Total chaos uca
Discussion in '3rd Gen. Tacomas (2016-2023)' started by cloudbnd, Apr 6, 2022.
  1. Apr 6, 2022 at 3:39 PM
    cloudbnd
    cloudbnd [OP] Well-Known Member
    Randy
    2008 silver DCSB 4X4 OFFROAD
    Looking to buy TC uca from a third gen to install on stock heighth 2nd gen. I called to get the rebuild parts and they told me they wouldn't fit for a stock height. I've got an 08 TRD offroad and am going to replace the shocks with coil overs from a 3rd gen TRD offroad. Anybody tell me why the ucas wouldn't work? Thanks for the input
  2. Apr 6, 2022 at 3:46 PM
    Buttskevin21
    Buttskevin21 Well-Known Member
    Kevin
    Washington
    2019 Brocoma, 37s, Lt, Dual Tcases, blah blah blah https://www.instagram.com/kevinjbutts/
    Stock-ish
    They will work fine. You will just have a lot of castor.
  3. Apr 6, 2022 at 3:51 PM
    cloudbnd
    Randy
    When you say alot of castor, would it be too much. And if so how could that be corrected
  4. Apr 6, 2022 at 3:53 PM
    Buttskevin21
    Kevin
    Washington
    Stock-ish
    I dont think theres such thing as too much castor, steering will just want to return to center more than stock. Depending on the alignment, it could make your tires rub the firewall/mudflaps easier than a stock Uca since aftermarket Uca's with more castor push the tire back into the wheel well.
  5. Apr 6, 2022 at 3:58 PM
    cloudbnd
    Randy
    Ok. Thanks for the help.
