Total Chaos UCA how-to Install
Discussion in 'Suspension' started by SILVER06TRD, Sep 14, 2008.
  1. May 9, 2009 at 8:36 PM
    #81
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I cant say I never made mistakes.....Sorry to hear, Man....
  2. May 9, 2009 at 9:40 PM
    #82
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Sorry to hear that mytoy but hey you got most of it done. lol.
  3. May 10, 2009 at 1:01 AM
    #83
    SILVER06TRD
    SILVER06TRD [OP] Well-Known Member
    AZ
    06 TRD
    de-badged, color matched grill, trd intake, trd short shifter, 3" skyjacker coilovers, rear aal, doug thorley long tube and y-pipe, urd catback, high flow cats, uni-chip, hellwig rear sway bar.
    Sorry bro...Chris will always help with an answer.
  4. May 10, 2009 at 5:48 AM
    #84
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    :D
    Hey...I think we need to go fishing again. :)
    Inacomalv likes this.
  5. May 10, 2009 at 6:00 AM
    #85
    SILVER06TRD
    AZ
    06 TRD
    Yeah, man...we should also hit up a ball game. See what the wife thinks huh??
  6. May 10, 2009 at 6:34 AM
    #86
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Sweet! Wife is fine with anything.
  7. May 10, 2009 at 6:42 AM
    #87
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Hey! I tried to call you, but it says your not reachable....You on a job out of the country????
    Lake Pleasant is at higher level than it has been in over 7 years! Its 100% capacity. :woot:
  8. May 10, 2009 at 7:54 AM
    #88
    SILVER06TRD
    AZ
    06 TRD
    Yeah been away for a while...be back soon enough though. Wow! full up huh? Nice...you been out with the boat or what?
  9. May 10, 2009 at 7:58 AM
    #89
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Yeah Man...I was out there on Tuesday. Dropped the boat in the water at around 9:00 AM, and virtually had the lake to ourselves! :D Looks like there should be some good fishing, as alot of the mountains are now under water...
  10. May 10, 2009 at 8:08 AM
    #90
    SILVER06TRD
    AZ
    06 TRD
    Ahh, nice huh?? I'll have some time to head out later this summer if you're around. I want to try and fish a coupe of times.
  11. May 10, 2009 at 8:11 AM
    #91
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Let me know, Buddy!
  12. May 10, 2009 at 8:20 AM
    #92
    SILVER06TRD
    AZ
    06 TRD
    Will do definitely bro...I'll get in touch when I get back.
  13. May 19, 2009 at 1:07 PM
    #93
    nurseboy
    nurseboy Well-Known Member
    Jan
    Riverside, Ca
    This install was not that bad at all. jdkeller and I just had a bitch of time removing the dirver side bolt because of the thicker inner fender wall, and putting in back on because having to line it up.
  14. May 19, 2009 at 1:09 PM
    #94
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Tapping it with a 3/8" 6" long extension makes it MUCH easier.
  15. May 19, 2009 at 1:10 PM
    #95
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    he meant lining it up to get it started with those metal lines in the way i bet
  16. May 19, 2009 at 1:11 PM
    #96
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Ah....The fuel lines. There is room, but just.
  17. May 19, 2009 at 1:13 PM
    #97
    nurseboy
    Jan
    Riverside, Ca
    yea we did that, it was just having to bend the inner fender because mine was a lot thicker then the passenger. jdkeller said his passenger was harder then his drivers..kinda weird...
    yea. we ended up bolting the brackets off those to line the bolt better with the UCA, still kinda had to hammer it in though
  18. May 19, 2009 at 1:22 PM
    #98
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Hmmm, considering this for my prerunner but not sure if it's totally (no pun) necessary. Am lifted 2.5 in front with 5100s/TRD springs but is only 2wd & will see limited offroading. Thoughts?
  19. May 19, 2009 at 3:05 PM
    #99
    austinmacry
    austinmacry Active Member
    Colorado Springs
    TRD Off-road
    Holy shizer! Lake pleasent at 100%! I havent seen that in a long time. Its probably packed with the limited parking areas though due to the extra water.
  20. May 19, 2009 at 3:24 PM
    #100
    austinmacry
    Colorado Springs
    TRD Off-road
    They dont have tc uca's for an 04 do they? I was looking but am I just blind?
    If not what kind of uca's should I get? Im planning on getting the toytec coilovers and aals with the blistens on the rear.
