Total Headscratcher on Gangster Lean
Discussion in '1st Gen. Tacomas (1995-2004)' started by MikeS, Nov 8, 2013.
  1. Nov 8, 2013 at 3:17 PM
    4runnercaged
    4runnercaged Well-Known Member
    cody
    arizona
    LOL
    98 toyota tacoma, stock
    are the shackles in the same position on both sides?
    that is so weird its in that much negative arch and its not even close to the bump stop.
    im betting on a bent frame.
  2. Nov 8, 2013 at 3:27 PM
    MikeS
    MikeS [OP] Member
    Tacoma 4wd, 4 cyl
    Yes, the shackles appear to be in identical position. And yeah, I hear ya - I can't get my mind around the whole thing at all. I appreciate the ideas being bounced around guys.
  3. Nov 8, 2013 at 3:28 PM
    richardbui23
    richardbui23 That guy
    Richard
    Arlington Texas
    Stacy
    check the markings on the dakars. did you install the "-" on the driver side? or the passenger?
  4. Nov 8, 2013 at 3:41 PM
    MikeS
    MikeS [OP] Member
    Tacoma 4wd, 4 cyl
    The springs came from Wheeler's clearly marked with "L" and "R" (or D and P, cant remember now) and that's the way I installed them. Where would the "-" marking be?
  5. Nov 8, 2013 at 4:13 PM
    Deathbysnusnu
    Deathbysnusnu Work is just a daily detour to happy hour.
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    I would try removing the packs, set them side by side and see if they're equal arch... Maybe try switching sides and see if you get the same effect.
    Looking at those pics, I don't like the looks of the leaves themselves, they seem separated and don't appear to sit well together but it could just be a camera thing. You might just have a weak pack. This is all speculation, really hard to go over it not being there.
    I would think if your frame were bent that the bed and body wouldn't line up too well, but that may depend on where it's bent.
    You don't have it on backwards do you?;)
  6. Nov 8, 2013 at 4:19 PM
    jspansel
    jspansel Just duct tape it
    Jay
    Central OR
    01 V6 Xtra Cab Tacoma, 5 Speed, 4x4, Lifted
    5100s front at 2.5" with Moog replacement springs, 5100s in rear with 2" Wheeler's AAL
    Seems strange since this happened with the previous leaf packs correct? You replaced them with these new ones and it is still doing it? Not sure what else can cause that though if nothing is bent. Spring is the only real thing holding the weight up, correct? Can you put the springs in backwards? Not left to right, but just turned around the wrong way? I dont see that causing something THAT bad though..? :confused:
  7. Nov 8, 2013 at 4:38 PM
    teneighty
    teneighty I'd rather be skiing...
    Right behind you. NY
    18’ F150 SCREW LB 3.5 EcoBoost
    Bilstein 5100’s (x4), 275/65/20 Cooper XLT AT3’s
    No way there is that big a difference in the two sides. And even if they were backwards why the F does it look so loaded. The leaf appears to be under stress/more weight than the other... You have 500# sand bag on that side??!! Lol
    Wonder if the leaf pack was bad?...
    Very weird...
  8. Nov 8, 2013 at 5:33 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    Thats the only dance i do!!!! moving like bernie that is
  9. Nov 8, 2013 at 5:39 PM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Just throwing idea's out there...
    You mentioned sand, I was thinking lead body filler, but that was way back in the day..:)
  10. Nov 8, 2013 at 5:59 PM
    FTD
    FTD Well-Known Member
    NOTHING about how your truck is sitting looks right. Kinda looks like the entire weight of the vehicle is coming down on the drivers side rear end. And that spring...yikes. I wouldn't drive that thing down to the gas station never mind out in the middle of the desert.
    More pics would help, but I think you need to get acquainted with someone who can straighten a frame.
    BTW, kudos, falconry is cool. Full-time job as I understand it. Got to hold one as a kid. Unreal how much strength is in the talons.
  11. Nov 8, 2013 at 7:16 PM
    teneighty
    Seriously! Haha
  12. Nov 8, 2013 at 7:19 PM
    Deathbysnusnu
    Brett
    Fort Crawlins, CO
    Vintage Tundra
    Dog, camper.
    Before Bondo, there was lead. Hence the term "lead sled" :D
    Apologies to the OP for the useless trivia, I hope you get that lean figured out.
  13. Nov 8, 2013 at 9:20 PM
    GLD01
    GLD01 Well-Known Member
    Jamie
    Denver, CO
    Tacoma SR5 TRD
    Toytec lift coils w/Bilstein 5100's; OME Dakars w/Bilstein 5100's; Camburg UCA's; Gray wire mod; Deck plate mod; Cooper Zeon LTZ 265/75 R16 tires
    No. The rear axle aligns with the pin in the leaf pack, which is not centered in the length of the leaf pack.
