Total Chaos UCA Install Question
Discussion in 'Suspension' started by bigwill837, Jan 25, 2017.
  1. Jan 25, 2017 at 2:10 PM
    bigwill837
    bigwill837 [OP] Well-Known Member
    Will
    Austin, TX
    1996 HZJ75 Land Cruiser Pickup
    So I am in the middle of installing my OME lift and Total Chaos upper control arms. I have the strut assembly removed from the truck, and the pin and castle nut off of the upper control arm.
    How do break apart the upper ball joint from the control arm? And how do I remove the assembly from the spindle? I've read to "use a ball joint puller" or to "use a hammer," but I'm not exactly sure what I'm supposed to be pulling or hammering.
    Basically, how do I get from here:
    To here:
  2. Jan 25, 2017 at 2:12 PM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    Step 1: Beer
    ClemsonMGM and ChadsPride like this.
  3. Jan 25, 2017 at 2:16 PM
    bigwill837
    Will
    Austin, TX
    Step 2: Pizza
    ClemsonMGM likes this.
  4. Jan 25, 2017 at 2:23 PM
    pray4surf
    pray4surf Well-Known Member
    Rick
    Oceanside, CA
    98 PreRunner conv to 4x4
    F&R suspension, OBA, Custom bed rack, RTT, rear frame plates, 4x4 conversion from prerunner, many other
    Atop the strut assembly are three bolts - remove those
    At the bottom of the strut assembly is one large bolt w/nut - remove that
    Disconnect the upper ball joint from the upper control arm - Do not strike the threaded stud unless you plan on on replacing the upper ball joint - you'll bugger up the threads. Here you can use a 'pickle fork' or simply strike the UCA with deadblow hammer.
    You may have to loosen/remove additional components (like the sway bar).
    Pizza and Beer are always encouraged
  5. Jan 25, 2017 at 3:34 PM
    Obsessed2000
    Obsessed2000 Just a big dummy
    NC/VA line
    2000 SR5 4x4 3.4
    Deck plate mod Bilsteins All pro leaf springs All pro greasable shackles Camburg UCA Interior Led conversion Tundra TRD springs Extended SS brake lines Seat covers 33" yokos White herculined exterior
    What I had to do on mine is cut the ball joint right under the UCA to disconnect the UCA from the spindle. Then that gave me the ability to get the ball joint press in there to push the part remaining on the spindle out.
    I still have that UCA in my garage and cant for the life of me get that part of the ball joint out. I've tried everything. But luckily your replacing the UCA so no worries. Good luck.
  6. Jan 25, 2017 at 3:38 PM
    niko5055
    niko5055 Well-Known Member
    24 Underground Sport Premium 4x4
    Search for the total chaos UCA install on YouTube, it'll walk you through the whole thing
  7. Jan 25, 2017 at 3:41 PM
    Obsessed2000
    NC/VA line
    2000 SR5 4x4 3.4
    I think his problem is that its seized. I could be wrong though.
  8. Jan 25, 2017 at 3:51 PM
    ElTacom
    ElTacom Member
    Brandon
    2000 4X4
    All Pro Coilovers & Leafs. Bilsteins. CBI Sliders
    I just finished this project over the weekend. Was harder than I anticipated.
    To get the the UCA to disconnect from the ball joint I did it different on both sides:
    1: Cut the stud (under the UCA) with a sawzall (not recommended)
    2: Used a pickle fork and a hammer. Mine was in there pretty good but using enough force and pounding with the hammer eventually allowed the UCA to disconnect over the stud.
    To get the ball joint out I used a ball joint press. You can rent them from autozone but I just bought the set. You may want to get the adapters as well. The problem I ran into was that screw for the press wouldn't fit into the wheel well. You should have the spindle tied up so that the axle isn't too extended but if you allow the spindle to be totally free, you can then fit the press outside of the wheel well. It's going to take a lot of pressure to get the ball to pop out. I also used a torch around the spindle to help loosen it up as well as beat on it with a hammer.
    Good luck.
