tough country 3 inch spacer lift or fabtech 3 inch coilover?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jd17usmc, May 11, 2011.
  1. May 11, 2011 at 9:44 AM
    jd17usmc
    jd17usmc [OP] Well-Known Member
    jansen
    Gainesville, FL
    2012 TRD Sport 4wd doublecab grey 6 speed
    Bilstein 5100 all around to level it out.
    i just moved from my 07 black single cab prerunner with 32 mud terrains and a skyjacker leveling kit, to a 2011 black dc 4wd. had the dealership move over the wheels and tires from my old truck to the 2011. but moving the leveling kit was too much of a hassle.
    so i may get another leveling kit for the time being, however i want to eventually go to a 3 inch lift new wheels with offset and bigger tires. my local shop suggests the tough country spacer lift they said they could have it installed and balanced for under $600. but i want to do things right for the long haul and i like the fabtech 3 inch lift. they said it would be around 4 grand to install however. looking for help from anyone on application of the lifts quality opinions and possibly whats the biggest i can go with tires.. id love to squeeze something close to 34s under my truck even if i have to do some cutting. i keep seeing clears 33 an i know thats conservative. just dont know how conservative.. any help would be appreciated, thank you.
  2. May 11, 2011 at 11:04 AM
    bsteinkamp
    bsteinkamp Well-Known Member
    Bruce
    Memphis
    2011 TRD Sport
    6" Fabtech Lift LR UCA's Terra Grapplers 285/70/17 American Racing Wheels 17X9 Wind Deflectors
    King coilovers 2K.
  3. May 11, 2011 at 11:10 AM
    TRDSPORTtaco
    TRDSPORTtaco Well-Known Member
    St. George UT
    06 TRD Sport
    Lift and Wheels
    If you paid $4g for a 3" lift to be installed I would have to kick you in the nutz!
  4. May 11, 2011 at 11:11 AM
    TeamSarcasm
    TeamSarcasm Flawless Escalation to the Ludicrous
    The better coast
    x2 haha ^
  5. May 11, 2011 at 11:13 AM
    TRDSPORTtaco
    St. George UT
    06 TRD Sport
    Lift and Wheels
    Oh and I used to have the Tough Country 3" spacer lift on stock struts and coils. WORST DECISION EVER MADE!
    I switched to 5100's all around and 885's. That combo was $500. Get a rear AAL for like $100 and install everything in your drive way.
    Do not get a spacer lift.
  6. May 11, 2011 at 11:14 AM
    kmok
    kmok Plastidipped ma Hootus!
    Kyle
    Columbus, Ohio
    2005 Subaru Outback XT 5MT
    OME coils and shocks up front. OME shocks or bilstein 5100 shocks and a new leaf pack or AAL in the rear. Try searching to see what setups people are running.
  7. May 11, 2011 at 11:14 AM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Neither option sounds good.
    Look into a set of Bilstein 5100s, if you are on a budget. If not then look into a set of ICON coilvers.
  8. May 11, 2011 at 11:22 AM
    Mexicutioner
    Mexicutioner Well-Known Member
    Joel
    Chula Vista, CA
    '10 4x4 TRD DCSB Off Road
    FRONT: Total Chaos 3.5 4x4 kit, Fox 2.5 x 8" coilovers REAR: Defined Engineering SUA kit, Fox 2.5 x 14" smooth bodies, Fox 2.0 x 4.0" bumps, American Motorsports bolt in bedcage MISC Mcneil Racing Inc Glass all around, Afe stage II cai, weathertech floormats, flowmaster 40, rigid led 30" combo, rigid dually reverse cargo lights, Bamf sliders, 1.25" spidertrax, 20% tint - front, 50% tint - rears AUDIO Alpine w910 headunit, Alpine 6.5" type r components in front, Alpine 6.5" type r coaxials in rear, 2 Alpine 10" type r shallow mount subs w/ custom box, JL Audio 900w 5 channel HD amp, steering controls & reverse camera integrated, Stinger Roadkill matted on entire interior
    Fox 2.5 rr coilovers with rear Fox 2.0 piggybacks. 1800 out the door and diy. spacers blow
  9. May 11, 2011 at 11:27 AM
    kingtaco
    kingtaco Well-Known Member
    San Gabriel Valley
    Spindle lift with some 5100's and use your stock coils. No need for new uca's. Should be around $1200-$1500. That's what I did. Very happy with the ride.
