TOTAL CHAOS: ULTIMATE GUIDE TO 1996-2004 1ST GEN TOYOTA TACOMA
Discussion in '1st Gen. Tacomas (1995-2004)' started by TOTAL CHAOS, Apr 12, 2024.
  1. Apr 12, 2024 at 6:16 PM
    TOTAL CHAOS
    TOTAL CHAOS [OP] WWW.CHAOSFAB.COM Vendor
    Corona, CA
    Gen 1 Toyota Tacoma Off Road Lift Kits and Accessories
    The 1996-2004 1st Gen Tacoma is still one of the most well regarded vehicles to this day. Just look at the prices for one of these Tacoma trucks in good condition. The 1996-2004 Gen 1 Toyota Tacoma offers the simplicity and reliability to make an excellent platform for daily driving, overlanding, desert racing, and everything in between.
    Why install TOTAL CHAOS suspension? Reliable and dependable off road equipment matters. Performance suspension upgrades add lift and reliability, and performance shocks have more precise valving and spring rates than factory shocks. When you combine the two, you add comfort and reliability when rock crawling through boulders, overland exploring with the family, pre-running through the desert or carving it up in the sand dunes. TOTAL CHAOS Gen 1 Tacoma lift kit packages improve ride quality on and off road.
    There are many reasons you might want to add performance suspension upgrades as your lift kit to your Toyota Tacoma. Here are just a few:
    More wheel travel. TOTAL CHAOS upper control arms (UCA’s) and long travel kits are designed to provide the maximum wheel travel when paired with aftermarket specific extended length coil-over shocks. More wheel travel allows your tires to remain in contact with the terrain flowing over obstacles more easily – added wheel travel helps control the vehicle at high speed, and at low speed during technical rock crawling.
    Improved ride quality. Urethane bushings pivot freely on upper and lower control arms and do not deflect like a rubber bushing. This deflection can cause more body roll or a sloppy steering feel when driving on and off road. Urethane pivot bushings tighten the steering response for better overall handling and control when driving on and off road.
    Increased ground clearance. Performance lit kits are one of the best upgrades you can make for your Gen 1 Tacoma to go off road. They also allow you to fit larger tires, up to a 285/70R17 or 33-inch tall tire, with no rubbing. Added ground clearance will allow you crawl over obstacles on the trail. To achieve optimum performance, tires must be mounted on wheels with the appropriate backspacing. Bigger tires provide more ground clearance and make bumps effectively smaller when you encounter them.
    Go off-road in your Gen 1 Tacoma. The Gen 1 Toyota Tacoma was designed as a utilitarian truck but it is full of off-road potential for desert prerunning, overlanding, desert racing, rock crawling, or all of the above. Upgrading your suspension with more than just a lift kit will transform your Tacoma from a rough riding pickup into a capable off-roader that can soak up any terrain without crashing into the bump stops off road. You can expect improved handing, more ground clearance and better trail performance when you add TOTAL CHAOS suspension components to your lifted Toyota Tacoma. We are the Toyota experts for truck and SUV performance with decades of hands on experience and knowledge.
    Suspension Packages – Gen 1 Toyota Tacoma Lifts Kits To Install Larger Tires
    TOTAL CHAOS suspension packages allow you to lift your 1996-2004 Toyota Tacoma 2.5-4 inches and turn it into a truly capable off-road vehicle built on comfort and reliability.
    The mid travel lift kit options offer 2-3-inches of lift and include stock length replacement upper control arms and stock length replacement lower control arms for your front suspension – a 2.5-inch diameter shock upgrade is also added that will allow you to install up to 33” tires.
    [​IMG] [​IMG] [​IMG]
    TOTAL CHAOS also manufacturers a bolt-on 3.5-inch wider long travel kit for off-road trail performance. The kit provides 3-4-inches of lift and features dual shock tabs on the lower control arms to maximize dampening control with dual shock capability. This suspension system includes 3.5” longer upper and lower control arms, limit straps, extended tie-rods & brake lines, and all mounting hardware. 3.5” extended axles (to retain 4WD) and TC custom length long travel shocks must be installed with this long travel suspension package. We have collaborated with KING, RadFlo, FOX, and ADS Shocks to develop custom length 2.5-inch long travel shocks for this specific performance suspension system.
    TOAL CHAOS offers several weld-on accessories to make your Gen 1 Toyota Tacoma an extremely reliable and dependable rig for the trails. Weld-on spindle gussets, lower control arm cam tab gussets, and steering rack bushings are just a few of the accessory upgrades that we offer to provide added protection and durability. One of the best upgrades for the 1st Gen Tacoma is our lower uniball conversions. Due to their design, factory lower ball joint failure on 1996-2004 Tacomas can be catastrophic (see image below). Our lower uniball conversion solves this problem and is compatible with either OEM Toyota lower control arms or TOTAL CHAOS lower control arms (stock length and long travel). Two versions are available based on your steering setup – factory tie-rods or TOTAL CHAOS heim steering conversion.