  9. Jan 25, 2017 at 4:13 PM
    bigwill837
    Will
    Austin, TX
    Thanks for the help guys. I've got the upper control arm apart from the spindle. Now I just need to get the ball joint out of the spindle, so I can install the slug adapter for the Total Chaos UCAs.
  10. Jan 25, 2017 at 4:53 PM
    Obsessed2000
    NC/VA line
    2000 SR5 4x4 3.4
    Do forget the snap ring is in there. If you haven't already, go rent the ball joint press from advance auto or auto zone like ElTacom said. If you have air tools she should pop out pretty easy, if not get a big cheater bar and some heat. I've done it both ways.
  11. Jan 25, 2017 at 5:51 PM
    bigwill837
    Will
    Austin, TX
    You have to remove the snap ring before using the ball joint press?
  12. Jan 25, 2017 at 5:55 PM
    bigwill837
    Will
    Austin, TX
    And the trouble I'm running in to now, is there is not enough room under the wheel well for the ball joint press.
  13. Jan 25, 2017 at 8:23 PM
    Obsessed2000
    NC/VA line
    2000 SR5 4x4 3.4
    Yes the snap ring will need to be removed. There's a good chance its hidden under some grit and shit.
    If I remember correctly I used a ratcheting wrench I picked up from homedepot so I wouldn't have to take it off once I got it in there. At that point I pushed and pulled to fought like hell to get whatever configuration of accessories of the ball joint press and my wrench inside the wheel well. Apply heat and crank that damn thing as far as you can. I think I had an extra set of hands to hold it as still as possible (my 100lbs wife...so you shouldn't need to much) and when you think your gonna break something you hit that fucking wrench with a BFH....then your done. Go inside have a beer and pray you never have to do it again.
    If this doesn't work the only other thing to do is take the whole spindle off and go through the above steps. The only thing that changes is that part where you hit the wrench with the BFH you actually hit the C press that your using to press the ball joint out.
    Make sure you apply some anti-seize for the next poor fucker who has to do this job again in 5-10yrs.
  14. Jan 25, 2017 at 8:38 PM
    bigbolas
    bigbolas Member
    You guys are scaring me, im just gonna pay to have done.
  15. Jan 25, 2017 at 9:10 PM
    bigwill837
    Will
    Austin, TX
    Thank you again. I'm going to try this long-arm puller method with a socket tomorrow (http://www.bajataco.com/tech/control_arms_03.html). I'm also going to get some anti-seize and synthetic grease for the UCA install.
  16. Jan 25, 2017 at 9:12 PM
    Obsessed2000
    NC/VA line
    2000 SR5 4x4 3.4
    I attempted that but could not find a 3 claw strong enough. Good luck brother.
  17. Jan 25, 2017 at 9:14 PM
    Obsessed2000
    NC/VA line
    2000 SR5 4x4 3.4
    It's not all that bad. Just takes patience and the right amount of pressure. Also hugely depends on how bad the rust is in your area.
  18. Jan 25, 2017 at 9:26 PM
    maxtherat
    maxtherat Well-Known Member
    Inland Northwest
    2001 Dodge Ram 2500, 1993 Jeep Wrangler
    All the usual diesel truck mods- fuel system upgrade, programmer, CAI, intake manifold, 60MM stealth turbo
    Not sure if I missed something but just loosen castle nut from ball joint (don't remove) and sharply hit the flat spot on the spindle. After a few good hits it should pop. Did you cut the ball joint stud and now there's a piece still stuck in the spindle?if so now you don't have the weight of the suspension to help push it out. Heat the shit out of it with a torch and then rapidly cool then use the ball joint tool you've got.
    snox31 likes this.
  19. Jan 26, 2017 at 5:09 AM
    bigwill837
    Will
    Austin, TX
    Yessir. I've got the upper control arm off the ball joint. I just need to remove the ball joint from the spindle now.
  20. Jan 26, 2017 at 5:51 AM
    maxtherat
    Inland Northwest
    Shoot I just looked closer and realized you've got 1st gen. Now I understand why I got confused. Haven't taken that style apart before but guessing bj press tool like another member already mentioned.
