touchscreen radio
Discussion in '3rd Gen. Tacomas (2016-2023)' started by harrison20, Sep 13, 2023.
  1. Sep 13, 2023 at 2:25 PM
    harrison20
    harrison20 [OP] Well-Known Member
    Has anyone else had their touchscreen die? I mean it is on and I can see it, but when I try to move between say CD or FM or bluetooth it doesn't respond, so for now I am stuck on bluetooth. 2017 Tacoma. I guess the whole unit would need to be replaced. Any suggestions for an aftermarket replacement unit?
  2. Sep 13, 2023 at 2:30 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    Xx_Evilvirus_xX likes this.
  3. Sep 13, 2023 at 3:11 PM
    099 Well-Known Member
    2022 White Tacoma Double Cab SR5
    Search the forum here. Someone posted to hold the power button to try to reset the radio. I may be wrong.
    Chew likes this.
  4. Sep 13, 2023 at 4:43 PM
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    reboot the whole truck
    BigJosh likes this.
  5. Sep 14, 2023 at 5:47 AM
    Shawgf2000
    Shawgf2000 Well-Known Member
    2018 Silver TRD Off Road
    Try holding the power button down until the screen goes dark, it's the equivalent of hard restarting a PC.
    Chew likes this.
  6. Sep 14, 2023 at 10:25 AM
    Lorescar
    Lorescar Well-Known Member
    Carlos
    Oceanside, CA
    2021 TRDOR DCSB
    TRD Bilstein Lift & 265/75/16 Wildpeaks
  7. Sep 14, 2023 at 10:27 AM
    Puppypunter
    Puppypunter Well-Known Member
    Johnny
    2019 Black SR
    What trim?
  8. Sep 14, 2023 at 10:43 AM
    Rainoffire
    Rainoffire Well-Known Member
    2017 QS DCLB TRD Sport
    It fits into the premium bezel perfectly.
    If you use the stock mounting brackets, you will need to drill a hole or two for a flush install. Not particularly difficult, I also used rubber washers to raise a corner or side for the OCD in me.
    drizzoh likes this.
  9. Sep 14, 2023 at 10:56 AM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    This. With factory brackets and 2021+ bezel they fit perfect with no trimming. I only needed to drill 2 holes in the brackets. IIRC I had to space or bend a bracket on the bottom right corner as well to get a perfect fit. I also lined the inner bezel surround with felt tape where it contacts the radio to get it to fit snug with no visible gaps or rattles. Overall was a pretty painless install though with a Maestro.
    Lorescar[QUOTED] likes this.
  10. Sep 14, 2023 at 11:21 AM
    Lorescar
    Carlos
    Oceanside, CA
    2021 TRDOR DCSB
    Thanks for the info. I may have to consider upgrading to this
    drizzoh[QUOTED] likes this.
  11. Sep 15, 2023 at 5:28 AM
    harrison20
    SR5
  12. Sep 15, 2023 at 7:21 AM
    Puppypunter
    Johnny
    2019 Black SR
    Thats the larger headunit?
