Totmacher's maybe not right but it works Build
Discussion in '2nd Gen. Builds (2005-2015)' started by totmacher, Aug 8, 2014.
  1. Dec 19, 2017 at 4:45 PM
    #241
    dirty deeds
    dirty deeds Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    When did this start? Never knew it was a problem
    ChadsPride likes this.
  2. Dec 19, 2017 at 4:48 PM
    #242
    totmacher
    totmacher [OP] automotive hypochondriac
    Daniel
    TN (memphis-ish)
    Toyotas
    Cut & broke off stuff. Prolific ziptie and tape usage.
    Started last summer (2016). Sporadic, unpredictable. Sometimes goes months without doing it. Sometimes it`s multiple times in a single trip.
  3. Dec 19, 2017 at 4:52 PM
    #243
    dirty deeds
    Nick
    Eastern KY
    Carbon build up in/out? Checked plugs for even wear or discoloration? Loose wire somewhere?
  4. Dec 19, 2017 at 4:55 PM
    #244
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    Plugs looked normal when I changed them last fall.
    Clean throttle body and MAF.
    Cleaned PCV.
    Maybe a wire. :notsure:
  5. Dec 19, 2017 at 5:00 PM
    #245
    dirty deeds
    Nick
    Eastern KY
    Checks plugs again if it's not too much trouble. Definitely look at power and grounds from the battery on. Could be simple as loose connection or corrosion, hope it's not a dying alternator.
    I say this because this has happened on prior vehicles to me. Ended up being plugs and spark wires on one and alternator on another. Countless loose wires on my used up road working vehicles and rotten vacuum lines too
    JKU3000, Dave41079 and ChadsPride like this.
  6. Dec 19, 2017 at 5:20 PM
    #246
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    2011 TRD TX 4x4 MGM DCSB
    Lift, 285's, mud, and scratches
    Gremlins
    dirty deeds likes this.
  7. Dec 19, 2017 at 5:20 PM
    #247
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    Those caused timing to retard sporadically?
  8. Dec 19, 2017 at 5:20 PM
    #248
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    I'll go feed them after midnight.
  9. Dec 19, 2017 at 5:28 PM
    #249
    dirty deeds
    Nick
    Eastern KY
    I get those bastards in computers, printers, servers, and switches all the time at work!
    11TRDTX[QUOTED] likes this.
  10. Dec 19, 2017 at 5:29 PM
    #250
    11TRDTX
    11TRDTX bruh
    Memphis, TN
    Microwave will kill 'em
    dirty deeds[QUOTED] likes this.
  11. Dec 19, 2017 at 5:29 PM
    #251
    dirty deeds
    Nick
    Eastern KY
    Yes. Strange enough.
    I also bought some really cheap vehicles just to get me to work for a while, and then buy another a year later.
  12. Dec 19, 2017 at 5:31 PM
    #252
    dirty deeds
    Nick
    Eastern KY
    So will sunlight
  13. Dec 20, 2017 at 5:32 AM
    #253
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    after reading more, I really think it's oil control valve sticking. Some Land Cruiser and Lexus guys have described same power loss like it won't accellerate past 60km/h (40mph). OCV clean or replace fixed it. Usually threw code for them and they typically had rough idle too but not always.
    Looks easy enough to pull and check.
    Or maybe see if dealer will change as warranty since i have video showing it happen now.
    ChadsPride and dirty deeds like this.
  14. Dec 20, 2017 at 5:35 AM
    #254
    dirty deeds
    Nick
    Eastern KY
    Try the warranty route.
    It was put to me, "If some kind of fluid touches the part, it's under the power train warranty." I've not needed any warranty replacements yet, but I think you should at least try there first.
  15. Dec 20, 2017 at 5:39 AM
    #255
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    yeah. and i was still within 36000 regular warranty first time i went in to have them check it. It's on record that they couldn't replicate the issue. :rolleyes:
  16. Dec 20, 2017 at 5:40 AM
    #256
    dirty deeds
    Nick
    Eastern KY
    Sounds like my kazoo wind noise BS.
    My own POS sperm donor happened to be the mechanic that drove my truck too. He couldn't get it to happen either, but he agreed that it does in fact happen on the Tacoma and he said he has the same issue on his Ranger
  17. Dec 26, 2017 at 6:17 PM
    #257
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    My wife knew just want I wanted for Christmas.
    She's a keeper.
  18. Dec 31, 2017 at 1:05 PM
    #258
    ChadsPride
    Sponsored by TacomaWorld.com
    Happy New Year buddy!
    :cheers:
  19. Jan 6, 2018 at 10:28 AM
    #259
    totmacher
    Daniel
    TN (memphis-ish)
    Toyotas
    I went to the lake planning to fish.
    There was this strange hard layer on the water.
    All the way across!
    WTF Tennessee!?
    JKU3000, dirty deeds and ChadsPride like this.
  20. Jan 6, 2018 at 6:04 PM
    #260
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    And still can't get any snow :rolleyes:
