Total Chaos UCA how-to Install
Discussion in 'Suspension' started by SILVER06TRD, Sep 14, 2008.
  1. Aug 12, 2009 at 1:53 PM
    #161
    Banchi94
    Banchi94 Well-Known Member
    Ron
    Parker, CO
    2008 Indigo Blue TRD Sport DCSB 4x4
    ToyTec 3" basic lift
    Awesome, thanks, Chris! I wonder why the alignment shop didn't catch this before? Would you suggest Big O Tires or Brakes Plus? I had Big O do it the first time. Brakes Plus is half the cost at $50.
    Thanks!
  2. Aug 12, 2009 at 2:04 PM
    #162
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I dont know who is better in your area. Preferably, someone who is familliar with lifted trucks. Tell them you want 0* Camber, 0* Toe, and 2.9* Caster, then check the printout they give you.
  3. Aug 12, 2009 at 2:09 PM
    #163
    Banchi94
    Ron
    Parker, CO
    Will do! Big O does all the lifted trucks for the Toyota dealership, so I'll just go there. I'll check the printout they gave me originally and see how far off I am from the specs you gave. Will these specs be good for the 3" Toytec spacer/AAL lift or does that even matter? Thanks again!
  4. Aug 12, 2009 at 4:09 PM
    #164
    docuw
    docuw Active Member
    SLC, UT
    09 Tacoma DBL TRD Offroad
    3" Lift: Front - OME 885 Springs with N140S, Toytec 1/2" Spacer; Rear - TSB Leafs with Toytec TSB AAL and OME N182S. Total Chaos UCA's, Access Tonnaeu Cover, Dynolock Tailgate Lock, Polished Aluminum Bull Bar, Bed Mat.
    I got it. Just had to put some balls behind the hammer. Thanks.
  5. Aug 12, 2009 at 5:01 PM
    #165
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
  6. Aug 15, 2009 at 2:21 PM
    #166
    FoxRacR17
    FoxRacR17 Well-Known Member
    Kevin
    SoCal
    09 4x4 SR5 DoubleCab Short Bed
    Fox 2.5 C/O's, Fox 2.0 rear shocks, toytec 1.5" AAL, TC UCA's, blue/white dashboard lights, seatbelt chime removed, Synthetic leather armrests, WO seat covers front and back, Goodyear Wranger Duratrac 285/70/17, KMC XD Addict 17x9 rims
    so what are some signs that you need to replace the bushings on these UCA's?
  7. Aug 15, 2009 at 5:00 PM
    #167
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    No idea. I have been beating mine, and they are still nice and tight. :eek:
  8. Aug 15, 2009 at 5:05 PM
    #168
    FoxRacR17
    Kevin
    SoCal
    WHAT?! SOMETHING THAT CHRIS DOESNT KNOW?! :eek:
  9. Aug 15, 2009 at 5:24 PM
    #169
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    LOL...Not YET.......:cool:
  10. Oct 30, 2009 at 1:33 PM
    #170
    testedone
    testedone Speak English..it's America
    Rick
    U.S.A.
    2010 Tacoma TRD Sport
    Weathertec Mats, Pioneer AVIC-X930BT, Pioneer GEX-P920XM (SAT), Pioneer Premier TS-D602P 6.2, Blaupunkt THb 200A Sub, Trimmed Mud Flaps, BF Goodrich AT/KO 285/70/17 ... Toytec Ultimate Lift, Tuffy Bed Box, A.R.E. Cover, Pop-n-Lock, TRD Exhaust
    Thanks fro the write up, I am about to go intall mine I have to say for the amount of money I paid for these you would think they would get a $5.00 set of zirk fitting correct??
  11. Oct 30, 2009 at 1:34 PM
    #171
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    LOL!! You would think.
  12. Oct 30, 2009 at 1:39 PM
    #172
    testedone
    Rick
    U.S.A.
    They are pretty though...And I got a sticker..you can't beat that..
  13. Oct 30, 2009 at 7:03 PM
    #173
    testedone
    Rick
    U.S.A.
    Thanks for the write up on this, it helped greatly...
    Everything went in without a hitch (other then the ones noted in the write up)
  14. Oct 30, 2009 at 7:04 PM
    #174
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Great to hear!
  15. Oct 30, 2009 at 7:08 PM
    #175
    testedone
    Rick
    U.S.A.
    If you guys had not mentioned bending the sheet metal I probably would have taken the whole front end off... :)
  16. Oct 30, 2009 at 8:13 PM
    #176
    Sandfire
    Sandfire Well-Known Member
    southwest midwest
    06 TRD Sport DC 4x4 silver
    OME 885 springs with OME N140s shocks, Total Chaos UCA's, TSB AAL, OME N182's, MT BAHA ATZ 4ribs.
    Someone else said this to but I think the zirks were apparently fitted before the powder coating. I used the ones they sent but it was a bitch to get them threaded in. Couldn't get them to go all the way down but they work.
  17. Oct 30, 2009 at 8:49 PM
    #177
    testedone
    Rick
    U.S.A.
    Same thing I did....
  18. Nov 8, 2009 at 4:50 PM
    #178
    youngblood
    youngblood Well-Known Member
    Chattanooga TN
    07 SR5 4x4 DC longggg bed
    None (yet)
    I wanted to update folks on an approach I took at the last minute that worked out nice.
    I decided I didn't want to bend my metalwork on the body to get the stock bolts out. I just think it is a bit retarded to buy a $30k truck and just because you want to upgrade the suspension you have to bend the crap out of the body? WTF?
    Solution: cut the heads off the bolts and replace them with new ones.
    I thought these would be expensive but once I called my local dealer, it turns out they are like $6...six tiny dollars. So for $12 and about 20 seconds with a sawzall and you don't have to bend jack squat.
    My dealer only had one in stock but ordered another (2 days) which slowed down my build. Just plan ahead and get these as it was so damn easy I would never consider taking the bend and yank approach. They really just slide right out toward the back, avoiding the bend, avoiding the wiring, and avoiding that question from the uninitiated: 'WTF happened there?'
  19. Nov 8, 2009 at 5:01 PM
    #179
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The bend required is virtually un noticable. And is bent right back. Its a pinch weld....Not a body panel. As for the wireing, you just pop the wire harnes and move it, then re atttach.
  20. Nov 8, 2009 at 5:18 PM
    #180
    youngblood
    Chattanooga TN
    None (yet)
    I understand that perfectly well. My buddy bent his and while I could tell, it wasn't that bad. However, I chose a different route.
    If you are okay with the picture below then hell yeah bend the shit out of anything you like. Have a party.
    As I thought I made clear last post I didn't want to bend shit. I didn't want to pop the harness off. For those who share these sentiments, they now have an option.
    It is about a 30 second job to get both bolts out depending on the sawzall blade. It is just a superior approach in my mind. Faster and doesn't require cracking paint, pinch weld or not.
    Tell me the first time you did the job it took you 30 seconds to get the bolts out with the bend and move the harness approach!
