Total Chaos UCA how-to Install
Discussion in 'Suspension' started by SILVER06TRD, Sep 14, 2008.
  1. Apr 28, 2014 at 9:12 AM
    #421
    TexasTacoLT
    TexasTacoLT Well-Known Member
    Killeen, TX
    '14 TRD Offroad
    3" Lift (ToyTech Coilovers and AAL) Bilstein 5100 Shocks Total Chaos UCAs Method Double Standard 17" BFG All-Terrain T/A KO2 (Removed) 33" BFG Mud Terrain Tires Colormatched Grill surround HomerTaco mesh grill insert Legacy "Toyota" Emblem Shrockworks plate rear bumper All-Pro plate front bumper w/ foglights All-Pro rock sliders Smoked Tail-lights DIY Steel Tailgate reinforcement Locking Tailgate handle Tint (15%) w/ sunstrip Tyger Tonneau cover (Removed) Bestop Soft Topper Bushwhacker colormatched fender flares DIY 8-ball shift knob DIY Amber LED grill lights DIY Debadged WeatherTech floormats Sudued US Flag door decals T-100 style tailgate decal Two way radio w/ 3' whip antenna Warn 8000lb winch CalTrend Neoprene seat covers DIY Bed tie-down anchors
    I just gave the bottom of the bolt a few really hard whacks with a hammer and they popped right out.
    They're not threaded in or anything, which is what I was afraid of.
  2. Apr 28, 2014 at 10:15 AM
    #422
    nvrenuf
    nvrenuf Whatever
    Saint Johns, FL
    '22 TRD Pro Taco; 6MT
    I finally got it. I just went to the auto parts store and bought a pickle fork and 4 pound sledge. A few good solid wacks broke it free.
    Also, I went with the "cutting-off-the-head-of-the-bolt" method to remove the long bolt... too easy. replacement bolts only $12 apiece from dealer.
  3. May 5, 2014 at 7:57 AM
    #423
    SlimBo84
    SlimBo84 Some Guy
    Colorado
    '11 TRD Off-Road
    ATO front bumper, Body Armor rear bumper w/ swing arm, AP sliders and front skid, ATO bed crossbars w/ Thule M.O.A.B. basket, Warn VR8000-s, 285/70R/17 Goodyear Wrangler MT/R w/ Kevlar, 17" XD Series wheels, Fox 2.5 coilovers w/ res., Fox 2.5 shocks w/ res., AP Expo leaf springs, extended rear breaklines, VIAIR HD OBA, 2x 9.5" HID LightForce, Rigid fog lights, and much more to come.
    Where you able to slide the long bolt back in from the other side? Or did you bend back the part of the framing next to the UCA?
  4. May 5, 2014 at 11:42 PM
    #424
    double dee
    double dee Well-Known Member
    Arizona
    So I'm going to be un-installing these but I did not install them so I have no experience with them. Should I do anything different other than follow this but in reverse order?
  5. Jun 3, 2014 at 3:17 PM
    #425
    4WDTrout
    4WDTrout Perpetually dreaming of tall trees & rivers
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    How long did it take everyone to install the new UCA's?
    Did you use any grease....if so, what kind/brand?
    Did most people buy new nuts & bolts and cut the old ones off?
  6. Jun 3, 2014 at 3:21 PM
    #426
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Takes about 40 mins or so if you've done it a couple times. About an hour or so if its your first time.
    Rub grease ALL OVER the bushings before installing them. Don't install them, then squirt a little in the zerk. RUB grease all over BEFORE installing them in the UCA.
  7. Jun 3, 2014 at 9:22 PM
    #427
    TacoBrah
    TacoBrah Well-Known Member
    Sean
    Icon stage 1, 255/85/16 KM2
    Its pretty simple but getting the UCA bolts out/in can be quite an ordeal. I used some grease that came with the UCAs, forgot what type it was though.
  8. Jun 3, 2014 at 10:47 PM
    #428
    double dee
    Arizona
    Total chaos recommends super lube. Depending on how old your truck is will determine the condition of the bolt and if you can reuse it. As long as the threads aren't rusted you can reuse it.
  9. Jun 4, 2014 at 4:08 PM
    #429
    presto
    presto Well-Known Member
    Topher
    san francisco
    2000 T4R 4x4
    Fully armored on 33’s
    i figure this might help someone someday. This is for all the 1st gens.
