Total Chaos UCA retrofit with Icon Delta Joint
Discussion in 'Suspension' started by WacoTacoma, Mar 13, 2021.
  1. Mar 13, 2021 at 6:14 PM
    WacoTacoma
    WacoTacoma [OP] Active Member
    Hunter
    Colorado Springs, Colorado
    Silver 2012 trd sport
    King 2.5 /TC UCA 33" Falken MT 16" SCS Ray 10 DIY Wedge Camper
    After about 30,000 miles I figured it was time to refresh my Total Chaos UCAs with new bushings and uniballs. After shopping around for a few weeks I was shocked at the price for 2 new uniballs (almost $200) for a regular maintence part, that was just gonna wear out in another 2 years.
    So I looked into a different option that seemed like a good idea but I could not find very much information about. I wanted to take a Icon Delta Joint and put it into my Total Chaos UCA.
    For those that dont know what a Delta Joint is its basically a high angle greasable ball joint that claims to have the strength of a uniball. I dont want to get into the details of ball joint vs uniball you can look that up for your self. I just wanted to provide more information about this topic because when I was looking to see if this would even possible i couldn't find anything and I was kinda taking a shot in the dark.
    Here is how it went.
    First I ordered Icons Delta Joint (part 614560 for non-icon uca) from toytec lifts, which was the best price i could find at the time, as well as they were local ~$275
    I also purchase the adaper tube (part 614519) this was required install the new joint as a normal uniball/ball joint press would/might be too short ~$30
    Access to a hydraulic press will make this much easier.
    Pushing out the old uniball is pretty self explanitory, remove the snap ring and press out from top side, after pressing out I cleaned up and applied some anti seize to inside of the UCA. then I used the adapter to press in the new delta joint, reinstall the snap ring and thats it!
    Here are some of the pictues I took after the install and may answer some fitment questions.
    This is a close up of the joint at full articulation showing that the stem won't contact the arm at full droop
    Here is a side by side comparison of the angle improvement of the new delta joint vs the old uniball, its subtle but it is an improvement
    Before and After
    This was a really straight forward modification that I think will last much longer than the uniball.
  2. Jun 18, 2021 at 7:35 PM
    cbowles
    cbowles Member
    Curtis
    a truck with truck-like things
    Beer bellied driver
    Bump to get an update on this and how it’s held up for the last few months. This seems like a pretty sweet solution to a worn out uniball.
  3. Jun 20, 2021 at 6:24 PM
    2000prerunner23
    2000prerunner23 Well-Known Member
    steve
    Ur misalignment spacer isn’t settled into the uniball so you are not getting the full angle out of that uniball .
  4. Jun 21, 2021 at 9:20 PM
    WacoTacoma
    Hunter
    So far so good. I grease the zerk fitting every 5000 miles and no issues for the first few months
  5. Jun 21, 2021 at 9:30 PM
    WacoTacoma
    Hunter
    I agree it does look that way, its not the greatest picture. However if you zoom in on the picture you can see that it isnt actualluy touching on top. the bottom spacer is engaged correctly so this should represent accurate deflection. However you may be correct, I cant remember the exact condition it was in when this picture was taken
    What mattered the most to me was that when everything was fully assymbled the shock fully extended before the joint even came close to maxing out.
    so regardless of the max angle my King extended coilovers wont max out this joint, and I assume that to be the same accross all tacomas.
  6. Jun 21, 2021 at 9:34 PM
    ForestRunnerFrank99
    ForestRunnerFrank99 Well-Known Member
    Josh
    Rancho Cucamonga, CA
    '99 TRD 4x4 Manual 3.4l v6
    Fox Coil-overs, Dakar Leafs, Intake, Tires, Rims
  7. Jun 21, 2021 at 9:41 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    those uniballs are off the shelf nothing special about them at any offroad supply store such as Kartek, McKenzies, Offroad Warehouse , Summit Racing etc etc.. for under 50 bucks each
    MGMDesertTaco and WacoTacoma[OP] like this.
  8. Jun 21, 2021 at 9:44 PM
    MonkeyProof
    SoCal- SGV
  9. Aug 19, 2021 at 5:19 PM
    garciav
    garciav Well-Known Member
    Houston, TX
    2013 Tacoma TRD Off-Road 6MT
    TRD SC,HPTuners
  10. Aug 20, 2021 at 7:21 AM
    TMFF
    TMFF Well-Known Member
    Tim
    Thornton, CO
    01/02 DCLB
    Stuff and junk and things...
    garciav[QUOTED] likes this.
  11. Aug 20, 2021 at 7:39 AM
    garciav
    Houston, TX
    TRD SC,HPTuners
    TMFF[QUOTED] likes this.
  12. Aug 20, 2021 at 7:59 AM
    garciav
    Houston, TX
    TRD SC,HPTuners
  13. Aug 20, 2021 at 12:36 PM
    TMFF
    Tim
    Thornton, CO
    01/02 DCLB
    The tighter fit can affect ride quality on very light vehicles like a sand rail or small UTV.
    The tighter the fit to start with the longer the bearing will last, in theory.
  14. Oct 22, 2022 at 10:55 AM
    Pete4x4
    Pete4x4 Well-Known Member
    Frankie
    NorCal
    2014 4x4
    6112/5160 Dakar HD
    1year Update? Glad I found this. I wasn’t going to install my TC uppers because of the rebuild cost. Now they are going in today!
  15. Oct 29, 2022 at 10:36 PM
    amadougrand
    amadougrand Well-Known Member
    Southwestern Idaho
    Tacoma TRD Off-Road
    Interested in this also. My first set of uniballs lasted ~8k miles. Bought replacements from Kartek much cheaper and will see how long they last.
  16. Dec 11, 2022 at 2:04 PM
    hherby
    hherby Member
    Oklahoma
    2012 Tacoma
    King 2.5 all around C4 front and rear bumpers and a GFC
    not sure what happend to my previous account but after about 2 years and 30k miles. one the delta joints has worn out, ive reached out to icon about the warranty but so far they havent responded. Kind of a bummer, i really thought these joints would have lasted longer than they did, however they did last longer than a standard uniball.
  17. Dec 11, 2022 at 4:15 PM
    amadougrand
    Southwestern Idaho
    Tacoma TRD Off-Road
    My uniballs lasted ~7k miles on the last set so 30k looks like a big win to me.
  18. Dec 11, 2022 at 5:23 PM
    hherby
    hherby Member
    Oklahoma
    2012 Tacoma
    Now Im trying to decide wether to go back to uniballs or take another shot with the delta joints. the both seem to have pros/cons
    uniballs are cheaper to replace ~ $120 vs $250 for delta joints
    maintenance seems to be about the same, if anything favoring the uniball, (just walk by and spray them here and there) vs having to grease the DJ.
    I seemed to get about 30k miles out of each of them before I noticed play on each of the joints. only difference i noticed between the two was that the delta joints were completly silent still to this day where as the uniballs got pretty noisy.
  19. Dec 11, 2022 at 6:13 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    off icon website...
    https://images.iconfigurators.app/images/categories/highres/ICON_2018_WARRANTY_INFO_1392.pdf
  20. Dec 17, 2022 at 6:31 AM
    hherby
    hherby Member
    Oklahoma
    2012 Tacoma
