Total chaos uniball rebuild kit
Discussion in 'Suspension' started by Brain52, Jul 17, 2019.
  1. Jul 17, 2019 at 3:42 PM
    Brain52
    Brain52 [OP] Member
    Socal
    2015 Tacoma DCLB
  2. Jul 17, 2019 at 4:40 PM
    JT@Bajakits
    JT@Bajakits Well-Known Member Vendor
    JT
    Race Trucks and Off Road Suspension
    FK is the most common uniball that the industry uses.
    There are different Part numbers from FK so you will have to talk to TC to see if that is the one they use
  3. Jul 17, 2019 at 4:52 PM
    djthicks
    djthicks Well-Known Member
    Orange County
    07 DCLB TRD Sport
    King's all around Long traveled Methods KO2s
    Item: FK 1'' WSSX-T Spherical Bearing, Wide Series w/Teflon WSSX16T-F1 (WSSX16T-F1) is the parts numbers i got from them just haven’t installed yet though
    DUSTYNEOJET and jberry813 like this.
  4. Jul 17, 2019 at 6:05 PM
    Brain52
    Brain52 [OP] Member
    Socal
    2015 Tacoma DCLB
    Thanks djthicks purchased the kit and will be installing as soon as they get here . I cant stand the squeak anymore
    djthicks likes this.
  5. Jul 22, 2019 at 3:57 PM
    MunchTIME
    MunchTIME Well-Known Member
    SD, CA
  6. Jul 22, 2019 at 4:11 PM
    Brain52
    Brain52 [OP] Member
    Socal
    2015 Tacoma DCLB
    Munchtime I’d say if they aren’t squeaking or causing uneven tire wear keep running them . But then again I’d pick up the kit I posted I changed my uniballs and all I can say is the difference is night and day no more sloppy steering and the kit is cheap
  7. Jul 22, 2019 at 4:14 PM
    MunchTIME
    SD, CA
    That's a good point, it's a new-ish truck. may as well replace them while they're off the truck. Did you swap your poly bushings too?
  8. Jul 22, 2019 at 4:17 PM
    MunchTIME
    SD, CA
    Also, where in Socal are you located? Any chance you'd like me borrow or buy the tool off of you when you're done with it?
    Brewno_ likes this.
  9. Jul 22, 2019 at 4:20 PM
    Brain52
    Brain52 [OP] Member
    Socal
    2015 Tacoma DCLB
    No I didn’t replace them don’t fix what isn’t broken. Also didn’t replace both just one the other seemed fine .im In Orange County and you can borrow it if your near me
  10. Aug 15, 2019 at 4:49 PM
    Brewno_
    Brewno_ Well-Known Member
    Bruno
    2010 Tacoma
    I have a tool you can use for the uniballs. not for sale but you can borrow it
  11. Aug 15, 2019 at 4:51 PM
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Can also retrofit Icon Delta joints I believe.
