Touchless or Brushed or does anyone care on Car Washes?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JBone25, Mar 22, 2018.
  1. Mar 23, 2018 at 11:11 AM
    #61
    Sugar Silva
    Sugar Silva Well-Known Member
    Dave
    San Diego, CA
    16 Toyota Land Cruiser
    Kings Sliders TRD Rock Warrior Wheels Tint
    Neither are good ideas. While being the lesser of two evils, the touchless car washes won't do a great, or even a good job, removing dirt. In the 4 years I've owned my truck I've only driven it through a wash once (touchless) and this was after spending a day on a dirt road. I knew it would be a week before I had time to wash it properly and I just wanted to get the top layer of filth off. I'll also mention that if you have paint chips, the pressure sprayers can cause damage. This happened to my wife's car a few years back. She had a chip on one of the doors and the pressure washer managed to get under the paint and blow off a small patch.
    The brushed washes are even worse. YES they will leave swirl marks. The brushes are extremely dirty and essentially beating the dog piss out of your paint. Avoid them if you care about such things.
    Even hand washing will cause swirls if done improperly. You can go way down the rabbit hole when it comes to researching how to properly maintain your truck's appearance. You just need to determine how much you care and how much time you can dedicate to it.
    Bottom line is, anytime you touch your paint, you are either making it worse or making it better.
  2. Mar 23, 2018 at 11:15 AM
    #62
    Suehog60
    Suehog60 Active Member
    Sioux Falls, SD
    2016 Tacoma TRD 4X4 Off Road
    TRD wheels, Michelin Defender LTX tires, Extang solid fold bed cover, OE roof rack added, 32" Caliraised LED light bar behind lower grill, Husky Liner floor mats, OE sliding bed divider, LED strip lights under bed rail, Fumota oil drain valve, TRD Pro skid plate, Warn front bumper, Weathertech in-channel vent visors, Updated TSB front door seals, Glove box and center console organizers,
    I live in South Dakota so hand washing outside is not practical in the winter but there are good car washes everywhere and most have underbody wash as your drive in. I use the brushless and have found the car washes that are better than others. Spring to Fall I use 2 bucket hand wash at home but will take the truck thru brushless occasionally, but not the Vette which is not driven in the winter or the rain.
  3. Mar 23, 2018 at 11:41 AM
    #63
    Norsemanvike
    Norsemanvike Well-Known Member
    Escondido, CA
    '18 Sport 4x4, DblCb, ShBd, BBP
    I plan on filling two 5-gallon buckets with water ( with lids ) at home, take them to the self-wash, hand wash it there myself since it's shaded, do all of the cleaning I need to do, rinse it with their spray gun and spotless rinse. Dry it on the freeway, back home and prep for clear coating/wax.
  4. Mar 23, 2018 at 12:09 PM
    #64
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    I work at a plant near cooling towers, I drive my truck in the woods, I don't really worry about using a carwash or not. I figure running through a car wash is much better than letting it sit until I can get to it.
    Touchless doesn't work all that well. I go to a well maintained brush wash place. I use the buckets and brushes to knock loose the dirt on the back, then drive through. It's not a show car, it sits outside, it gets pollen, chemicals, dirt, bird poop and whatever on it.... I'm not worried about a brush and I have better things to do with my time.
  5. Mar 23, 2018 at 12:18 PM
    #65
    jethro
    jethro Master Baiter
    Geoff
    Southern NH
    2020 Ford F-150 Lariat 5.0L V8
    I go to car wash that has the big spinning brushes. If it doesn't touch your car, it won't clean it. And I don't go if I don't have 15 minutes after to wipe down the whole truck. If you don't you'll get water spots and dust will stick to the water spots.
  6. Mar 23, 2018 at 3:29 PM
    #66
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    shakerhood likes this.
