Total chaos Weld-on Spindle Gussets with swaybar AND max wheel backspacing?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Crom, Jan 25, 2016.
  1. Jan 26, 2016 at 10:16 AM
    AaronArf
    AaronArf Well-Known Member
    Aaron
    VA Beach
    2023 LR OR DCSB
    sway bar gussets are stronger, thats why I run em
  2. Jan 26, 2016 at 10:22 AM
    chenbro
    chenbro ¯\_(ツ)_/¯
    Broomfield, CO
    2009 Silver DCSB TRD OR
    What haven’t I changed?
    I have the TC gussets w/ sway bar and am running 255/85/16 tires on 16x8 wheels and 4" backspacing. I agree with @NYCO that you should play it safe and consider getting some wheel spacers. Better to have them and not need them than, well, you know..
    Crom[OP] likes this.
  3. Jan 26, 2016 at 10:23 AM
    zscott
    zscott Well-Known Member Vendor
    Zach
    Utah
    13 DCSB Off-Road 4x4
    @Crom
    Here are some pictures I just snapped of mine. Sorry about the engineers scale and the poor angle of the photos, I didn't have a normal tape and just my phone. I have about 1.5" from the edge of the tire to the gusset, slightly more to the edge of the wheel.
    Since I have the same size tires as you and 3.5BS wheels vs the 4.5 BS you are looking at you would probably have about 1/2" of space. Getting close but doable in my opinion.
  4. Jan 26, 2016 at 10:29 AM
    AaronArf
    Aaron
    VA Beach
    2023 LR OR DCSB
    Using some calculators comparing to my set up I came up with
    Results
    7mm MORE Inner Clearance:(the inside of the wheel to the strut housing)
    31mm LESS Outer Position:(position of the outside edge of the wheel)
    Tire width/sidewall bulge is my only concern with a narrow rim.
  5. Jan 26, 2016 at 10:46 AM
    Crom
    Crom [OP] Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Appreciate all the help and feedback. I think I may end up doing the no-sway-bar gusset with extra tie rod gusseting.
    Like this:
    @yotastaco
    SonnyBones and NYCO like this.
  6. Jan 26, 2016 at 10:47 AM
    Crom
    Nick
    San Diego, CA
    Millions
    Thank you for going through the effort. Appreciated!!!
  7. Jan 26, 2016 at 10:52 AM
    zscott
    Zach
    Utah
    No problem. The only place I could see you having issues is during articulation. I am not sure if that gap changes at all or how drastically it does change. If its not much you should be fine.
  8. Jan 26, 2016 at 10:55 AM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    airing down you will see the bulge move down most likely too?
    always been curious to see if it makes a difference airing down...
  9. Jan 26, 2016 at 11:03 AM
    zscott
    Zach
    Utah
    Yeah that is something I hadn't thought of. I would think most of the deformation would occur at the bottom where the tire is contacting the ground? :confused:
  10. Jan 26, 2016 at 11:05 AM
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
    well yes, that's the most obvious area of change...but i wonder if the top, unweighted section changes at all with less pressure
  11. Jan 26, 2016 at 11:05 AM
    AaronArf
    Aaron
    VA Beach
    2023 LR OR DCSB
    No issues with running extremely low pressure on mine. Much tighter then the above. 619bc874406ee91149e90624b661f32f_074265c6af3276b688eb631f3186b73629d4529c.jpg
    Used my key for scale. that's sitting on the wheel lip.
  12. Jan 26, 2016 at 11:11 AM
    zscott
    Zach
    Utah
    Thats about how I imagine @Crom would be with his setup. I have much more space with mine.
  13. Jan 26, 2016 at 11:14 AM
    Crom
    Nick
    San Diego, CA
    Millions
    Very interesting! So you're saying that when airing down, the tire does indeed bulge a little bit at the top?
  14. Jan 26, 2016 at 11:15 AM
    AaronArf
    Aaron
    VA Beach
    2023 LR OR DCSB
    No...just saying zero rub marks on the spindle or inner tire and I've wheeled with single digit air pressures :thumbsup:
    and wow that picture is blurry sorry guys ! :bananadead:
    Crom[QUOTED][OP] likes this.
  15. Jan 26, 2016 at 11:19 AM
    #35
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    thats freaking close!!!
    Just run the no swaybar gussets, truck will ride nicer without the swaybar anyways.
  16. Jan 26, 2016 at 11:19 AM
    #36
    Crom
    Nick
    San Diego, CA
    Millions
    Okay. Thanks. That helps. Like Bob above, I've wondered if the top portion of the tire bulged (even if a little) when aired down. As far as I could tell it didn't but I've never got in there and measured like you. Appreciated!
  17. Jan 26, 2016 at 11:24 AM
    #37
    AaronArf
    Aaron
    VA Beach
    2023 LR OR DCSB
    I don't run a sway bar, won't fit...too short. LT problems :headbang: Sway bar gussets are just stronger. When I went to install I knew it would be tight so I had a spare set of ungusseted spindles on stand-by but it cleared. 25k miles on it like that.
  18. Jan 26, 2016 at 11:32 AM
    #38
    NYCO
    NYCO go explore...
    bOb
    Colorado
    dents & scratches
    i ran a 305/70/17 MTR on a 4.5" BS with the non-sway gussets for a while, aired up and down no issue...
    this was that setup..
  19. Jan 26, 2016 at 12:57 PM
    #39
    nd4spdbh
    SoCal
    got it. Makes sense as the swaybar gussets make a triangle of sorts out of the spindles.
  20. Apr 14, 2016 at 1:39 PM
    #40
    mach1man001
    mach1man001 eh whatever
    Rob
    Bellingham, MA
    2024 Tundra Limited
    I love my new truck but miss my Tacoma
    Maybe I should start a new thread but I am wondering the same thing about the all-pro gussets. I have 265's on 17" FJ cruiser wheels and 285's on 16" 1st gen Tacoma wheels and wonder if they will clear without spacers.
