total chaos UCA problems
Discussion in '2nd Gen. Tacomas (2005-2015)' started by xyourlocaldjx, Mar 21, 2013.
  1. Mar 21, 2013 at 4:37 PM
    xyourlocaldjx
    xyourlocaldjx [OP] Well-Known Member
    The ball joint on the UCA is hitting the UCA causing indents. Anyone else have this problem?
  2. Mar 21, 2013 at 5:46 PM
    xyourlocaldjx
    So its okay that it hits like that?
  3. Mar 21, 2013 at 6:41 PM
    xyourlocaldjx
    Wth is wrong with my UCA then? Always thought it didn't sit right.
  4. Mar 21, 2013 at 6:47 PM
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    need moar pics!
    and some info would be nice.
  5. Mar 21, 2013 at 8:40 PM
    xyourlocaldjx
    I haven't even wheeled yet. Wtf!
  6. Mar 21, 2013 at 8:43 PM
    MEMO CAMPOS
    MEMO CAMPOS Well-Known Member
    Westminster, Ca.
    05 PRERUNNER
    TC Upper Arms, ICON coilovers, Camburg spindles, AP standard leaf packs, ICON Resi.'s, AFE intake, Magnaflow Magnapack, Defiant Light Bar with PIAA 580's, 6K HID's top and bottom
    Mine does the same, when Camburg installed my spindles they made me aware of it. They mentioned its common binding with TC UCA's. For some odd reason its not that bad since they installed my spindles...bought my uca's in 05 so who knows if its still a prob.
  7. Mar 21, 2013 at 9:49 PM
    Raceline08
    Raceline08 Well-Known Member
    Brett
    Santa Rosa, ca
    Silver 08 DBC SB 4x4 TRD Offroad
    front Billies, 885x coils, taco lean spacer, TC UCA'S, Magnaflow 22" OME Dakars, Billy 110 rear's, B.A.M.F CMC, custom made E-locker guard
    Never had a problem with mine hitting. If you haven't wheeled it like you say that could be a problem. There has to be something a miss? Idk
    Brett
  8. Mar 21, 2013 at 9:51 PM
    Raceline08
    Brett
    Santa Rosa, ca
    What front lift you running? 2wd? 4x4?
    Brett
  9. Mar 21, 2013 at 10:00 PM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    X2 on lift and also post more pics
  10. Mar 21, 2013 at 10:16 PM
    Raceline08
    Brett
    Santa Rosa, ca
    Right. Maybe you have your frontend cranked up too high, I could see it making metal to metal contact driving down a crappy road or a speed bump to fast if thats the case. I just have a 3 inch on my truck and my angles don't look like that at all. Almost looks like a drooped pic.
    X2 on more pics and info.
    Brett
  11. Mar 21, 2013 at 10:17 PM
    xyourlocaldjx
    Sway away coils with probably a 2.5 inch lift if that. Rear with add a leaf is still higher. Will get more pics tomorrow.
    I also get a loud squeaking noise when reversing out of the drive way at low speeds with wheels slightly turned. Same with going fwd some times. It has to be a slow slow crawl for it to make noise.
  12. Mar 21, 2013 at 10:24 PM
    Raceline08
    Brett
    Santa Rosa, ca
    Hmm? Something's not right. How long have you had the tc's on it? Do you hear the frontend hitting while driving down the road?
    The other pics should help.
    Brett
    Subd
  13. Mar 21, 2013 at 10:26 PM
    tacokid09
    tacokid09 it's about the off-road miles
    Brian
    San Luis Obispo, CA
    2010 Tundra
    it happened to mine as well and i was at full droop quite a bit. all that happened was that grade 8 bolt was a little bent when i got new uppers.
  14. Mar 21, 2013 at 10:28 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    Your topping out the UCA and the misalignment is hitting the arm. Three options stop mobbing over speedbumps, reduce your preload, or get some limit straps.
  15. Mar 21, 2013 at 10:29 PM
    Alex352
    Alex352 Well-Known Member
    Alex
    Oregon
    07 Tacoma Dbl Cab
    http://www.tacomaworld.com/forum/2nd-gen-builds/281569-alex352s-build-thread.html
    Try regreasing your uniballs. Mine was dirty which caused the squeak when reversing and moving forward slowly. Hope this helps
  16. Mar 21, 2013 at 10:45 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    Em I out of line with saying this but, are the ucas installed correctly? Looks like it may be upside down in that one pic in the OP....
    :notsure: could be wrong or me being tired that I'm just seeing things :anonymous:
    Edit nvm I think I'm seeing things :laugh: long days Suck
