Total Chaos UCA how-to Install
Discussion in 'Suspension' started by SILVER06TRD, Sep 14, 2008.
  1. Oct 9, 2015 at 8:49 PM
    #481
    tacobrumz
    tacobrumz Active Member
    Tacoma
    Total Chaos Dual Shock with spindle gussets
    The zerks are pipe threads so they should only go in until they're tight
  2. Oct 9, 2015 at 8:49 PM
    #482
    Uncle Creepy
    Uncle Creepy Well-Known Member
    Jalopy
    They should just screw right in and you don't have to bottom them out. If not, try cleaning out the threads and try again.
  3. Oct 9, 2015 at 8:51 PM
    #483
    NumNutz
    NumNutz One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
    I know they're not suppose to sit flush with the UCA, but they seem very hard to screw in. I know they're hollow and I don't want to snap them off.
  4. Oct 9, 2015 at 8:52 PM
    #484
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    I used a tap to clean the powder coat out of the threads. It helped a little but I still had some trouble getting the zerks in. Plus they might not all face toward the tire like the pictures show. It's not a very good design.
  5. Oct 9, 2015 at 8:54 PM
    #485
    NumNutz
    Virginia Beach, VA
    Lots.
    I'll look and see if I have a die that will fit. As far as greasing goes, how do you know if you are greasing the UCAs the proper amount so as to not "mushroom" the bushing?
  6. Oct 9, 2015 at 9:22 PM
    #486
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    The nut is ny-lock so it doesn't need much torque. I cranked it pretty tight and didn't have any trouble with bushing deformation. Make sure there is no grease on the threads tho and prolly use blue thread lock. The movement of the arm can loosen the nut.
  7. Oct 10, 2015 at 6:32 AM
    #487
    NumNutz
    Virginia Beach, VA
    Lots.
    Are these zerks installed deep enough?
  8. Oct 10, 2015 at 6:32 AM
    #488
    G.T.
    G.T.
    CONUS
    Yes.
  9. Oct 10, 2015 at 6:58 AM
    #489
    G.T.
    G.T.
    CONUS
    I know it's been posted here in this thread at least twice but not everyone checks each page. Read your printed install instructions and then review this video.
    One thing that catches allot of people out are the zerks. If you do not have a tap then tighten them until they bite and then back them off to clear the thread. You will probably have to do this a half dozen times per zerk. And remember that NPT is a different type of thread and they will not "bottom out."
    Also double check the UCA orientation before bolting them up. It is very easy to mistakenly put them in on the incorrect side as well as upside down. As convinient as it would be remember that the zerks do not sit on the top.
    scocar and Rippa like this.
  10. Oct 10, 2015 at 8:24 AM
    #490
    Griff 99 TRD
    Griff 99 TRD Well-Known Member
    '99 Tacoma TRD Extended Cab 4x4
    K&N FIPK OME w/883s Air Raid TBS Trailgear Bumper Smoked Lights Mean Green Alternator JL Audio Sub/Amp HAT Speakers Pioneer Head Unit ARB bumper XD 128 16x8 wheels Odyssey battery BAMF Sliders Camburg UCAs
    I used a tap to ensure the threads were good on both my camburg and TC UCAs
  11. Oct 10, 2015 at 8:42 AM
    #491
    NumNutz
    Virginia Beach, VA
    Lots.
    I haven't torqued everything down yet, but why would the uca being hitting the coil?
    It's like there's too much down travel. I'm having to jack the LCA to keep the uca from resting on the coil
  12. Oct 10, 2015 at 9:05 AM
    #492
    Griff 99 TRD
    Pics might help out with determining a diagnosis. I didn't experience that particular issue when I installed my UCAs. This may be a dumb question, but do you have the UCAs installed on the correct side(s)?
  13. Oct 10, 2015 at 9:07 AM
    #493
    mcnkl
    mcnkl Active Member
    calgary,alberta
    I've been running ome 3" lift for about six months now. I just picked up a set of total chaos uca since im free this weekend I want to install them. Would I have to get an alignment right after? or should I install the day before my alignment date (2weeks away)? thanks
  14. Oct 10, 2015 at 9:14 AM
    #494
    NumNutz
    Virginia Beach, VA
    Lots.
  15. Oct 10, 2015 at 9:24 AM
    #495
    CodeTaco
    CodeTaco Well-Known Member
    HB, CA
    2008 Tacoma Access Cab 4x4 TRD
    Bilstein 5100s (f @ 1.75); 5100s rear; All Pro Expedition Springs; PowerStop slotted discs; Akebono ceramic pads; Wheeler's braided brake lines; Prodigy trailer-brake system; heavy duty towing set-up (for off-road trailer); WeatherTech mats (awesome); 5% Ceramic Tint; matching Snug Top (mid) with racks; Thule racks; dipped badges; 17" 2014 OEM 5-spoke 4-runner rims; 265/70/17 Bridgestone Desert Duelers (for now); Siriusxm radio; more on the want list...
    Man......those just look badass. Now I'm off to order a set. You guys are just free-wheelin' on here and causin' me to spend all of my cabbage. I really need to quit stopping by this place.... :ballchain:
    techbill likes this.
  16. Oct 10, 2015 at 10:04 AM
    #496
    alphabravo
    Christopher
    Canada via FL
    2003 Tacoma TRD
    i dont think there is any limiter for down travel. if you expect to full droop or jump sweet jumps you might need straps
  17. Oct 10, 2015 at 10:21 AM
    #497
    G.T.
    G.T.
    CONUS
    I can see the rubbing issue you have, is there a chance you can take a picture of the whole works - not as zoomed in - and indicate which side of the truck it is for us? And to repeat what @Griff 99 TRD asked, are you certain that they are on the correct sides? He asked that as UCA/spring collision is one of the issues that people face when the UCA's are either upside down and/or mounted to the incorrect side. Zerks should be facing down and stickers facing up and to the front of the truck.
    Excited to hear about you getting it sorted chalking up another success for the books.
    Getting allot of miles out of this video this week...
  18. Oct 10, 2015 at 10:32 AM
    #498
    Griff 99 TRD
    I, too, am running OME. I have the 883 springs, though. I've read and have been told by a few folks to wait a few hundred miles prior to getting your wheels aligned and balanced. I'm assuming the reasoning behind this thought process is to allow your springs and shocks to break in a little bit so you can get the caster/camber close to factory specs. Imo, it was a good call purchasing after market UCAs. I definitely noticed a difference when I installed mine.
  19. Oct 10, 2015 at 10:52 AM
    #499
    NumNutz
    Virginia Beach, VA
    Lots.
    Me too lol. Pretty sure everything is installed correctly. I'm thinking it's the increased diameter of the 700# coils causing me issues
  20. Oct 10, 2015 at 11:28 AM
    #500
    Griff 99 TRD
    I don't think the 700lb springs have a larger diameter than the 650lb springs. Springs are married to the shocks based on the diameter of the shock i.e. 2.5 or 2.0. My guess is the UCAs are rubbing only when the UCAs are at "full droop" meaning fully extended toward the ground. Once you put your wheels on you should be good to go. However, I feel I should ask, are the uca rubbing in your most recent picture? It looks like you installed them correctly.