    TOTAL CHAOS has passion for performance.
    At TOTAL CHAOS we personally test our products in the harshest of conditions. Our vehicles are being driven every day whether to and from work or to and from the trail. We are passionate off roaders and manufacture dependable suspension upgrades that are designed to make your vehicle handle better on and off road. We are a privately owned small business who cares about our customers. All of our products are hand crafted in our manufacturing facility in Corona, California, just as they have been for the past 25 years. And you can be confident that TOTAL CHAOS will be around for the next 25 years providing the level of technical support and customer service we have become famous for.
    Contact us today! (Info@chaosfab.com - 9517379682)
    Feel free to contact us with any questions that you might have regarding building your lifted Tacoma. At TOTAL CHAOS, an actual person answers the phone, and we just happen to own several Tacoma’s of our own. We offer the highest quality components and our parts are hand crafted in Corona, California. Quality counts.​
    btu44, Baja Designs, YotaBro and 8 others like this.
  2. Apr 12, 2024 at 6:38 PM
    ChargedSHOTaco
    ChargedSHOTaco Well-Known Member
    I've been sleeping through the nights after installing my TC uniball LBJs.IMG_7702.jpg
    surfishjoe and w8tdstrgecube like this.
  3. Apr 12, 2024 at 6:57 PM
    TOTAL CHAOS
    Corona, CA
    RAD!
    Thanks for posting up feedback and a pic of your setup. Glad we could help!
    - Team TC
    info@chaosfab.com
    951.737.9682
  4. Apr 13, 2024 at 12:29 AM
    w8tdstrgecube
    w8tdstrgecube Well-Known Member
    Brian
    Wisconsin
    2004 Gold Regular Cab 2.7L Manual 4x4
    Definitely saving up for a set of these for when my LBJs are due
  5. Apr 13, 2024 at 9:54 AM
    TOTAL CHAOS
    Corona, CA
    let us know when you’re ready :thumbsup:
    We’d love to earn your business
  6. Apr 14, 2024 at 9:41 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  7. Apr 15, 2024 at 5:16 PM
    TOTAL CHAOS
    Corona, CA
  8. Apr 15, 2024 at 5:29 PM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
  9. Apr 15, 2024 at 6:07 PM
    TOTAL CHAOS
    Corona, CA
    VERY Clean! :cheers:
  10. Apr 16, 2024 at 8:08 PM
    TOTAL CHAOS
    Corona, CA
    w8tdstrgecube and Area51Runner like this.
  11. May 14, 2024 at 10:11 AM
    TOTAL CHAOS
    Corona, CA
    Comment below if you have any questions, comments or feedback!
  12. May 14, 2024 at 9:48 PM
    TOTAL CHAOS
    Corona, CA
    1ST GEN TACOMA EXPEDITION SERIES LOWER CONTROL ARMS
    1996-2004 TOYOTA TACOMA LOWER CONTROL ARMS
    Stock ball joints and rubber bushings eventually wear out and must be replaced. Sloppy steering and uneven tire wear are common when these parts become worn out or damaged.
    These TOTAL CHAOS lower control arms are designed to be compatible with the factory Toyota lower ball joint or the TC lower uniball conversion (sold separately). Rubber bushings are replaced with urethane bushings to provide better off road trail handling and steering response. Less bushing deflection allows the vehicle steering to be more responsive at higher speed on and off road.
    These fully rebuildable lower control arms are hand crafted from mild steel construction making them much stronger than the stock units. Available with single shock tabs or dual shock capability to maximize vehicle dampening control and performance.
    Complete stock replacement lower control arm upgrade.
    Fully boxed mild steel construction features internal gussets for added strength.
    Lower ball joint location moved slightly forward to increase caster for alignment.
    Lower shock tabs are designed to work with all brand aftermarket coil over shocks.
    Lower control arms are pre-tabbed for dual 2.5" diameter shock capability.
    Compatible with a factory Toyota ball joints or can be installed with the TC lower uniball conversion.
    Urethane pivot bushings reduce deflection compared to a rubber bushing offering a tighter steering feel.
    Zerk fittings allow for easy maintenance on the lower pivot bushings.
    Three stage powder coat includes a durable clear coat.
    Hand crafted in the U.S.A.
    NOT COMPATIBLE WITH 4"-7" SPINDLE/DROP BRACKET LIFTS
