Toughness of composite bed
Discussion in '2nd Gen. Tacomas (2005-2015)' started by grivera, May 5, 2009.
  1. May 5, 2009 at 1:14 PM
    grivera
    grivera [OP] Well-Known Member
    Hanover, MD
    '08 DC SR5 4x4, Desert Sand Mica
    Rear Suspension TSB, Bilstein 5100 on all 4 corners-fronts set at 1.75". BFG A/T's @ 265/75/16; Access LE Roll-up cover; Iron Cross Tube SS Steps; Fumoto valve; WeatherTech Liners; AFE Pro-Dry; front side windows tinted 20%; TW Decal!
    I want to buy and haul about 1/2 ton (or more) of 1-2" river rock in my bed. The place I will buy from will dump it in with a bobcat. can the bed survive the stone being dumped in? Whats the most I can carry?
    BTW, I already have the susp TSB.
  2. May 5, 2009 at 1:18 PM
    petersharp
    petersharp Well-Known Member
    Do you need to ask?! It's up there ^
    Louisville, CO
    Ex DC LB Sport owner.
    If I were you I'd put some boards in there - maybe an 8'x4' sheet of OSB cut down to fit. This will stop the impacts of the rock and also help for when you're shovelling them out afterwards.
    Your truck should be able to handle about 1,400lb legally.
  3. May 6, 2009 at 8:48 AM
    grivera
    Hanover, MD
    Thanks for the tip.
  4. May 6, 2009 at 8:52 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    yeah I lay some plywood down. The beds are tuffer than I thought. I put my 454 in the bed using my engine stan. The engine stan has small wheels I thought would wreak havoc, but didn't.
  5. May 6, 2009 at 8:53 AM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    I've never gotten raw rock but when I pick up compost/dirt pretty regularly for my landscaping jobs the truck groans when the bobcat dumps it in.
    Also some bobcat drivers are better than others. I use a tarp.
    The place I get it from with not exceed the weight limit of my truck, one scoop of compost weighs close to 900 pounds & that is a 1/2 yard.
    The same experience when I pick up patio stone, place won't exceed my truck limits & have a guide in the shed stand.
    Post up your experience though, I need get some surpak soon & wanna know what the truck can handle. :)
  6. May 6, 2009 at 8:56 AM
    4getful
    4getful Senior Junior Member In Training
    Dan
    Gilbert, AZ
    09 DCLB 4X4
    6" Pro-Comp Stage 2, 35x12.50x20 ProComp Xtreme All Terrain, 20" KMC Revolvers, 4.88 Gears, Banks Exhaust De-Badged
    I agree that plywood would be beneficial in the unloading of the rock. I actually think that the bed itself would hold up. I think that it would be stronger that a metal bed. It never hurts to be cautious though, I know that I would be. I tend to be a little OCD about that stuff though. I want it to look almost new after being used.
  7. May 6, 2009 at 8:57 AM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    I would do the plywood for the sole purpose of making shoveling easier. I would think a shovel scrapping the bed would cause more harm than the rocks anyway
  8. May 6, 2009 at 9:02 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    You and me both!
    To the Op. Take some pics with it loaded, curious to see how it'll handle the load. The post I put in the bed was around 800lbs.
  9. May 6, 2009 at 9:04 AM
    longbow
    longbow I see you now..................
    Bill
    Indiana
    05 Tacoma Silver Mica TRD 4 Door
    Toy-tec Coil over lift, Eibach 700 lb springs, Sway bar relocate, Total Chaos UCA's, Moto metal wheels, BFG mudterrians, HID, custom 3 piece grill, Highlift jack w/custom mount, Highlift jack cover, bed matt, de-badged 100%, storage box lock mod, using defrost w/o AC mod, short antenna mod, horn re-locate, Tire Gate flat spare tire mount, engine cover painted, bed light (1) mod, wreck bar carrier, Blue Sea 5026 fuse block, center console outlet, flash light mod, Blue Sea inline fuse, Shrockworks sliders, All-Pro front bumper, Piaa 510 driving lights, Warn shackles front, Kennesaw rear bumper, "Tag Boltz" plate lights, Warn shackles rear, Warn M8000 winch, devil horns, BHLM, weathech liners front and rear.....T.W. sticker of course. Custom Sock bed decal for Michele
    good point!!! plus agree with the plywood
  10. May 6, 2009 at 9:05 AM
    LBtaco
    LBtaco Thread killer
    Long Beach , CA
    15 Nissan Leaf
    Jetsons mod
    this was loaded with 1/2 yard of paver sand... maybe 600 lbs?
    this is Non TSB and riding the bumpstops
  11. May 6, 2009 at 9:15 AM
    Krazie Sj
    Krazie Sj Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
    That's an angry looking truck.
