Total Chaos UCA how-to Install
Discussion in 'Suspension' started by SILVER06TRD, Sep 14, 2008.
  1. Jun 7, 2009 at 4:50 PM
    #121
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Use an extension to clear the fender.
  2. Jun 7, 2009 at 4:51 PM
    #122
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    Where do get that type of extension? Autozone?
  3. Jun 7, 2009 at 4:53 PM
    #123
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I got my Extensions at Sears......I think I have a couple from Napa, and Home Depot too.....
  4. Jun 7, 2009 at 4:58 PM
    #124
    jdkeller
    Jonathan
    Inland Empire, Ca
    Thanks chris.
  5. Jun 7, 2009 at 4:59 PM
    #125
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  6. Jun 8, 2009 at 12:09 AM
    #126
    SILVER06TRD
    SILVER06TRD [OP] Well-Known Member
    AZ
    06 TRD
    de-badged, color matched grill, trd intake, trd short shifter, 3" skyjacker coilovers, rear aal, doug thorley long tube and y-pipe, urd catback, high flow cats, uni-chip, hellwig rear sway bar.
    Hey Chris....you going to this cleghorn run??
  7. Jun 8, 2009 at 2:02 AM
    #127
    jdkeller
    Jonathan
    Inland Empire, Ca
    i definitely think you guys should. its not too far.
  8. Jun 8, 2009 at 5:54 PM
    #128
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Havent heard about it, buddy...Where and when?
  9. Jun 8, 2009 at 8:00 PM
    #129
    vwguy60
    vwguy60 Well-Known Member
    Southern California
    2009 TRD Sport DC LB
    Toytec Ultimate Lift Kit, TC ucas, TRD CAI, powder coated OEM tube steps, powder coated TRD skid plate.
    Hey Chris... I got my TC UCAs today and regarding the zerk fittings... The problem is because of the super thick powder coating TC uses. I just chased the threads with a 1/4"-28 tap (the same thread and pitch as the zerk fitting). Rather than buying a smaller threaded zerk and cross threading them in, just chase the threads to clean out the powder coating. Just an FYI. Hope all is well old man!
  10. Jun 8, 2009 at 8:02 PM
    #130
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I've dont that...SOme of the zerks are the worng size.
    WTF is with the "Old Man" crack?
  11. Jun 8, 2009 at 8:30 PM
    #131
    vwguy60
    Southern California
    After learning you had an Interceptor, I figured you were at least as old as I! Hope you didn't take it personally! :)
  12. Jun 8, 2009 at 9:20 PM
    #132
    jdkeller
    Jonathan
    Inland Empire, Ca
    Its here in socal. On the 27th. Oakleytrd is coming out for it. Check out the link in my sig.
  13. Jun 8, 2009 at 9:48 PM
    #133
    mountainwolfpup
    mountainwolfpup Ford Guy (Formerly known as a Toyota Guy)
    Vancouver, WA
    2015 Ford F150 Lariat FX4 3.5l Eco
    First month of ownership... This month I'm removing front air dam, and also Rhino lining the bed.
    So, what are UCAs and what do they do? Well, Chris4x4 would be perhaps the best member to lay this one out.. but I'll give it a go...
    The upper control arm is one part of a front suspension system. The Tacoma 05+ control arms were designed to remove flex, in order to achieve more predictable and enhanced handling as well as improved traction capabilities on road.
    Upper arm - takes driving and brake torque and must handle the stress associated with the axle articulation. So they need to be strong! UCAs are usually formed in a triangular shape to handle the stress put on them.
    Lower arm - supports the shock/spring to allow up-and-down motion of the axle and the wheel assembly.
    As an active suspension component, the UCAs pivot in two places, where one end is attached to the suspension frame, and the narrow end is attached to the steering knuckle and pivots on a ball joint.
    OK, most people need/want new UCAs when they change their suspension.. for one (or both) of two reasons:
    1) To get correct alignment. Raising the truck with a lift of any kind makes it more difficult (or even impossible) to get a good strait camber dialed in... and may necessitate new UCAs to properly align the front. [If you consider the cost of tires and that an out of alignment truck will wear them down quickly, a set of new UCAs are worth it] For more info on Camber, Caster, and Toe (a.k.a. the front end alignment) see this link picked at random from a Google search I did on it just now:
    http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=4
    2) To get more travel. The stock UCAs are limited in the vertical travel they allow.. limiting off road performance. (If you drive mostly on road then you wouldn't care about the extra travel) So, new UCAs designed to work with your 2"-3" Taco lift and the correct shock setup can give you a better performing off road racer.
  14. Jun 8, 2009 at 10:26 PM
    #134
    mountainwolfpup
    Vancouver, WA
    I got my TC UCAs put on and they look AWESOME! Yes, the truck rides really well and looks damn good too. I catch folks giving it the "guy stare" all the time now.. BTW, they were super easy to install.. took only a couple hours with air tools... and the awesome how to instructions and photos in this thread
    A BIG THANK YOU to Chris4x4 for helping SILVER06TRD and in doing so helping all of us. You're awesome bro!
    BTW- the directions that come from Total Chaos are pretty lame, so this how-to is really a treasure.
  15. Jun 9, 2009 at 12:48 AM
    #135
    SILVER06TRD
    AZ
    06 TRD
    Hey...Chris...you there??? :boink:
  16. Jun 9, 2009 at 5:08 PM
    #136
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    LMAO! Gottcha! ;)
  17. Jun 9, 2009 at 5:11 PM
    #137
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Thanks, Dwight! :)
    LMAO!! I have been working the last few days. I have one more day on this project.....Give me a call on thursday! :)
  18. Jun 9, 2009 at 8:30 PM
    #138
    vwguy60
    Southern California
    I thought you were pissed! Then I thought who am I gonna PM when I have a question :confused: Thanks again for the alignment numbers!
  19. Jun 10, 2009 at 4:49 PM
    #139
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Naw...I dont get pissed very easilly. :)
  20. Jul 7, 2009 at 4:47 PM
    #140
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    wenatchee, wa
    09 DCLB 4x4
    anybody else have issues with the TC uca's rubbing on the coils?
