Total Chaos upper control arms touching coil over springs at full droop?
Discussion in 'Suspension' started by DevL, Aug 6, 2010.
  1. Aug 6, 2010 at 10:11 AM
    DevL
    DevL [OP] Well-Known Member
    I have heard that Total Chaos upper control arms will limit travel and contact your coil over springs at full droop using 1" longer King coil overs. First is that true? Any pics? Will that be true with any after market 1" longer coil over set up like Icon or King 2.5" 1" extended coil overs?
  2. Aug 6, 2010 at 10:13 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I have heard about this with the 1.25" uniballs, but not the 1" ones...
  3. Aug 6, 2010 at 10:14 AM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    IIRC I believe that It was Icon coilovers and they had this problem with all the UCAs except Camburg and Icon. I dont think the kings do it, but don't quote me on this.
  4. Oct 9, 2010 at 2:02 AM
    chad68
    chad68 Master Jedi Member I am...
    Chad
    In a (Toyota) van down by the river! Sonoma Cownty
    2009 4x4 reg cab. Modded with more to come
    Polished 16x8 Pro Comp 1069's 4" BS Nitto Mud Grapplers 305/70/16 Magnaflow & glasspack muffler Stainless tip K&N 63 series Aircharger Vent visors Autometer volt and dig. temp. gauge custom mounted Factory chrome rear bumper (not black factory, one) TRD pedal covers TRD skid plate Hurst T handle shift knob Rear Tint Clear bra on the sides Chrome extinguisher Icon non resi coilovers, ICON RR shocks, black seat covers. And some other crap
    Pretty sure you could use a spring compresser and rotate/spin your springs 180 degrees (Or what's needed) , so that at full droop your UCA will be in between two of your spring coils , instead of hitting a spring coil.
    In other words at full droop your arm would fall in between two spring coils were there would be like a 1.25-1.5" gap (empty space).