  12. May 6, 2009 at 9:27 AM
    Anathollo
    Anathollo www.saveadane.org
    Houston
    07 Tacoma TRD Sport
    Icon coilovers, Rear Fox Resi-shocks, 285/70/17 Toyo A/T's, Touchscreen JVC Headunit, Custom Rhino-lined sub box, Rocksford Fosgate components and Dual Rockford Fosgate 10" shallow subs, Pioneer and Rocksford Fosgate amps, 1250 watts total, Autometer Volt and Trans gauges with Lotek A-pillar, K&N Drop-in filter, WO Seat covers, Tint, NST WP pulley, Hi-lift jack, Diff breather mod, horn relocation mod, extra "D" rings, de-pinstriped, carrier bearing drop, Rear backup 886 bulbs, Camburg UCA's, AMW Catch can, BHLM, OME Dakars with AAL, Procomp 7089's, Front single hoop Demello bumper, Superwinch Tiger Shark 9500, Amsteel 3/8th synthetic line
    Yeah definitely put down some boards! The best is plywood, that way it'll keep all the little stuff from getting into the cracks and small spaces of your truck. I've already hauled a couple of loads of dirt, stones, and pallets of grass and I haven't had any problems. And it makes shoveling out the rocks a breeze.
  13. May 6, 2009 at 9:44 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    +1 to all the posts about putting a board down. The bed will handle it but it'll make unloading much easier- Make sure you watch the bobcat driver with the rear window to the truck...
  14. May 6, 2009 at 10:37 AM
    grivera
    Hanover, MD
    Thanks for all the responses. I have to wait for the ground to dry some in my yard so I don't f'up the lawn when I drive on it. I will kake pics and post. Godd point on the Bobcat operator too-my taco only has 4500 miles on it...
  15. May 6, 2009 at 10:39 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    Been around heavy machine operators all my life watch out for the ones with nick names like Bam Bam. Ask me how I know.
  16. May 6, 2009 at 10:49 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    I haven't been- but I usually just don't trust folks...
    I fly for a living- and I had tons of other pilots out there trying to kill me....I drive daily and I haven't had many days yet where someone hasn't tried to mess up my truck or flatten me on the CBR.
    Just worth keeping an eye out all the time...Maybe I'm a bit paranoid- but it got me this far...
  17. May 6, 2009 at 10:53 AM
    Killer Red Taco
    Killer Red Taco NorCal Rock Whore
    Whatsurname
    BFE–Norcal
    007 Tacoma A/C TRD O/R Impulse Red 4x4
    Bilstein 5100 on front at 1.75 setting • 5100 on back• K&N Air Filter• TRD Seat Covers• Day Time Running Lights• Foglights Anytime• Hella 500 lights in grille• Rear TSB Springs• Alternative Locker Mod• CB and 4 ft firestick II• Billet Grille• Kid puke in the back!• 265/75R16 Goodyear MT/R• 16" Devino wheels• Hose Clamp Mod• Revenge Fab Sliders• No Sway Bar• A Hottie as Copilot
    just dump it in there. I had a set of leaf springs in my bed beating around on bumps and fast turns and there was never any damage.
    Just don't let him dump a full load at once, a little at a time will do.
    Bam Bam the the loader driver is cracking me up.
  18. May 6, 2009 at 10:54 AM
    w8n4mud
    w8n4mud I'm back.
    Albert
    Chula Vista, CA
    2019 Tacoma Off Road DCSB
    Stock. Purchased 2/17/19. Cement!
    ^ yeah me too.
    Put a piece of commercial carpet, then the plywood. That way you don't scratch the bed with a rock or two that got under the plywood before pulling (sliding) it out.
  19. May 6, 2009 at 11:19 AM
    sataco
    sataco Well-Known Member
    san antonio tx
    06 SR5 PRERUNNER, ARMOR LID, UWS SIDE STEPS,
    i hauled around 700 pounds of flagstone before my tsb was done and the bed
    held up, but i did lay them out in layers in the whole bed to spread the weight.
  20. May 6, 2009 at 3:22 PM
    05 TRD Sport
    05 TRD Sport She's Fat, I'm Drunk, It's On.
    30 minutes south of Atlanta
    2016 SR5
    boards or plywood first, then cover bed with thick plastic or small tarp, rolled up over the sides and tailgate. After you've shoveled most of the rock out, just pull the tarp and remaining rocks out. Less mess to clean out. Prevents stuff from falling/getting stuck under tailgate. Works with sand, mulch,etc. Kind of like a bed condom.