    Basically the hardest part is removing the old UBJ and installing the TC puck in place of the UBJ. This really only helped with the installation of the TC puck. Not sure if this has been done before but my buddy came up with this idea. We put the puck in the freezer for about an hour or so. Then took a propane torch and heated up the hole for the puck on the spindle. The puck literally almost went in by hand. Took two taps of a hammer and bam.
    edit:
    I tried using the TC BJ removal/install tool.. what a joke. i almost broke 3x c clamps haha..
    ended up smacking the BJ out with a 20 oz hammer.
  10. Jun 5, 2014 at 7:26 AM
    #430
    TexasTacoLT
    Killeen, TX
    '14 TRD Offroad
    Having never worked on suspension before, it took me about an hour and a half to get the first one installed. After the first one, the second took me about 30 min. The hardest part for me was getting the long bolts out; I used the fender bend method. If I were to do it again, I would have cut 'em off and bought new bolts. I also ran into some trouble getting the ball joint bolts out; ended up just whacking it a few good times with a hammer.
    For grease I used some multipurpose grease that I picked up from Autozone; not sure what brand.
    All in all, it's pretty straight forward. Good luck.
  11. Jun 5, 2014 at 9:00 AM
    #431
    4WDTrout
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    Sounds good. Thank you for all the replies guys, I appreciate it. I know it's not like rebuilding an engine or anything but, I just wanted to have all my ducks in a row before I started the job.
  12. Jun 10, 2014 at 12:51 PM
    #432
    Griff 99 TRD
    Griff 99 TRD Well-Known Member
    '99 Tacoma TRD Extended Cab 4x4
    K&N FIPK OME w/883s Air Raid TBS Trailgear Bumper Smoked Lights Mean Green Alternator JL Audio Sub/Amp HAT Speakers Pioneer Head Unit ARB bumper XD 128 16x8 wheels Odyssey battery BAMF Sliders Camburg UCAs
    Guys, I am definitely in a world of POOP with this!!! Yes, I realize this thread is dedicated to installing Total Chaos Upper Control Arms, but I'm trying to install Camburg and I hope the issue I'm having may be more universal per say.
    So, I have a '99 Tacoma SR5 V6 TRD and I can't get the snap ring to lock in between the slug and spindle. I first used a c-clamp style press, then I took it to a local shop where they used a 30 ton press and there still wasn't enough clearance. The guy said I would have to grind down the top of the spindle. Thoughts? Man, this project has been a huge a PITA!!!
  13. Jun 10, 2014 at 1:09 PM
    #433
    presto
    Topher
    san francisco
    2000 T4R 4x4
    Don't grind IMO. Doesn't sound right. If I were you I would take them out and start over. Make sure you clean the surfaces pretty nicely.. Te easiest way to do it is stick the puck into the freezer for an hour and heat up the spindle with a torch (only where you put the puck in). Should be able to tap it in with about two taps of a hammer.
  14. Jun 10, 2014 at 1:22 PM
    #434
    presto
    Topher
    san francisco
    2000 T4R 4x4
    Oops didn't mean to double post...
  15. Jun 10, 2014 at 1:39 PM
    #435
    BBtacosurfer
    BBtacosurfer Well-Known Member
    Dave
    ID
    MGM 2012 4x4
    just wanted to say I read a really informative article in 4wd magazine (or something like that) about Total Chaos...These will be my next purchase when I upgrade my Light Racing UCAs...Total Chaos FTW
  16. Jun 10, 2014 at 7:13 PM
    #436
    Griff 99 TRD
    Thanks, man! I'll give that a try.
  17. Jun 10, 2014 at 9:03 PM
    #437
    presto
    Topher
    san francisco
    2000 T4R 4x4
    no prob. let me know how it turns out.
  18. Jun 11, 2014 at 10:13 AM
    #438
    4WDTrout
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    Subbed.
  19. Jun 19, 2014 at 8:54 PM
    #439
    tacobrumz
    tacobrumz Active Member
    Tacoma
    Total Chaos Dual Shock with spindle gussets
  20. Jun 24, 2014 at 8:31 PM
    #440
    Griff 99 TRD
    I apologize for the late update, but I was in route for a flight within 30 minutes of finishing the project. Thanks for your help, guys! I finally got the slug through the spindle after a little sanding/grinding to get the extra 'hair' clearance required. So far, so good! The truck seems to ride better with the new UCAs...post-alignment, of course.