  10. May 11, 2011 at 3:12 PM
    kmok
    Kyle
    Columbus, Ohio
    OP is 4x4 so he can't get lift spindles.
  11. May 11, 2011 at 4:14 PM
    BigGameHuntr
    BigGameHuntr Member
    VA
    07 TRD OR 4X4
    ELITE front bumper w/ Blazer fogs and Smittybuilt XRC8 Comp, Debadged/ blacked out emblems, Morimoto retro, Flowmaster 40 series, URD TCAI, URD MAF sensor calibrator, JBA Headers,OME 885 with 5100's on front and back, LR UCA's, LED taillights/3rd brake light,weatherTech floor liners, Infinity Basslink Sub
    x2 I did the same thing
  12. May 11, 2011 at 4:17 PM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    GO THIS ROUTE!!!
  13. May 11, 2011 at 4:54 PM
    jd17usmc
    jansen
    Gainesville, FL
    see thats the problem i saw with both these kits, the fabtech being ridiculously priced... and ive heard spacers are garbage and as soon as you take them off road you have problems.
    what you suggested sounds like the best way to go. and i see guys trucks on here with similar set ups that look like they have a great stance, and love the ride. but im ignorant to all this, was a little apprehensive about piecing together a lift myself. i guess ill do some more research and go with everything you suggested. where will that put me height wise and stance?
  14. May 11, 2011 at 7:07 PM
    kingtaco
    San Gabriel Valley
    It would help if I knew how to read. Huh?
  15. May 11, 2011 at 7:20 PM
    kmok
    Kyle
    Columbus, Ohio
    Who reads stuff anyways? :D
  16. May 11, 2011 at 7:49 PM
    jd17usmc
    jansen
    Gainesville, FL
    its over rated!
    so just with a little research im seeing maybe the way to go is 5100 all around. to level it out and i can add to that with 885s and AAL to eventually get to 3 inches? does the 885s on the 5100s give the 5100s more than 2.5 lift? and with this combo and maybe some cutting could i fit anything close to 34s under it? or is that a pipe dream?
  17. May 11, 2011 at 9:39 PM
    kmok
    Kyle
    Columbus, Ohio
    5100s all round to start out then upgrading as you can is a good idea. With the 885 and the bilstein shocks set at 0 you should be at 2" or so. You should be able to change the settings to get around 3" of lift. You don't want to go over 3" of lift or shit will start breaking and you'll be going through cv axles and boots like crazy. 34s might fit with some major cutting and the right backspaced wheels or wheel spacers.
  18. May 12, 2011 at 3:00 AM
    jd17usmc
    jansen
    Gainesville, FL
    thank you. thats the most helpful advice ive gotten so far. im hoping with the 5100 and stock springs for now atleast i can get a level ride. and ive also been told that with the 5100s and 885s i shouldnt ever set the 5100s over 0" or ill start having problems. im looking for a good solution and not to F up my new truck if you know what i mean.
  19. May 12, 2011 at 10:40 AM
    TRDSPORTtaco
    St. George UT
    06 TRD Sport
    Lift and Wheels
    From what I have read and seen on here, most people wanting to level out their trucks set the 5100's at 1.75" and had the TSB done in the rear.
    I started out with the 5100's, then waited like ohhhhhh 4 days then bought TC upper control arms, then after putting those on I waited like a week before ordering the 885's. So start off with the 5100's and upgrade from there when you can.
  20. May 12, 2011 at 5:12 PM
    jd17usmc
    jansen
    Gainesville, FL
    thanks, i think thats prolly what im gonna wanna do. what does changing the upper UCA do for you? is it to help with travel or does it affect ride height? and what does the TSB mean, and ive heard people saying that some dealerships will do it for you and some wont.
