TOTAL CHAOS - UCA Maintenance (Lubricating Bushings & Uniballs) *VIDEO*
Discussion in 'TOTAL CHAOS' started by TOTAL CHAOS, Jun 9, 2018.
  1. Jun 9, 2018 at 3:20 PM
    TOTAL CHAOS
    TOTAL CHAOS [OP] WWW.CHAOSFAB.COM Vendor
    Corona, CA
    At TOTAL CHAOS we want to make it easy to maintain your suspension components! Our Upper Control Arms (UCA) are designed to be easily greaseable without removal from the vehicle or an alignment afterward. With just a few tools and a couple minutes of your time, you can be greased up and ready adventure!
    NOTE: Do NOT pump grease into a UCA without loosening thru-bolt. Doing so will most likely cause the bushing to deform and require replacement. Please watch the videos below on HOW TO properly maintain your TOTAL CHAOS UCA bushings and uniballs
    HOW TO - GREASE YOUR TOTAL CHAOS UCA BUSHINGS
    https://www.youtube.com/watch?v=xvMdAX2uybs
    HOW TO - LUBRICATE YOUR TOTAL CHAOS UNIBALLS
    https://www.youtube.com/watch?v=udUaFDCwGAA
    THRU-BOLT TORQUE SPECS:
    2000-06 TUNDRA (98ft/lbs)
    2007 + TUNDRA (173ft/lbs)
    1996-02 4RUNNER (87ft/lbs)
    2003+ 4RUNNER (85ft/lbs)
    2007+ FJ CRUISER (85ft/lbs)
    1996-04 TACOMA (87ft/lbs)
    2005-15 TACOMA (85ft/lbs)
    2016+ TACOMA (85ft/lbs)
    1998-07 100 SERIES LAND CRUISER (72ft/lbs)
    2008+ 200 SERIES LAND CRUISER (136ft/lbs)
    Want to know HOW TO Prep your TOTAL CHAOS UCA’s? We cover replacing Bushings and Uniballs in this thread:
    https://www.tacomaworld.com/threads/total-chaos-uca-prep-replacing-bushings-uniballs-video.553261/
    Post up or give us a shout if you have any questions! Hope everyone is causin' some CHAOS this weekend!
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
    Geeterman, HIYota, lynyrd3 and 9 others like this.
  2. Jun 13, 2018 at 10:20 AM
    NaZRaQ
    NaZRaQ Well-Known Member
    Zee
    Denver
    2024 TRD OR Tacoma hybrid
    holy crap! i've been doing it completely wrong for the last 2 years... may need to replace the bushings.
    VA SOFTACO and JMY24 like this.
  3. Jun 13, 2018 at 1:31 PM
    TOTAL CHAOS
    Corona, CA
  4. Jun 13, 2018 at 1:38 PM
    djthicks
    djthicks Well-Known Member
    Orange County
    07 DCLB TRD Sport
    King's all around Long traveled Methods KO2s
    738AC0EA-A43E-4273-8D5F-259619A915D7.jpgJust did mine :)
    NaZRaQ[QUOTED] likes this.
  5. Jun 13, 2018 at 3:34 PM
    JMY24
    JMY24 Well-Known Member
    Huntsville AL
    '05 white TRD OR DCSB
    3 inch TOYTEC lift with Bilsteins Total Chaos uniball UCAs BAMF sliders
    Same lmao
  6. Jul 30, 2018 at 2:48 PM
    cav
    cav Well-Known Member
    Marc
    Encinitas, CA
    2018 MGM DCLB OR 4x4
    Bilstein 5100 w/OME 888 Coils & OME Medium Duty Leaf Pack, TC UCAs, TRD 17" Matte Gray w/ Falken Wildpeak A/T3w 285/70/17
    Hi, I just installed these this weekend and followed your instructions per the video. How often do the bushings need to be greased? (After install the paperwork accidentally got discarded)
    Thanks!
  7. Jul 30, 2018 at 4:20 PM
    TOTAL CHAOS
    Corona, CA
    Some customers go 15k and some do it before & after every trip. Greasing every oil change (5k miles) is good practice.
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
    DawsonDestroyer likes this.
