    #392
    AWF ROWD
    AWF ROWD ...eats at the " Y " often....
    Doc
    40.102° N, 82.804° W
    '13 BLOWN 4X4 Sport
    TRD Supercharger, Walbro 255 FP Upgrade, aFe Stage 2 si CAI, TRD Acrylic cover by Coupe ADD 1 OIL Catch can/SS hoses, TRD cat back exhaust, URD 2.8" Stealth pulley, 3" lift, Toytec/Bilstein C/O's, Toytec Progressive AAL's, LR UCA's, 5100 Rear Billies, Bi-Xenon HID BHLM Retro's w/ Halos RED LINE Tuning Hood Rods Swaybar Relocate, Line X'd Bull Guard/Step, Hitch, Craven Speed Dual Gauge mount, AEM Boost/AFR Gauges, Windows 20% tint, Weather Tech deflectors, GrillCraft upper and lower, Tacoma Raptor letters, LED Interior/Exterior lighting, Lund 6" Color Matched Oval Side Bars, Webasto 700 II sunroof, Heated Two toned custom leather TRD logo'd, Kenwood Multimedia 6990 HD head unit ,JL Stealthbox sub, Hertz Component speakers,, Entire cab damped with hushmat, Viper Security/Remote start, Weather Tech Liners, Blackened exterior LED Lights, Undercover Top w/LED's, Carbon fiber TRD windshield decal,, TRD stitched leather shift knob, TRD steering wheel emblem,
  13. Dec 4, 2013 at 2:46 PM
    #393
    octoyotaco
    octoyotaco Well-Known Member
    C
    Orange County
    If anyone has a pair of these for a 2nd gen tacoma please let me know. Message me and then ill send my cell #
  14. Jan 8, 2014 at 5:22 PM
    #394
    BBtacosurfer
    BBtacosurfer Well-Known Member
    Dave
    ID
    MGM 2012 4x4
    Do you guys running TC grease them like every 6 months or how often? I'm just worried about the maintenance with these uniballs vs. my Light Racing ball joint UCA. I know Chris 4x4 has ran these for like 4 plus years with no squeaking or problems. Is that consistent with all ya'lls experiences? Any problems with noise?
  15. Jan 11, 2014 at 6:53 PM
    #395
    Chi Taco
    Chi Taco New Member
    Bart
    Orland Hills
    08 trd off road
    K&N CAI, custom grill, light bar,
    I was wondering if the TC arms will also fix the camber issue i have after the 3" lift.
    I had the truck aligned at work and they cant get both sides in spec, after the lift.
    i also have new powersteering rack, new lower arm and alignment cams so everything is brand new and both side cant get in spec after i put the lift on. My tires are getting chopped real bad on the outside because the tires arent sitting flat.
  16. Jan 11, 2014 at 6:54 PM
    #396
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Yes. It allows for the Camber to be set at .4*, while adding Caster.
  17. Jan 11, 2014 at 6:55 PM
    #397
    BBtacosurfer
    Dave
    ID
    MGM 2012 4x4
    ^^^ That's a great question for Chris 4x4. I know the Light Racing have the camber adjustment on the top of the UCA. Just remember that "within" spec when lifted is different. You should be able to get very close to 0 camber with the TC arms I'm assuming.
  18. Jan 11, 2014 at 6:56 PM
    #398
    BBtacosurfer
    Dave
    ID
    MGM 2012 4x4
    And he beat me to it! :D
  19. Jan 11, 2014 at 6:57 PM
    #399
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  20. Jan 11, 2014 at 6:58 PM
    #400
    BBtacosurfer
    Dave
    ID
    MGM 2012 4x4
    Chris, you're still running the same set of TC uppers that you've had for a while now? Just replaced the bushings I'm assuming and maybe uniball or two?
