Tow/Haul Mode? Tow Pics?
Discussion in 'Towing' started by jtruck618, May 24, 2008.
  1. Dec 6, 2011 at 6:50 AM
    Cajun1
    Cajun1 Well-Known Member
    Brooks
    Abbeville, LA
    Brush Gaurd 265 Destinations 5100's @ 1.75 LED Lighting Center console Home made Saatchi DDM 5K HID
    thats all a tow/haul mode is...to keep ur truck from going to overdrive...sooo dont put it in DRIVE and keep in fourth gear...however if you are moving at fast speeds i wouldnt go to fast an make ur truck rev too much in 4th
  2. Dec 11, 2011 at 2:44 PM
    Isthatahemi
    Isthatahemi Well-Known Member
    TRD OFF ROAD
    BFG AT's, Weathertechs, Hoppy's brake controller.
    Okay, here's an answer from a non Kool-Aide drinker. I towed over 6000 miles on a trip last summer with my Tacoma TRD OR. In Canada, to get the "tow package", it is required to get the "off road" package, which many on this site tell me is not for off roading. Well, I'm here to tell you the lack of Tow/ Haul sucks. I absolutely hated towing on anything other than flat ground. The biggest piss-off of the whole experience, was that I was able to either control the gears, or use cruise control. If 3rd is selected for power or engine braking reasons, cruise control is not an option. Now before the know-it-alls chime in and say cruise should not be used while towing, it is a much more relaxed safer way to tow, especially when covering 6000 miles.
    Here's the rub; I have sub leased my TRD OR to someone else, and now have and different brand of truck which is rated to tow 1000# less, but has a 6 speed, tow/haul, range select, and manuall gear select. Cruise control works in all gears, and automatically engine brakes, no need to even bother shifting manually. It also NEVER hunts, and uses all 6 forward gears. Look elsewhere my friend, I swore, and swore, and swore that I would never take a long road-trip with the Taco again. It was that irritating. Without naming what I have now, it is a pleasure, turn on tow haul, set the cruise, and enjoy the fact that I now run lower RPM, get better mileage, it's quieter, and I doubt I'll come home with a transmission leak, or a whining rear diff. All for $10K less than the Taco, jeebus.
  3. Dec 23, 2011 at 6:58 PM
    Sprink669
    Sprink669 Well-Known Member
    I didn't know that Yugo's could tow that much ^^^^^^:eek::eek::eek:
  4. Feb 24, 2012 at 12:53 PM
    Misfit
    Misfit Well-Known Member
    IL
    2017 SR 2.7L 4x4 5MT
    I m calling that ^^ one a late model F150 with the new 3.7L V6 :rolleyes: (Not the EcoBoost 3.5L)
  5. Feb 24, 2012 at 1:00 PM
    Misfit
    IL
    Haha nice! Damn trouble makers.. :D
  6. Feb 24, 2012 at 1:03 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Not to mention he's incorrect about only the Offroad having the tow package in Canada , either TRD model comes with it
  7. Feb 27, 2012 at 10:25 AM
    AWorthyOpponent
    AWorthyOpponent Member Caught Off Road
    Dan
    Palm Beach County, Florida
    2013 MGM DCLB TRD SPORT 4x4
    TRD Catback Exhaust
    Towed this trailer this weekend. Heavy Duty Steel Trailer loaded with 2 ATV's, cooler, two 50 gallon water tanks, a little bit of fire wood, and a full tool box came in around 4000-4300lbs. I'm in Florida, so I didn't have to worry about hills. I did have to pull it through some soft sugar sand for about 100 yards. Other than putting it in 4hi for the soft stuff getting to camp, I had no problems...
  8. Feb 27, 2012 at 10:34 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Can you guys get a plain old SR5 with the tow package in Canada or does it only come with one of the TRD packages?
  9. Feb 28, 2012 at 4:41 AM
    elwood
    elwood "Really, how hard can it be?" Jeremy Clarkson
    Neal
    ont, canada
    2007 SR5 4x4 LB
    K/N cold air intake, leer cap, running boards, nose gaurd,E brake control, mud flap cut, suspension tsb, Rear diff breather mod,Factory Fog lights, Factory front diff cover
    Mine is the SR5 and it came standard with the up graded alternator and battery, trd suspension and prewired for the harness. No hitch or 7 pin was at the rear and no tranny cooler. I installed that after, very easy and toyota put on a cooler ( aftermarket and larger) when i bought it.