  8. Aug 3, 2018 at 10:48 AM
    kksrunner
    kksrunner Well-Known Member
    Whit
    Havelock
    2018 tacoma TRDOR and 2014 4runner
    5th gen T4R -3" toytec -285 trails -18" XD Grenades -Total Chaos UCA 2018 TRDOR Front: 2.5” bilstein/OME, Total Chaos UCA, driver side shim Rear: 2” Toytec Boss shocks and AAL 285/70R17 trail grapplers 17” XD grenades Spidertrax spacers
    Do I need to jack my truck up or remove the wheel and tire to do this?
  9. Aug 3, 2018 at 10:49 AM
    kksrunner
    Whit
    Havelock
    Do I need to jack up my truck or remove the wheels for this? Or just loosen the bolt and grease?
  10. Aug 3, 2018 at 11:12 AM
    TOTAL CHAOS
    Corona, CA
    No need to jack up the truck or remove the wheel and tire. Simply loosen the thru-bolt and pump grease into the zerk fittings. Once you're done make sure everything is re-torqued and you're good-to-go!
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
  11. Aug 3, 2018 at 11:30 AM
    kksrunner
    Whit
    Havelock
    Thanks for the quick reply! Y’all are awesome!
  12. Aug 6, 2018 at 3:25 PM
    NaZRaQ
    Zee
    Denver
    i need to replace my bushings (which i can get from Toytec) as well as the ball.
    i saw a video that a special too is required to replace the ball - where can i get this from ?
  13. Aug 7, 2018 at 11:33 AM
    TOTAL CHAOS
    Corona, CA
  14. Aug 7, 2018 at 11:35 AM
    TOTAL CHAOS
    Corona, CA
    We recommend using a grease like Super Lube for our Urethane Bushings. Comment below if you have any questions
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
    Biscuits likes this.
  15. Sep 1, 2018 at 12:04 PM
    Yager78
    Yager78 Well-Known Member
    Las Vegas
    15 Tacoma TRD Off Road
    King Coilovers, Total Chaos UCA, Dakars, Pelfrey Front and Rear with Swingout, AP Sliders, Budbuilt Skids, OBA, OBW.
    What is the procedure for greasing the Lower Control Arm bushings? Do I loosen the bolts first? Will that throw off my alignment?
    I’m typing this sitting under my truck looking at the cam tabs, saying hmmmmmmmmm?
  16. Sep 4, 2018 at 8:38 AM
    TOTAL CHAOS
    Corona, CA
    For the Lower Control Arms, DO NOT loosen anything. You can simply pump grease into the zerk as-is. The UCA's are the only ones that require loosening the pivot thru-bolt
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
  17. Sep 12, 2018 at 10:51 AM
    artesho
    artesho Well-Known Member
    Randy
    For the UCA, it’s required to loosen the pivot thru-bolt to avoid pumping grease and building pressure that deforms the bushings. Is there some type of built in relief built into the LCA bushings that allow it to be greased without loosening the LCA bolts?
    Yager78 likes this.
  18. Nov 6, 2018 at 8:51 AM
    dkhorse74
    dkhorse74 Well-Known Member
    Where you want to be
    For the first full year, I didn't grease the UCA at all until I noticed the zerk fittings while rotating tires.. Once I realized I had to grease, well I've been doing it wrong and not loosening up anything. I was wondering why the bushing was swelling up, but I never thought twice and stopped adding grease once I see some of it get past the bushing.. The installer never passed any info. to me about this requirement.. :annoyed: How can you tell if one needs to replace the bushing?
  19. Nov 6, 2018 at 12:18 PM
    TOTAL CHAOS
    Corona, CA
    The bushings can fold over the washers on the UCA. This is why we require loosening the thru-bolt.
    The LCA has a larger surface area surrounding the bushings. It is still possible to overgrease the lowers, we recommend one or two pumps for this reason. Driving the vehicle will allow the grease to work it's way into the required areas.
    Could you post a pic or two of your setup? Happy to see how the bushings are looking.
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
  20. Nov 7, 2018 at 8:18 AM
    dkhorse74
    Thanks for taking a look!! Hopefully, the bushings are still in good shape
