Total Tail Stage 1 Back in Stock at Meso
Discussion in '3rd Gen. Tacomas (2016-2023)' started by FL_TRD Sport, Jun 4, 2022.
  1. Jun 24, 2022 at 6:47 AM
    #41
    Tacospike
    Two Trucks
    I've never seen them come into stock or the brake bulbs.
    However there is an option for back up's (spares)
    16-22 TOYOTA TACOMA MESO TOTAL TAIL STAGE 1 UPGRADE V6 TRITON SWITCHBACK 921 (vleds.com)
    slowpoke16taco likes this.
  2. Jun 24, 2022 at 6:47 AM
    #42
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Yes, they work perfectly. The Meso switchback bulb that is provided uses a 3 pin threaded connector. The VLEDS kit I linked gives you the T adapters and they mate up perfectly between the meso switchback, meso harness, and of course a branch for the resistor to connect to so that it can all be plug and play.
    For a good metal surface for the resistor to adhere to and not melt anything else, I used the metal wall that is directly behind where the tail light bulbs are. I got under the bed, found the front side of that wall (towards the front of the truck), stuck on the resistor there, then the resistor wiring I ran through a big circular hole which led the wiring into the tail light wiring area. Easy as can be. 15 ohm resistors don't get very hot in most use but they can still get decently warm if the turn signal is on a while. So it made sense to adhere mine to metal and away from other objects.
    ClimbMaintain[QUOTED] likes this.
