Tough decision: 2011 Access Cab 4x4 or X-Runner
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RMCO, Jan 7, 2011.
  1. Jan 7, 2011 at 1:35 PM
    RMCO
    RMCO [OP] Active Member
    Went to my local dealership today set on checking out an X-Runner and turns out thier online stock was wrong and they didnt have one on the lot. What they did have was a 4x4 Access Cab 6 speed. After driving that I'm torn on which truck I should pick now. I don't have any real towing needs, don't hit the trails, or really haul all that much. Sunny Florida is a far cry from Michigan where I moved from so I don't know how much use I would make of a 4x4. I haven't driven an X-Runner but the ride in that 4x4 was damn nice.
    I'm torn. Been lurking around all the Tacoma forums and figured now was as good as any to ask peoples opinions on the two trucks.
  2. Jan 7, 2011 at 1:37 PM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR
    back to bone stock.
    if i had to guess, i would imagine there are more threads from folks wishing they had 4x4, than guys with 4x4's wishing they didnt.
    having said that, it really sounds like you dont need it.
  3. Jan 7, 2011 at 1:39 PM
    Rucas
    Rucas 1st gen > 2nd gen
    Lucas
    Northern Colorado
    1st gen. 4x4 MANual
    sparkles, fairys, and happy things.
    In your suttiation i would go with the xr.
    :burnrubber:
  4. Jan 7, 2011 at 2:54 PM
    RMCO
    What's the main "I should have got the 4x4" comments floating around? I don't remember reading all that many.
    I guess that's my only worry. I don't have a need for a 4x4 now, but that doesn't mean I won't here in the future.
  5. Jan 7, 2011 at 2:56 PM
    SD2011Taco
    SD2011Taco Well-Known Member
    San Diego
    2011 SR5V6 4x4 Grey TRD Offroad Overland Setup
    3" Lift, Lights, CB, Yellow-Top, CBI Bed Rack, Tepui RTT, Shovel/Axe Mount, Maxtrax, ARB OBA, 33" KO2, Sliders
    Florida has a lot of back country and beaches. 4x4 will be really nice for you.
  6. Jan 7, 2011 at 2:59 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    Wants and Needs
    Figure those out and you'll know what to get
  7. Jan 7, 2011 at 3:21 PM
    Raylo
    Raylo Well-Known Member
    MD, USA
    2009 4x4 Access Cab, TRD Sport
    I grew up in FL and say that unless you plan to get on the beaches (like up in the panhandle where the sand is soft and deep) a 4x4 is a total waste. The 2wd XRunner will be faster, get better mileage, be cheaper to maintain. And the Toyota 2wds don't sit lower like most other small trucks so it looks just as awesome. Just my 2 cents...
  8. Jan 7, 2011 at 3:23 PM
    Crom
    Crom Outside
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    You're in Orlando, forgo the 4x4 and get the XRunner.
  9. Jan 7, 2011 at 3:29 PM
    NumNutz
    NumNutz One of the original 7928
    Virginia Beach, VA
    07 Tacoma 4x4 - Kings, TC, Dakars, broken stuff
    Lots.
    It would be worth checking out xr-underground.com. It is the TW of the x-runners.
  10. Jan 7, 2011 at 3:35 PM
    Doomsday
    Doomsday Well-Known Member
    Cypress, TX
    2017 TRD Sport 4x4 DCSB MGM
    Lights, Tires, Wheels,...more to come!
    I would go 4x4, I personally don't know what the purpose of X-runner is.
  11. Jan 7, 2011 at 3:39 PM
    lynyrd3
    lynyrd3 Strength ,Determination ,Merciless,Forever
    Bill
    Upstate New York ,Columbia County
    2008 SR5 AC SUPER WHITE V6 4x4
    Bilstein 6112s at top setting ,1/4" top plate spacer driver side,Total Chaos UCAs ,SS extended brake lines ,Rear 4 leaf Suspension TSB,Wheelers 2" AAL, Bilstein 5125s , SS extended brake lines rear , Toytec dif drop , Hayden high performance transmission fluid cooler,aFe pro dry filter , ,Powerstop drilled and slotted rotors.N-Fab light bar with 4 Hella OR lights , Devil horns by Andres ,Weathertecs floor protector, American Racing wheels Baja 17x8,4.5 BS , 285/70 Falken Wildpeaks AT/3W .Body Armor rear bumper . Extra D rings in bed ,Blue sea fuse block and 100amp breaker ,G-Tek Fab door sill protectors ,blacked out grille , painted pinch weld.Shorty antenna ,HVAC knob mod ,LED dome and map lights , Tri Fold bed cover ,UltraGauge ,Morimoto XB LED fog lights ,
    :headbang:
    4x4
  12. Jan 7, 2011 at 3:39 PM
    RMCO
    Been there doing a lot of reading too. This seemed the less biased crowd to ask, haha. From the initial posts it looks like the xr may be more my speed. Still open to more opinions though.
