Total Chaos Uni-ball Installation - Clunking Noise
Discussion in 'Southern California' started by glitch1213, Jun 15, 2018.
  1. Jun 15, 2018 at 6:50 AM
    glitch1213
    glitch1213 [OP] Well-Known Member
    2024 Tacoma TRD Offroad 4x4
    Hey Taco fam.... Anyone in the Orange County area have any experience installing uni-balls? A few weeks back I started to get a really bad clunking noise from the front passenger side of the truck. Turns out the uni-ball needs to be replaced on the lower control arm. I ordered through @TOTAL CHAOS , but have no experience installing one.
  2. Jun 15, 2018 at 8:16 AM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    https://youtu.be/HjAqneTSDys
    Same applies to the lca. Might want to check out to see if you have an issue if your stuff is only a year old. Should get a good 3 years out of a uniball.
    Around 4 minute mark show how to press out a uniball.
    tcjacado and Drainbung like this.
  3. Jun 15, 2018 at 8:27 AM
    glitch1213
    I've read through some of the other posts, looks like most people tighten the bolt a bit more and it takes care of the issue. Had everything re-torqued a week ago and I'm still hearing it. I double check before replacing.
    Thanks bud.
    MadTaco461[QUOTED] and Drainbung like this.
  4. Jun 15, 2018 at 9:02 AM
    glorifiedwelder
    glorifiedwelder IG= @Liquid_Torch
    jason
    Santa Clarita, ca
    double cab trd sport
    Definitely check the torque on the bolt. They will work their way loose every once in a while. That’s one of the main reasons I throw in a free re-torque @500 miles on installs I do.
    tcjacado and SixthSnail like this.
  5. Jun 15, 2018 at 9:14 AM
    glitch1213
    I'll pick up a torque wrench and give it another shot this weekend. Appreciate it.
  6. Jun 15, 2018 at 9:34 AM
    glorifiedwelder
    jason
    Santa Clarita, ca
    No problem. You’re setup is pretty new I’d definitely check torque before replacing anything
  7. Jun 15, 2018 at 9:54 AM
    glitch1213
    Yeah, not too old. When you did the Archive Garage install for me, the suspension was only a few months old, at most.
  8. Jun 15, 2018 at 10:03 AM
    glorifiedwelder
    jason
    Santa Clarita, ca
    Yeah that’s I was basing it on. Have you jacked the truck up from that control arm and tried to see if the wheel has any play in it?
  9. Jun 15, 2018 at 10:59 AM
    glitch1213
    Yep, isolated the noise to that corner, jacked that corner up, and then put a pry bar under the tire and saw it moving/clunking
  10. Jun 16, 2018 at 3:51 AM
    tetten
    tetten Cynical Twat Waffle
    Andy
    Socal
    That doesn't sound right at all. Are you sure it was the uniball? This is what a bad uniball looks like.
  11. Jun 16, 2018 at 10:04 AM
    glitch1213
    Yeah, sent an email to @TOTAL CHAOS and they confirmed as well. Had to order a new kit. Installing now, so fingers crossed.
  12. Jun 16, 2018 at 2:05 PM
    glitch1213
    That was a waste. Replaced it, no noise for a while, then at full lock left made a loud ass clunking noise.
  13. Jun 16, 2018 at 2:09 PM
    Darth_Yota
    Darth_Yota I intend to live forever, or die trying.
    Cam-moron
    Somewhere USA
    Dented, broken-down ‘08 hoopty
    Ain’t good’nuff for insta
    Check your coilover
  14. Jun 16, 2018 at 2:15 PM
    glitch1213
    Anything specific I should look for. I’ll do that now.
  15. Jun 16, 2018 at 3:44 PM
    Darth_Yota
    Cam-moron
    Somewhere USA
    At full lock the actual coil sometimes reseats itself. May have been what you heard clunk. Or the steering stop on the spindle moving against the stop pad on the lca. If you can get a video, or audio file of the clunk when it happens that’ll go a long way towards figuring out what it could be. Good luck, hope you find it.
  16. Jun 16, 2018 at 3:47 PM
    scleaf
    scleaf Well-Known Member
    Torrance, California. USA
    2013 Silver Tacoma TRD 4x4
    SaBellCo's Tailgate Lock :), Cable mod
    100 ft lbs on the uca bolt
  17. Jun 17, 2018 at 10:58 AM
    glitch1213
  18. Jun 17, 2018 at 2:48 PM
    glitch1213
    Just torqued to 100, can’t drive it yet because I’m blocked in for a family bbq, but I posted the sound as well.
  19. Jun 17, 2018 at 4:25 PM
    glitch1213
    Update. Torque to 100 didn’t work.
  20. Jun 18, 2018 at 9:28 AM
    TOTAL CHAOS
    TOTAL CHAOS WWW.CHAOSFAB.COM Vendor
    Corona, CA
    Sorry about the issue!
    We know you're in touch with the shop, but thought we could help here. Just have a couple of questions. Could you post up some photos of your setup? We'd like to see multiple shots of the front suspension. Include different angles showing all of the components.
    How long have you had the kit? What kind of use is the vehicle seeing?
    Happy to help get this resolved for you.
    TOTAL CHAOS
    WWW.CHAOSFAB.COM
