Total chaos UCA question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by GROOT5252, Apr 19, 2018.
  1. Apr 19, 2018 at 5:31 PM
    GROOT5252
    GROOT5252 [OP] Well-Known Member
    2017 Toyota Tacoma 4X4 DCLB Quicksand
    I was wondering when you guys install the UCA’s did you put the through bolt in the same direction Toyota installed it? Or installed the bolt from the bottom up? Also did it loosen the through bolt as you drove it?
    Attached is the driver side UCA that is loose. Each side it’s about 1/8” gap. I know I can tighten it but I wasn’t aware I’d have to tighten every 3,000 miles.
    SilverII and ChadsPride like this.
  2. Apr 19, 2018 at 6:11 PM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    Went through the way it was installed as if the nut came off the bolt won't disappear.
    Are you torqued to proper spec?
    tcjacado likes this.
  3. Apr 19, 2018 at 6:15 PM
    doorsidedown
    doorsidedown Well-Known Member
    I put mine through backwards. I’ve checked it every oil change but never needed to tighten it.
    JJ Customs, Dacon and BassAckwards like this.
  4. Apr 19, 2018 at 6:33 PM
    GROOT5252
    Does yours squeak?
    Yeah I torqued them to spec.
  5. Apr 19, 2018 at 7:04 PM
    awdvkd115
    awdvkd115 Well-Known Member
    Bud
    2017 Tacoma TRD OR
    Toytec lift, White Knuckle sliders, RCI Armour, ECGS (Nitro Gears), Victory 4x4 Striker Front bumper, Smittybilt X20 10K winch, Dobinson snorkel, Spidertrax 1.25 spacers and 255 R80 16 BF Goodrich KM2s.
    I put the driver side in the way it came out and the passenger in backwards. I periodically check them and they have never changed. I periodically go through my truck before and after trips to check all the changes I have made just to avoid trail mishaps. But I go through a lot of locktite when I upgrade my vehicle.
    GROOT5252[OP] and BassAckwards like this.
  6. Apr 19, 2018 at 7:54 PM
    LoMa
    LoMa Well-Known Member
    2016 Tacoma TRD Sport AT MGM
    I reversed mine and applied torque marker to the nuts and bolts. It hasn't come loose yet.
  7. Apr 19, 2018 at 8:02 PM
    GROOT5252
    Thanks! I was thinking it could be the reason they are squeaking. I was about to disassemble them.
  8. Apr 19, 2018 at 8:30 PM
    doorsidedown
    No, it doesn’t squeak, although I give them a few pumps of grease and dry lube on the uniball.
  9. Apr 19, 2018 at 8:31 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Mine looked the same and had play
    Bushings were shot and I had to install new ones.
    I would NOT be driving around with it like that
    samiam likes this.
  10. Apr 19, 2018 at 8:40 PM
    doorsidedown
    Good point. OP how many miles on yours since the install? If you have that much play, and it’s torqued to spec, might be time for a rebuild.
    Can’t be that much if you have a 2017...
  11. Apr 19, 2018 at 8:43 PM
    t8fanning
    t8fanning Active Member
    Utah
    2018 Quicksand TRD OR
    33" KO2s, TC UCA, 3" OME lift, ARB front bumper
    Mine squeak a bit. I probably need to grease them. I really want to find or make some kind of cap for the spherical bearing though.
  12. Apr 19, 2018 at 8:47 PM
    anthony250f
    Anthony
    San Diego, CA
    Makes me think the bolt is just super loose since he has a 2017. Mine were many years old.
    doorsidedown[QUOTED] likes this.
  13. Apr 19, 2018 at 9:46 PM
    GROOT5252
    I’ve only had them on for 7,000 miles and they have never stopped squeaking.
  14. Apr 19, 2018 at 9:47 PM
    GROOT5252
    I’ve regressed them at least 6 times in 7,000 miles. I went through a whole tube of super lube already.
  15. Apr 19, 2018 at 9:50 PM
    BraskaTaco
    BraskaTaco Well-Known Member
    Midwest
    2013 Tacoma TRD OR
    My TC UCA's are the least favorite mod on my truck. Loud as hell, but at least I got a year out of them before they started making noise.
  16. Apr 19, 2018 at 10:08 PM
    anthony250f
    Anthony
    San Diego, CA
    Did you grease them properly ?
    Loosen the bolt grease and then tighten ?
    If not you have ruined the bushings and need new ones.
  17. Apr 19, 2018 at 10:16 PM
    GROOT5252
    Yup followed the instructions total chaos gives you.
  18. Apr 19, 2018 at 10:24 PM
    samiam
    samiam Always here, never there
    Sam
    Stinky Vegas
    2008 TRD OR DCSB 4.0 6MT 1E7 Alu Cab
    Workin' on Workin' on it
    Did you clean the threads of grease before tightening?
  19. Apr 19, 2018 at 10:54 PM
    doorsidedown
    I love the way mine look, and they don’t make any noise... but if I were to do it again I’d buy JBA air SPC. I just don’t NEED these.
